ADR Axles any good? - Polaris RZR Forum - RZR Forums.net
post #1 of 3 Old September 16th, 2019, 08:09 AM Thread Starter
b.lee's Avatar
First Name: Bill
My RZR: 2012 900 XP
Member #261164
View b.lee's Photo Gallery(0)
ADR Axles any good?
For my 2012 900 XP,
Are these axles any good. I was taking the rear end apart and one axle didn't want to slide out of the wheel hub, and I messed it up in the process of getting it out.
Since one rear axle is messed up and both axles are out of the machine, I'm going to go ahead and replaced both of them
ADR seems too cheap at $75 a pop but has anyone had good luck with these?
My machine is pretty much all stock, 26" tires, stock HP.
We run it pretty hard sometimes threw the whoops in the woods but that's it, otherwise just cruising around.
So... are these ADR Axles worth running? or no?
2012 RZR 900 XP - Street Legal
KFI Winch - Wheels/Tires - Soundbar
Alba cam chain tensioner - Inline CVT Cooling fan
b.lee is offline
post #2 of 3 Old September 17th, 2019, 08:34 PM
Kevinryan's Avatar
First Name: Kevin
My RZR: 2011 900 xp
Member #174729
View Kevinryan's Photo Gallery(0)
I haven't I ended up going with the sixties axles on the rear andd haven't had any problems. I ride with people that have 1000"s and i do keep up
Kevinryan is offline
post #3 of 3 Old September 18th, 2019, 05:23 AM
oldnslow's Avatar
First Name: Phil
Member #167137
View oldnslow's Photo Gallery(0)
Re: ADR Axles any good?
I bought a set for our ranger, one snapped at the outer cage in less than 100 miles. The warranty is for manufactor defects. Hard to prove that , and really not worth the effort. The rest of the same axles on the machine now have @ 400 miles on them with no problems at all. Maybe I got a bad one, maybe I shouldn't have had it on the trail it happened on. For75 dollars what can you expect? I would not put them on my xp1000 and expect them to last, but I did replace the broken one on the ranger with one.
Phil
It might be lonely at the top, but it's a bitch at the bottom.
oldnslow is offline
