Both axles popping out of front diff? - Polaris RZR Forum - RZR Forums.net
 1Likes
  • 1 Post By jdinvt
post #1 of 9 Old August 13th, 2019, 05:36 AM Thread Starter
jdinvt's Avatar
Member #271786
View jdinvt's Photo Gallery(0)
I was out riding the other day when I notice my drivers front wheel, at about 5mph, kept locking up and sliding on the small rocks I was on so I got out and grabbed the inboard, diff end, and it moved back and forth like a broken shaft but not just that side, its pass side too. I thought they were broke till I got home, tore it apart and when checking the shaft off, they feel fine but they were both still held in by the clip, so I had to pull hard a few times to take it out so why all the play, Just doesn't make any sense to me, could someone please tell me if your shafts have ever popped out or SEEM to have popped out or seem broke but checking off the machine they feel fine. I dont know......
jdinvt is offline
post #2 of 9 Old August 13th, 2019, 06:48 AM
Fastone110's Avatar
First Name: Travis
My RZR: 2016 1000s
Member #31197
Re: Both axles popping out of front diff?
I have had a similar problem. I took the shaft out, cleaned the diff out really good and put a little new grease inside. Took the shaft clip and expanded it slightly and fixed it that way. You can also replace that clip. Other times I just had to get a new shaft because they advertise more angle without binding. Extreme cases could be fixed with limiting straps I suppose. Hope this helps
Fastone110 is offline
post #3 of 9 Old August 14th, 2019, 10:02 AM Thread Starter
jdinvt's Avatar
Member #271786
Thanks, I will give it a good cleaning and regrease it a little bit and see what happens, maybe try to get new clips on the ends or just put the new shafts in and keep the old ons as spares?
Fastone110 likes this.
jdinvt is offline
post #4 of 9 Old August 14th, 2019, 01:44 PM
Demon_Powersports's Avatar
First Name: Demon Powersports
Member #168049
View Demon_Powersports's Photo Gallery(0)
Check the inboard spline to see if there is any sign of wearing, the worn out spline could lead to play in the inboard joint.
Follow Us on Instagram : @DemonPowersports
Like Us on Facebook : @DemonPowersports
Demon_Powersports is offline
post #5 of 9 Old August 18th, 2019, 04:34 AM Thread Starter
jdinvt's Avatar
Member #271786
I put both brand new axles in and still does it, could I possibly need a new hub because those splines are worn out? Or just SEND IT the way it is?
jdinvt is offline
post #6 of 9 Old August 18th, 2019, 10:54 AM
Fastone110's Avatar
First Name: Travis
My RZR: 2016 1000s
Member #31197
So it is still popping out of the diff and locking up the wheel?
post #7 of 9 Old August 18th, 2019, 12:52 PM Thread Starter
jdinvt's Avatar
Member #271786
Not sure yet, havent been out. Found that it needs a new wheel bearing on the drivers wheel and I think that it is because of it being bad, it would lock it up and release it with a curtain speed.
jdinvt is offline
post #8 of 9 Old August 18th, 2019, 03:20 PM
Fastone110's Avatar
First Name: Travis
My RZR: 2016 1000s
Member #31197
I think they just have a excessive amount of play in them. Mine still does. I just go on with it. At least you found out why your tire was locking up.
post #9 of 9 Old August 18th, 2019, 04:05 PM
GimpyRZR's Avatar
Member #208177
View GimpyRZR's Photo Gallery(0)
splines in the hub are probably shot.
GimpyRZR is offline
