2011 900 XP - Pulls hard to the left - Polaris RZR Forum - RZR Forums.net
post #1 of 10 Old June 18th, 2019, 10:49 AM Thread Starter
AwkDenver's Avatar
Member #270446
View AwkDenver's Photo Gallery(0)
Hi Everyone,
I have a 2011 900 XP (no power steering) that pulls hard to the left and I cant figure out why. I have seen a few other posts where people have also had this problem and there were lots of suggestions but no definitive answer. I have tried most of the suggestions I have not had any success. When taking off from a stop the wheel immediately jerks to the left about a 1/4 turn. It takes a conscious effort and energy to keep the vehicle going strait, without it the wheel continues to turn left until the bike is in a full left turn. When moving at slow to moderate speeds it is very easy to steer to the left but takes more energy to steer to the right. Once at higher speeds it is less noticeable. There is no real noticeable difference between 2 and 4 wheel drive, however it does seem to be a little better with 4 wheel drive but still very noticeable.
Things I have tried that did not have an affect
  • Adjusted all 4 calipers to make sure they were not dragging
  • Checked all 4 wheel bearings to make sure they were not damaged
  • Replaced all 4 axles
  • Jacked up the front of the bike and made sure there was no play in the steering.
  • When jacked up both front tires spin about the same and I did not feel any drag.
  • Swapped the 2 front tires
  • Jacked up the back end of the bike and gave it some gas to make sure both back wheels were spinning.
  • Did an alignment. When I did the alignment I made sure that the steering wheel was strait and adjusted to that. In fact I actually adjusted it so the bike should pull to the right but it had no impact. The tie rods do not look bent or damaged any way, unless it is under the boot where I cant see it.
  • Checked to make sure all the bolts on the steering box were tight ( altho, now that I think about it I could double check where the box is bolted to the frame)
  • Checked for anything bent or out of shape and I do not see any kind of impact mark that would indicate significant damage
  • It seems to engage and disengage 4 wheel drive with out a problem.
I really appreciate any suggestions or pointers anyone has. I am really scratching my head on this one.
Thank you
Eric
AwkDenver is offline
post #2 of 10 Old June 18th, 2019, 11:51 PM
ntrsandman's Avatar
First Name: Ken
My RZR: 2012 900 XP
Member #200753
Re: 2011 900 XP - Pulls hard to the left
Hi Eric and welcome to the forum!
Thanks for a detailed explanation on the concern and what you have done to try and correct the issue.
Reading what you have experienced, it is possible you have answered your own question. You stated that it is easier to steer left than right. I believe when you are moving forward, the force of the front tires on the ground will force the steering to go to the path of least resistance.
That said, I would disconnect the outer tie rods at the knuckles and check how the knuckles turn. Then check what I am suspecting. The steering gear/rack. If the steering wheel turns easier to the left than right, then I think you found the smoking gun.
Let us know what you find!
ntrsandman is offline
post #3 of 10 Old June 20th, 2019, 04:43 PM Thread Starter
AwkDenver's Avatar
Member #270446
Last night I jacked up the front of the machine and check for the amount of force needed to turn the wheels left and right. It was the same. One thing I did notice while looking around is that the driver side boot on the tie rod near the steering box looks like it has been replaced and a zip tie was used to keep it closed on the steering box side. It did not feel like there was anything majorly wrong inside by feeling it though the boot. But, it does seem that someone was in there at some point doing something. I bet that is where the problem is located
post #4 of 10 Old June 21st, 2019, 07:25 PM
UPRIDER's Avatar
My RZR: 2012 Liquid Silver, 2014 Orange Madness
Member #47303
View UPRIDER's Photo Gallery(0)
Did you swap rear tires , stand them next to each other and check heights?
UPRIDER is offline
post #5 of 10 Old June 21st, 2019, 07:37 PM
Dirttracker13n's Avatar
First Name: Steve
My RZR: 1000 XP 4
Member #208609
View Dirttracker13n's Photo Gallery(0)
I am a service tech at the local Polaris dealer and we have ran into the racks going bad. Check the pinon on the rack where the steering rod couples to it. We have had a lot of the bearings going out right there.
Dirttracker13n is offline
post #6 of 10 Old June 22nd, 2019, 07:44 AM Thread Starter
AwkDenver's Avatar
Member #270446
Thank you! I will check it. I was just looking at the schematic for OEM parts and was unable to locate the bearing you mention. Any chance you have a part number for it?
Also, someone on Cragslist is selling the entire steering rack all the way down to the ball joints from a 2015 900 xp for 200$. When I look at the 2 schematics they look pretty much the same but different part numbers. Any chance that would fit on the 2011 900 xp?
Thanks again!
post #7 of 10 Old June 22nd, 2019, 10:28 AM Thread Starter
AwkDenver's Avatar
Member #270446
Actually I just ordered a new aftermarket steering rack from Amazon. Hopefully it solves the problem
post #8 of 10 Old June 22nd, 2019, 03:04 PM
dajo's Avatar
First Name: Dave
Member #19884
View dajo's Photo Gallery(0)
Let us know how it works out.
dajo is offline
post #9 of 10 Old June 22nd, 2019, 03:09 PM
shilo020's Avatar
First Name: Rick
My RZR: Wreck it Rick: 2015 XP1000 Voodoo Blue / You Know...For the Kids: 2015 XP1000 Havasu Red
Member #59828
View shilo020's Photo Gallery(0)
It may not be front pulling left but rear pulling right. Check the rear alignment too. My car had a bent trailing arm. It was hard to see but enough that the car would not run straight.
shilo020 is offline
post #10 of 10 Old July 8th, 2019, 11:51 AM Thread Starter
AwkDenver's Avatar
Member #270446
A new steering rack was 93$ on Amazon and I put that in and helped 75% of it. Then I checked the pressure on the rear passenger side and indeed it was low on pressure. That solve the problem like 90%. I figured the last 10% was from alignment, however I sold the bike before I got it totally fixed.
Thanks for the suggestions everyone!
