2013 900xp eps big bore 975 what else is needed - Polaris RZR Forum - RZR Forums.net
post #1 of 8 Old April 12th, 2019, 07:10 PM Thread Starter
Johndeere900xp's Avatar
Member #268346
View Johndeere900xp's Photo Gallery(0)
Hi iv been reading a lot about the 900 xp and I recently bought a 2013 900 xp I love it the guy said it used oil so I got a good deal being a mechanic I am planning a rebuild it’s all stock. I was hoping someone could tell me what it would take on top of running a big bore 975 upgrade. Would a clutch, header, intake all be needed? I’m gunna run 10.5:1 compression but I don’t want a loud ride cause of the kids. So if I could run the stock exhaust or an exhaust similar in sound would be great.i plan on building a mudder 28 or 30 inch bkt tires so I want it to run cool going slow so would a turbo on this small of a motor help cool it or will it heat more. Sorry for all the questions I’m a diesel mechanic not a high rpm small engine guy lol. I live in Minnesota and plan on mudding with it and the kids.
Johndeere900xp is offline
post #2 of 8 Old April 15th, 2019, 04:14 AM
Divit's Avatar
Member #255866
View Divit's Photo Gallery(0)
Re: 2013 900xp eps big bore 975 what else is needed
The factory airbox has been known to not seal completely, could be valve guides/seals, rings/cylinders causing the oil consumption.
How many miles?
These machines have plenty of power to spin 28-30's when clutched properly
2012 900xp, Bikeman 935, stage 2 cams, P&P head, Bikeman intake & tune, PC5, Dynoed @ 108hp, Goldstar clutch weights, Custom cage, SATV forward arched A's, Alba Rear arched kit, Rhino Axles, ProArmor seats & Belts, Walker Evans Beadlocks & 30" Kanati TeraMasters
climaxfab.com
Divit is online now
post #3 of 8 Old April 15th, 2019, 06:06 AM
HiTechRedneck's Avatar
First Name: Jack
My RZR: 2013 XP 900
Member #263946
View HiTechRedneck's Photo Gallery(0)
S&B Particle Seperator!! Save the engine from getting "Dusted"
HiTechRedneck is offline
post #4 of 8 Old April 15th, 2019, 08:51 AM Thread Starter
Member #268346
Divit I just rolled over 2100 miles when I got it the air filter was filled with mud so I tore the whole intake system down and cleaned it. changed out the oil and filters it reads good compression but the leak down test fails. So iv been pondering pulling the head and having it rebuilt and taking the pistons out to see what they look like. Just haven’t messed with much for gas engines. It’s not much for oil use. Iv noticed that the vent tube is pushing all my oil out of it. Like it’s building to much pressure from the rings being bad? Is their a valve on the vent tube? To help prevent the oils from coming out of the vent tube or a screen?
post #5 of 8 Old April 15th, 2019, 08:52 AM Thread Starter
Member #268346
Hitechredneck is there a good place to get an s&b filter system?
post #6 of 8 Old Today, 04:31 AM
First Name: Jack
My RZR: 2013 XP 900
Member #263946
Lots of places on line, even Amazon and all are priced about the same. Just Google S^B Particle Seperator.
post #7 of 8 Old Today, 04:52 AM
Smooth Moderator
roguedriver's Avatar
First Name: Ken
My RZR: 2011 1102cc 900XP
Member #24045
View roguedriver's Photo Gallery(0)
If you didn't know already, you'll need to replace the rods if you go 975. Most people go with Carillo's.
Ken R.
roguedriver is online now
post #8 of 8 Old Today, 05:38 AM
Divit's Avatar
Member #255866
Originally Posted by Johndeere900xp View Post
Divit I just rolled over 2100 miles when I got it the air filter was filled with mud so I tore the whole intake system down and cleaned it. changed out the oil and filters it reads good compression but the leak down test fails. So iv been pondering pulling the head and having it rebuilt and taking the pistons out to see what they look like. Just havenít messed with much for gas engines. Itís not much for oil use. Iv noticed that the vent tube is pushing all my oil out of it. Like itís building to much pressure from the rings being bad? Is their a valve on the vent tube? To help prevent the oils from coming out of the vent tube or a screen?
That sounds like a good approach. I have the 935 kit on mine with about 500 miles on the rebuild and it blows a little smoke out the vent until it warms up. I'm running a prefilter with the factory airbox and just greased the edges of the factory filter element, its clean inside now.
climaxfab.com
Divit is online now
2013 Rzr 900xp low miles, eps for sale TOlsen RZR XP 900 0 November 8th, 2015 07:07 AM
935 or 975 Big Bore Kit??? racerxray1 RZR XP 4 900 Specific Discussion 9 May 4th, 2015 09:25 PM
Ricochet Racing 85mm Big Bore Kit Installation mmotley Projects and How-To 8 December 20th, 2010 06:22 AM
