Won't start when you tighten the crankcase. - Polaris RZR Forum - RZR Forums.net
post #1 of 7 Old April 12th, 2019, 03:23 PM Thread Starter
Viper31's Avatar
Member #265636
View Viper31's Photo Gallery(0)
Ok,few weeks ago the bolts on my flywheel came apart (luckily as I was cranking not while running) and screwed up the one way starter clutch. Replaced and loctite the flywheel bolts and intermediate gear. Put on a new one way clutch and put it all together. Nothing but a click when I tried to start it. Replaced the battery, solenoid and rebuilt the starter, still nothing but the click. Took the crankcase cover back off and starter engaged like it was supposed to and turned over fine. Put it back together and click. Loosened the bolts on the crankcase cover, spins free like it should, tighten and nothing....any suggestions?
Viper31 is offline
post #2 of 7 Old April 12th, 2019, 03:31 PM
Aspiring Perfectionist
RWB713's Avatar
First Name: Richard
My RZR: 2018 XP4 Turbo
Member #70552
Use an OEM gasket and no silicone on the stator cover and torque to spec, it is critical on those, thereís a couple threads Iíve helped others on with it too. It really is that close of a tolerance
2018 XPT4 - Bailey
RWB713 is offline
post #3 of 7 Old April 12th, 2019, 03:45 PM
RWB713's Avatar
First Name: Richard
Member #70552
Re: Won't start when you tighten the crankcase.
No start
https://www.rzrforums.net/rzr-xp-900/405409-no-start.html
2018 XPT4 - Bailey
RWB713 is offline
post #4 of 7 Old April 13th, 2019, 09:37 AM Thread Starter
Viper31's Avatar
Member #265636
WOW!! Thank you so much, that just blows me away!! 3 weeks of scratching my head and throwing money at it for a $20 gasket, LOL. Just so everyone out there knows, that was a brand new Caltric gasket that I had put on there and you see how well that worked! I just ordered 2 new OEM gaskets from Partzilla, but it doesn't look like they are going to get here before the ride I am supposed to go on Tuesday. Unless you tell me its a really bad idea, I am going to make a gasket out of a thicker gasket material and put it back together today, so I can go on my group ride, then put the OEM gasket on soon as it comes in. I am guessing my only danger would be a mild oil leak. Are there any other risks involved in that temporary fix to get me through this ride? Once again, thank you very much for your knowledge.
Viper31 is offline
post #5 of 7 Old April 13th, 2019, 10:36 AM
RWB713's Avatar
First Name: Richard
Member #70552
That would probably work for a temp fix
2018 XPT4 - Bailey
RWB713 is offline
post #6 of 7 Old April 13th, 2019, 01:14 PM
RWB713's Avatar
First Name: Richard
Member #70552
2018 XPT4 - Bailey
RWB713 is offline
post #7 of 7 Old April 13th, 2019, 10:35 PM
MartinezNOjai's Avatar
First Name: Frank
My RZR: 16 1000 xp4
Member #187865
View MartinezNOjai's Photo Gallery(0)
We had the same problem on a buddies, ordered a new gasket from a place that we now know by Chapperhell, called they "had it there" paid $43 shipping for next day and it didn't show up. Called and found out it was not there and was not going to make it and no one called to tell us different. O'riely gasket sheets and a exact o knife, hundreds of miles on it now, its permanent! Amazed that the tolerance was that close.
"Why can't we be into something cheaper? Like knitting"
MartinezNOjai is offline
The Start of my barrage of questions! Starting Issues Dazzle RZR 800 Specific Discussion 15 March 12th, 2019 02:32 PM
'16 XP Turbo Cranks but wont start intermittently mcdblhndl RZR XP Turbo 5 March 5th, 2018 11:02 AM
570 cold start BreakDownBrian RZR 570 Specific Discussion 13 October 28th, 2015 05:32 PM
I disconnected a cable and now rzr wont start! kingalvaro RZR 800 Specific Discussion 3 March 9th, 2015 09:25 PM
Help! No start. eth0211 General RZR Discussion 2 February 14th, 2014 07:28 AM
