2012 Hiccups at idle / stalls out - Polaris RZR Forum - RZR Forums.net
 9Likes
post #1 of 40 Old October 3rd, 2018, 06:07 PM Thread Starter
b.lee's Avatar
First Name: Bill
My RZR: 2012 900 XP
Member #261164
View b.lee's Photo Gallery(0)
2012 Hiccups at idle / stalls out / backfires
I just got this machine and ever since I got it its had a problem with erratic idling and stalling
The engine is all stock
It starts easily with no throttle needed
This happens when the engine is cold or hot
Throttle response is good cold or hot
So far I have replaced:
Airfilter
Spark plugs
Fuel pump
Fuel Filter
In tank fuel pressure regulator
Completely drained tank and replaced old gas with fresh premium gas
Also I took off the air box and inspected the throttle body boots between the TB's and cylinders,
The TB's weren't on completely so I loosened the boots up and pushed them on all the way.
Tightened everything back up and everything is clean and tight from the cylinders back to the air box.
Anyone have any other ideas?
I've drove it around about 10 miles and it runs good otherwise, pretty fast.
I haven't pushed it over 60 mph yet because the rollers on my secondary are flat spotted (Thats another story, I cannot get the secondary off this thing)
2012 RZR 900 XP - Street Legal
KFI Winch - Wheels/Tires - Soundbar
Alba cam chain tensioner - Inline CVT Cooling fan
b.lee is offline
post #2 of 40 Old October 5th, 2018, 11:58 AM Thread Starter
b.lee's Avatar
First Name: Bill
My RZR: 2012 900 XP
Member #261164
Re: 2012 Hiccups at idle / stalls out
Bump... anyone have any ideas?
Maybe TPS issue?
How do I check/test/set the TPS Voltage?
b.lee is offline
post #3 of 40 Old October 6th, 2018, 06:06 AM
Aspiring Perfectionist
RWB713's Avatar
First Name: Richard
My RZR: 2018 XP4 Turbo
Member #70552
Sounds like an XP 900, mine always behaved similar, had the same little stumble, would randomly die at idle, even after i replaced the engine, still did it, I never really fixed it, just drove it, you could try the Idle Air Control Valve, or another possibility is that the primary clutch is not fully disengaging and slightly grabbing the belt, at one point with mine one of the weights had worn a goofy groove into the clutch body, and it wouldn't allow it to fully disengage, mine was bad enough that it made it act like a direct drive, so you could never stop unless the transmission was in neutral, obviously yours isn't that bad, but it may be developing, something to look at at least.
As for getting that secondary off...
just make sure to use a hammer that won't destroy the bolt (brass, a very solid plastic deadblow, etc..)
and when you put that secondary back on, put a little bit of anti-seize on the transmission input shaft, never have that problem again
Denver and b.lee like this.
2018 XPT4 - Bailey
RWB713 is online now
post #4 of 40 Old October 6th, 2018, 06:47 AM Thread Starter
b.lee's Avatar
First Name: Bill
My RZR: 2012 900 XP
Member #261164
Thank you RWB713!
I will inspect the primary, and hopefully get the secondary off, lol.
Where is the IAC located?
RWB713 likes this.
b.lee is offline
post #5 of 40 Old October 6th, 2018, 07:01 AM
RWB713's Avatar
First Name: Richard
Member #70552
Itís on the crossbar above the throttle body, under the bed cover, has 3 hoses that come out of it, 1 from the air box, 2 into the throttle body
2018 XPT4 - Bailey
post #6 of 40 Old October 6th, 2018, 07:10 AM Thread Starter
b.lee's Avatar
First Name: Bill
My RZR: 2012 900 XP
Member #261164
Thanks again!
RWB713 likes this.
b.lee is offline
post #7 of 40 Old October 10th, 2018, 08:03 PM Thread Starter
b.lee's Avatar
First Name: Bill
My RZR: 2012 900 XP
Member #261164
https://www.youtube.com/watch?v=DlogTdOjnow
I bought a 2lb brass hammer and this trick worked perfectly! Thank you for posting this video!
RWB713 likes this.
b.lee is offline
post #8 of 40 Old October 10th, 2018, 08:35 PM
RWB713's Avatar
First Name: Richard
Member #70552
Glad to help! Make any progress on the other issue?
2018 XPT4 - Bailey
post #9 of 40 Old October 19th, 2018, 06:46 AM Thread Starter
b.lee's Avatar
First Name: Bill
My RZR: 2012 900 XP
Member #261164
No, not yet. Put 200 miles on it last weekend, other than the idling issue it ran good, just not quite getting the top speed.. maxing out at 65mph / hitting rev limiter. Trying to figure that issue out now, lol.
Also if you let it coast to a complete stop, it sorta surges to a stop. Feels like the belt is gripping and not gripping once for every rotation of the belt.
Anyone have any ideas?
b.lee is offline
post #10 of 40 Old October 19th, 2018, 05:17 PM
RWB713's Avatar
First Name: Richard
Member #70552
How'd the primary look? or have you looked at it yet?
I don't remember exactly what the top speed was, but it was around there if I remember right... might have been 75-80 at most... but are you actually hitting the rev limiter? should be either 8300 or 8800 RPM depending on which computer Polaris decided to put in it (that's a whole nother topic),
2018 XPT4 - Bailey
post #11 of 40 Old October 23rd, 2018, 05:52 AM Thread Starter
b.lee's Avatar
First Name: Bill
My RZR: 2012 900 XP
Member #261164
I haven't looked at it yet,
I will be looking at it shortly.
Also I didn't know there was a RPM readout option on the speedo, I'll test it and see what kind of RPM's I'm getting. It sure sounds like a rev limiter.
Thanks!
b.lee is offline
post #12 of 40 Old November 2nd, 2018, 07:08 AM Thread Starter
b.lee's Avatar
First Name: Bill
My RZR: 2012 900 XP
Member #261164
Well I took a peek at the primary, everything looks normal from what I could see. No glaring problems that I noticed.
As for the rev limiter problem, I was seeing/hearing the rev limiter type sound at different RPMs
Sometimes 8600, sometimes 8400, 8500, etc. I only tested it on a few runs and didn't really look into it any further. I wanted to change the belt and clean the clutch faces
After cleaning the clutches and putting on a new belt, I noticed this belt seems to be riding a little too high in the secondary? At least on my 2014 skidoo, we normally adjust the belt so the cogs of the belt are just above the secondary... Is this normal ride height for the belt in the secondary for a 900 rzr xp?
Also I didn't see any way to adjust the ride height of the belt in the secondary? Is it not adjustable?
b.lee is offline
post #13 of 40 Old November 2nd, 2018, 08:35 AM
dajo's Avatar
First Name: Dave
Member #19884
View dajo's Photo Gallery(0)
Originally Posted by b.lee View Post
Thank you RWB713!
Check for IAC hose pinching.
dajo is online now
post #14 of 40 Old November 2nd, 2018, 08:44 AM Thread Starter
b.lee's Avatar
First Name: Bill
My RZR: 2012 900 XP
Member #261164
Thank you RWB713!
Thank you Sir,
I checked that, I was hoping it would be that easy but no dice. Appreciate your input though!
b.lee is offline
post #15 of 40 Old November 2nd, 2018, 09:05 AM
dajo's Avatar
First Name: Dave
Member #19884
My 900Xp also dies occasionally when coming to a stop. Starts back up good. My XP is also hard to get in gear, no grinding just hard to move shifter. Have not removed belt cover and observed if belt stops rotation yet.
Had missing out bad running problem not just at idle that was caused by connector to throttle body not being fully snapped into position.
dajo is online now
[UPDATED 2019] UTV INC RZR Wheel Bearing Greasing Tool UTV Inc. UTV Inc 147 May 2nd, 2019 08:17 AM
Need help! 2012 xp 900 idle problems JasonS1522 RZR XP 900 1 April 20th, 2018 11:59 PM
2015 RZR 4 900 stalls when coming to idle westcoastedgevanisle RZR 4 900 10 April 19th, 2018 04:53 AM
Help with running at idle. 2012 170 Jsmycal RZR 170 Specific Disccusion 6 December 18th, 2016 01:28 PM
help! XP 900 motor won't idle properly and stalls...and.. malter RZR 900 Engine 7 November 4th, 2016 08:19 PM
