No start - Polaris RZR Forum - RZR Forums.net
 6Likes
post #1 of 24 Old April 1st, 2017, 03:11 PM Thread Starter
sawguy50's Avatar
Member #139617
View sawguy50's Photo Gallery(0)
No start
So, after my top end rebuild, it started and ran fine then I noticed the stator cover gasket leaking. I removed the cover replaced the gasket and now it wont' start. Starter clicks once when turning the key and dash lights go out if key is held on. Battery is fully charged. Anything it might be before I take the stator cover off again?
sawguy50 is offline
post #2 of 24 Old April 2nd, 2017, 01:36 PM
texhntr
texhntr's Avatar
First Name: Doug
My RZR: 2013 XP900 Orange Madness
Member #172089
View texhntr's Photo Gallery(0)
Re: No start
Maybe a bad connection? I would check the connections at the battery, starter, starter solenoid and the ground.
texhntr is offline
post #3 of 24 Old April 2nd, 2017, 01:37 PM
texhntr
texhntr's Avatar
First Name: Doug
Member #172089
Re: No start
Oh, and either test or bypass the solenoid.
texhntr is offline
post #4 of 24 Old April 2nd, 2017, 02:56 PM Thread Starter
sawguy50's Avatar
Member #139617
Re: No start
I removed the stator cover and couldn't find anything odd. Removed the starter to flywheel gear and turned the key. The starter spun normally. Put it back together. Now wait 24 hrs for form a gasket to cure. Then I'll try again.
sawguy50 is offline
post #5 of 24 Old April 10th, 2017, 07:49 AM Thread Starter
sawguy50's Avatar
Member #139617
Re: No start
bad solenoid...terminals rusted solid
sawguy50 is offline
post #6 of 24 Old April 15th, 2017, 08:30 AM Thread Starter
sawguy50's Avatar
Member #139617
Re: No start
Update...not the solenoid. Replaced it and same thing...one click(starter) and ground wire jumps when it clicks. Reading back to 2014 there was an issue with a bolt(stud) coming loose next to the flywheel. Would this be my next move or look into starter?
sawguy50 is offline
post #7 of 24 Old April 23rd, 2017, 09:37 PM
Aspiring Perfectionist
RWB713's Avatar
First Name: Richard
My RZR: 2018 XP4 Turbo
Member #70552
Did you torque the stator cover to spec? I also recommend using the OEM gasket. A friend of mine had an issue with the starting turnin very slowly after he took off the cover to fix an oil leak and tightened it down too much, and used silicone gasket maker.
the starter shaft seats firmly into a bushing on the stator cover, if you put the starter shaft in too much of a bind, it doesn't allow the starter motor to spin freely and can overload the solenoid.
Don't know if you've fixed it or not yet, and I don't know that that's your problem, just thought I'd share, there is also a numbered sequence to torque the bolts down.
AlbaNate likes this.
RWB713 is offline
post #8 of 24 Old April 26th, 2017, 07:31 AM Thread Starter
sawguy50's Avatar
Member #139617
Re: No start
This could be my problem...I used permatex fipg instead of factory gasket. Will remove and replace one more time...thanks..I'll let you know.
sawguy50 is offline
post #9 of 24 Old May 2nd, 2017, 12:34 PM Thread Starter
sawguy50's Avatar
Member #139617
Re: No start
RWB713...without your help I would still be scratching my head. I can't believe a gasket that's about 1/32nd inch thick could make the starter lock up but it did! Installed factory gasket and starter spun like it should. Thank you! This info should be in or have a sticky by itself. Sometimes our brains try to think too much into a situation. When I go back to the beginning of this problem (stator cover oil drip), the only thing I did different was use fipg instead of the factory gasket.
AlbaNate and generaljls like this.
sawguy50 is offline
post #10 of 24 Old May 2nd, 2017, 01:09 PM
AlbaNate's Avatar
Member #24131
View AlbaNate's Photo Gallery(0)
Re: No start
Love this forum! good job guys. Never reuse the stator gasket on an early XP900. This will happen almost every time. Also, there is a washer on the outside of the circlip on intermediate starter gear post that is missing sometimes and will do the same thing.
Nate
Alba Racing
[email protected]
LIKE ME AND ALBA!!!
Check us out on Yelp.
AlbaNate is offline
post #11 of 24 Old May 13th, 2017, 11:53 AM
RWB713's Avatar
First Name: Richard
Member #70552
Glad to help! And glad you got it fixed. I know firsthand what it's like to have a rzr as a garage decoration and it's not very fun at all!
It is amazing that a gasket can make that much difference, just shows how tight & influential design tolerances can be.
RWB713 is offline
post #12 of 24 Old May 29th, 2017, 06:49 PM
pa.hunter's Avatar
Member #130737
View pa.hunter's Photo Gallery(0)
Re: No start
seen this before bet thats it
pa.hunter is offline
post #13 of 24 Old September 16th, 2018, 03:58 PM
Cothranm13's Avatar
Member #260834
View Cothranm13's Photo Gallery(0)
Mine started fine before removing the cover. Now the solenoid just clicks.. it won't spin the starter. Battery has 12.7 v.
Cothranm13 is offline
post #14 of 24 Old September 16th, 2018, 04:02 PM
RWB713's Avatar
First Name: Richard
Member #70552
Re: No start
You need to get an OEM gasket and torque it to spec in the correct sequence, I sh*t you not, that little gasket is your problem. Get the OEM gasket, clean all the rtv off, re-install and torque to spec (89 +/- 9 in-lbs if my memory serves me correctly), and the is also a numbered sequence to torque the bolts in, When i get home i can send you a pic out of the manual
2018 XPT4 - Bailey
RWB713 is offline
post #15 of 24 Old September 16th, 2018, 04:12 PM
Cothranm13's Avatar
Member #260834
One more thing if you don't mind. After putting in 3.5 qts. Of oil. It seems to still be all up top in the sump. Is this normal? I haven't had the machine long so it's new to me. I would've thought gravity would factor in here.. thanks
2012 800 will turn over, but wont start DCeighty8 RZR 800 Specific Discussion 16 May 11th, 2019 02:57 PM
2012 900xp click no start ALLTHEWAYUP900 RZR XP 900 15 October 26th, 2018 01:19 PM
New XPT won't start? MiniMan RZR XP Turbo 5 November 28th, 2016 07:42 AM
Wont start unless battery disconnected for 20 secs aswetich RZR 800 Specific Discussion 1 June 21st, 2016 07:58 AM
Machine won't start for a few seconds after turning key Kurto RZR XP 4 1000 3 June 19th, 2016 10:54 PM
