Rear passenger wheel bowed inward - Polaris RZR Forum - RZR Forums.net
post #1 of 7 Old August 26th, 2019, 03:49 PM Thread Starter
XP4 Turbskie's Avatar
Member #272422
View XP4 Turbskie's Photo Gallery(0)
Hey guys, new to the rzr life. I’ve got a 19’ xp4 turbo. In need of opinions. Took the rzr out last night, got up this morning to pull it out to wash, and noticed the passenger rear wheel is bowed in at the top and front. Driver rear looks fine to me. Don’t know if y’all can tell in the picture but figured I’d post. Everything is stock btw. Any help is appreciated. Also, I have checked everything from, bearings, hub, radius rods, trailing arms, axles, everything and everything seems fine.
XP4 Turbskie is offline
post #2 of 7 Old September 11th, 2019, 03:27 AM
191186's Avatar
Member #256866
View 191186's Photo Gallery(0)
Re: Rear passenger wheel bowed inward
I have one of my rear tires angled in as well .. .. anyone know what causes it ?
A worn suspension part ?
191186 is offline
post #3 of 7 Old September 11th, 2019, 07:18 AM
mwcwood's Avatar
Member #212921
View mwcwood's Photo Gallery(0)
Itís normal. I thought the same thing after my daughter put ours on itís side. I checked everything and couldnít find anything. So I went to the dealer and looked at new ones and they looked the same.
mwcwood is offline
post #4 of 7 Old September 11th, 2019, 09:16 AM
Max H's Avatar
First Name: Max
My RZR: 2018 XPT 2 seat
Member #16311
View Max H's Photo Gallery(0)
You need to measure camber at the loaded ride height...not unloaded. Here is a quote from a post back in 2012 ...
As for adjusting camber it relates a bit differently on offroad vehicles than onroad vehicles due to the suspension travel and the amount of squat under acceleration. Camber will increase negative as suspension compresses from stationary ride height and will increase positive on suspension rebound. It would be best to have some positive camber at stationary ride height, under accelleration you will gain negative camber, too much static camber and you will have less tire contact surface area under hard acceleration and cause slip. Some positive static camber will allow it to go negative under acceleration and during cornering. Also you can adjust the lower arm to gain negative camber and some extra track width or adjust upper arm to gain negative and keep track width the same. Adjusting both upper and lower arms will increase track width and also add some toe in on the rear wheel's and will gain you some straight line stability. But you need to make small adjustments at a time and be sure each side is equal. If you don't really know what you are doing then you can really screw yourself.
Max H is offline
post #5 of 7 Old September 11th, 2019, 09:21 AM
EE
FordTruckMan's Avatar
My RZR: 2019 XP Turbo
Member #201969
Based on the angle of the radius rods in the picture everything looks normal to me, but it's hard to tell with a picture. Take some measurements side to side and see if they are different.
FordTruckMan is offline
post #6 of 7 Old Today, 08:53 PM
chuckscarstereo's Avatar
My RZR: 2016 XP4T
Member #80622
View chuckscarstereo's Photo Gallery(0)
i kept thinking mine looked different than normal and so i finally checked it out and found that one of the ends of the radius rod had came apart, basically, where the inner "ball" had came out of the end of the radius rod. the boot had it covered up pretty well so i didn't notice it at first.
chuckscarstereo is online now
post #7 of 7 Old Today, 09:22 PM
Toddg1's Avatar
My RZR: 2015 XP 1000
Member #225138
View Toddg1's Photo Gallery(0)
I had this happen to me on my XP1K. It ended up being a slightly twisted Trailing Arm.
2019 Turbo S Velocity
Street Legal
Toddg1 is online now
