Sway bar or no sway bar, that is the question - Polaris RZR Forum - RZR Forums.net
post #1 of 7 Old August 14th, 2019, 10:37 AM Thread Starter
Jerry Hall 95's Avatar
Member #241570
View Jerry Hall 95's Photo Gallery(0)
I just brought my 2018 XP4 Turbo Fox home from Shock Therapy last night and tonight after work I will take it for my first spin. I have them do the re-valving and the spring kit and they suggest to me that I have the sway bar kit installed also. After spending over $1600 to have what I had done I really didn't want to spend anymore. So the big question, is it something I should buy or am I going to be OK with out it. I do a lot of riding in the dunes and the desert. Also, do I need to buy the whole kit or can I just buy the solid sway bar?
Can't wait to get home tonight and ride.
Jerry Hall 95 is offline
post #2 of 7 Old August 14th, 2019, 12:13 PM
Steamfitters38's Avatar
Member #225146
Congrats man. You must be very excited. I remember when I brought my first one home on Valentine’s Day...
I have the Gold level kit from ST and considered the sway bar as well. I decided to buy it later and see how it felt first without it. After riding it for awhile now I would only recommend the sway bar if you do a substantial amount of high speed riding. With 30s and the spring kit I find it hard to not over correct and keep vehicle straight when doing 65+MPH. However, I almost never get out of low gear so this is not an issue for me.
Steamfitters38 is offline
post #3 of 7 Old August 14th, 2019, 12:16 PM
PaulK's Avatar
First Name: Paul
My RZR: 17 XP Turbo
Member #34432
View PaulK's Photo Gallery(2)
Re: Sway bar or no sway bar, that is the question
you will definitely need to run a sway bar with ST set up,, weather or not you need their stiffer bar is up to you,, Drive it and see how it feels, it will have way more body roll than it did with the stock set up,,
PaulK is offline
post #4 of 7 Old August 15th, 2019, 09:34 AM Thread Starter
Member #241570
Well I got it off the trailer and took it for a spin. What a difference it made to the ride. Hard to describe all the changes it made but the wide is more plush. As far as the sway bar I am on the edge, but I went ahead and ordered it anyway. It did feel different if you took the steering wheel and just rocked it back and forth. Could I live with it? Yes. I was thinking a head to the dunes in the fall and I push it hard there and I don't want an uneasy feeling doing it. So I highly recommend getting it done if you can afford it.
post #5 of 7 Old August 15th, 2019, 10:38 AM
Jsk8r1's Avatar
First Name: Jason
My RZR: 2017 XP4
Member #19900
View Jsk8r1's Photo Gallery(0)
I had the same (stage 4 springs/re-valve) done on my XP4 and run the stock rear sway bar. I'll be at the dunes for the first time with this new set up for Thanksgiving so I'll decide after that if I really need an aftermarket sway bar.
Jsk8r1 is offline
post #6 of 7 Old August 15th, 2019, 11:50 AM Thread Starter
Member #241570
I will probably go for Camp RZR around Halloween and I am sure it will be a big improvement from the last time I was there. I will post the results of the trip when I get back.
post #7 of 7 Old August 15th, 2019, 12:09 PM
Aspiring Perfectionist
RWB713's Avatar
First Name: Richard
My RZR: 2018 XP4 Turbo
Member #70552
Walker Links.... that is all
2018 XPT4 - Bailey
RWB713 is online now
