Sway Bar Clunk - Polaris RZR Forum - RZR Forums.net
 5Likes
post #1 of 19 Old July 28th, 2019, 07:16 PM Thread Starter
AzRocket's Avatar
First Name: JT
My RZR: 2017 RZR XP4 Turbo
Member #9250
View AzRocket's Photo Gallery(0)
Sway Bar Clunk
Sway bar is making a clunk when going slow or fast, mainly with articulation. Today, I disconnected the sway bar, noise was gone. Is there a way to tell if its coming from the bushings or the end link? Prior to disconnecting, I made sure all the bolts were tight, so I know it wasn't a loose bolt issue. Also, both bushings were just greased.
Sent from my SM-G973U using Tapatalk
AzRocket is offline
post #2 of 19 Old July 29th, 2019, 06:20 AM
Eliminator602's Avatar
First Name: Dickhead
Member #62539
View Eliminator602's Photo Gallery(0)
The clunking noise is the sway bar moving side to side, you can duplicate it by pushing/pulling on it.
New bushings will cure it.
Several posts about clunking sway bars on here
moore3cam likes this.
Eliminator602 is offline
post #3 of 19 Old July 29th, 2019, 05:09 PM Thread Starter
AzRocket's Avatar
First Name: JT
Member #9250
Re: Sway Bar Clunk
Yea, I've read through so many posts on sway bars. I can move the bar by hand (left to right), but if I move/shake the rzr by hand it won't clunk, only when riding. I didn't know if the end links would make a noise if they were worn out. Also didnt know what a bad bushing would sound like, clunk or a squeal. Plus, theres a lot of people on here with kore knowledge than me.
AzRocket is offline
post #4 of 19 Old July 30th, 2019, 08:39 AM
Michale's Avatar
My RZR: 17 XPT2
Member #218193
Re: Sway Bar Clunk
Put a 2 piece shaft collar on the sway bar on the inside inside of each sway bar mount. Granger has them. I don't see why it wouldn't work. Let us know if it does work.
Michale is offline
post #5 of 19 Old July 30th, 2019, 09:59 AM
PaulK's Avatar
First Name: Paul
My RZR: 17 XP Turbo
Member #34432
View PaulK's Photo Gallery(2)
Shock Therapy clamp with Energy suspension bushings,, NO clunking
ID:	581120   Click image for larger version
AzRocket and SkullCandy202 like this.
PaulK is offline
post #6 of 19 Old July 30th, 2019, 10:24 AM Thread Starter
AzRocket's Avatar
First Name: JT
Member #9250
Re: Sway Bar Clunk
During all my reading, I saw your setup from another post. I was looking into the it since it fit the bill. I found it to actually be a little cheaper to get a setup from Flex Rock. Comes with the bushing and mount. I am going to guess it'll be a similar result. As long as their bushing is quality. If not, at least I'll have the stronger mount.
AzRocket is offline
post #7 of 19 Old July 30th, 2019, 10:43 AM
bimmerdog's Avatar
First Name: Pat
My RZR: 2017 XP Turbo
Member #72309
View bimmerdog's Photo Gallery(0)
Re: Sway Bar Clunk
My 15 XP and my friends 17 XPT did what yours is doing. Both times it was the links. Replaced with aftermarket links and problem gone.
2017 XP Turbo
January Ride of the Month
Sold. What is next?
bimmerdog is offline
post #8 of 19 Old July 30th, 2019, 05:51 PM Thread Starter
AzRocket's Avatar
First Name: JT
Member #9250
Re: Sway Bar Clunk
I'm hoping it's the bushings since they are already ordered. If not, I'll be getting links. Did you get the solid ones, or adjustable ones? I was leaning towards solid.
AzRocket is offline
post #9 of 19 Old July 30th, 2019, 06:07 PM
bimmerdog's Avatar
First Name: Pat
Member #72309
Re: Sway Bar Clunk
I did Zbros adjustable and my friend bought new stock links. Both ways solved our problem
2017 XP Turbo
Sold. What is next?
post #10 of 19 Old July 30th, 2019, 06:43 PM
Got4wd's Avatar
First Name: Jeremiah
My RZR: 2017 XPT
Member #79606
View Got4wd's Photo Gallery(0)
Re: Sway Bar Clunk
Mine was the bushings. Front and rear were wore out. New ones and no more clunk.
AzRocket likes this.
Got4wd is offline
post #11 of 19 Old July 31st, 2019, 09:47 AM
RZRCrawlin's Avatar
My RZR: 2017 RZR XP4T
Member #17965
View RZRCrawlin's Photo Gallery(0)
Re: Sway Bar Clunk
I did the Flex Rock mounts, the Thunderhawk sway bar gusset kit, the ZBroz adjustable sway bar (And created a quick disconnect to adjust on the fly. I call it my "Manual Dynamix" setup ), and Assault links. I seriously love that setup!
SkullCandy202 likes this.
Let me know if you're heading to Sand Hollow to rock crawl!
RZRCrawlin is online now
post #12 of 19 Old July 31st, 2019, 09:58 AM Thread Starter
AzRocket's Avatar
First Name: JT
Member #9250
Re: Sway Bar Clunk
Which bushings did you put in the front? No mods on that right, just a swap? I could see those moving a bit on mine the other day.
AzRocket is offline
post #13 of 19 Old July 31st, 2019, 09:59 AM Thread Starter
AzRocket's Avatar
First Name: JT
Member #9250
Re: Sway Bar Clunk
I'd definitely like to see a pic of that setup.
AzRocket is offline
post #14 of 19 Old July 31st, 2019, 10:26 AM
RZRCrawlin's Avatar
Member #17965
Re: Sway Bar Clunk
I keep my machine in St George, UT, and will be heading there tonight for a couple of days of riding. I'll snap a photo while I'm up there.
post #15 of 19 Old July 31st, 2019, 02:04 PM
Electrical Contractor
tazz3069's Avatar
My RZR: 2017 XP4 Turbo TITANIUM MATTE METALLIC
Member #17644
View tazz3069's Photo Gallery(0)
Re: Sway Bar Clunk
Mine is coming from the front. I also have the Shock Therapy front sway bar. I also have movement with there bar. They told me that is normal. I am sending my front shocks for them to look at. I have had this noise since they rebuilt my shocks. I think that it is a combo between the sway bar and the springs rubbing on the crossover rings. We will see how it sounds when I get them back.
2017 XP4 Turbo TITANIUM MATTE METALLIC, Custom Simpson Seats, Crow Harnesses, FU2 Motorsport Cage and Bumpers, Shock Therapy Suspension, Shock Therapy Front and Rear Sway Bars, Trinity Exhaust, Alba Racing Tune, Rugged Radio
SOLD. 2015 White Lightning Monochrome, FU2 cage and bumper, OMF Beadlocks, Twisted Stitch Seats, Crow 4 and 5 point harnesses, Alba Stage 3 engine kit, Shock Therapy Stage 4 suspension
tazz3069 is offline
