Glowing Red - Polaris RZR Forum - RZR Forums.net
 3Likes
  • 1 Post By PhatPat
  • 1 Post By Plankk
  • 1 Post By Max H
post #1 of 8 Old July 16th, 2019, 08:03 PM Thread Starter
PhatPat's Avatar
Member #96657
View PhatPat's Photo Gallery(0)
Just purchased a XPT4 it’s got around 170 miles on it. All stock. Tonight after a short ride around my neighborhood maybe 2 miles I noticed the glowing red..Temp showed it around 189 190. Is this normal these to glow that red ? Just want to make sure all is normal. Sorry if this has been posted before. Thanks for any information.
ID:	580406   Click image for larger version
PhatPat is offline
post #2 of 8 Old July 16th, 2019, 08:17 PM
craigstumph
craigstumph's Avatar
My RZR: RZR 1000
Member #59177
Re: Glowing Red
Turbos can get red hot when your on the gas. Its probably OK, however, check your exhaust for restrictions.
Call or Text 801 367 1395
www.proutvparts.com
craigstumph is offline
post #3 of 8 Old July 16th, 2019, 08:28 PM
Aspiring Perfectionist
RWB713's Avatar
First Name: Richard
My RZR: 2018 XP4 Turbo
Member #70552
Re: Glowing Red
All good sir, plenty normal for a turbo to run that hot, donít even have to push it hard.
make sure let it idle for 30sec - 1 minute before you shut it off to let it cool a bit ( it will still glow )
ID:	580410 Click image for larger version
2018 XPT4 - Bailey
RWB713 is offline
post #4 of 8 Old July 16th, 2019, 08:52 PM
Highrider's Avatar
Member #54711
Re: Glowing Red
Yep perfectly normal... as RWB713 stated- just let her idle a bit before you shut it off...It's spooky but it is what it is.
Have a 6 here in my shop- they all do it all 2019's
2019 XP 1000 Trails and Rocks
Highrider is offline
post #5 of 8 Old July 16th, 2019, 09:06 PM Thread Starter
PhatPat's Avatar
Member #96657
Re: Glowing Red
Thank you! Just wanted to make sure. Is the stock exhaust pretty restrictive?
Attachment 580410 Attachment 580412
Thanks! Greatly Appreciated!
Thanks. Will let it idle a little longer also then I have been!
Highrider likes this.
PhatPat is offline
post #6 of 8 Old July 17th, 2019, 03:36 AM
RWB713's Avatar
First Name: Richard
Member #70552
Re: Glowing Red
The stock exhaust has a catalytic converter in it, which keeps a lot of heat built up in the turbo.
Gutting the cat and aftermarket exhaust are two common practices to get rid of it, and it does help, but it will still glow red, ( I have aftermarket exhaust, and those pictures I posted were taken after about 2-3 minutes of idle time after a short hard run ) Just the nature of a high rpm, exhaust driven, compressor turbine.
2018 XPT4 - Bailey
RWB713 is offline
post #7 of 8 Old July 17th, 2019, 05:59 AM
Plankk's Avatar
First Name: Tony
My RZR: 2019 RZR XP4 Turbo
Member #246370
View Plankk's Photo Gallery(0)
Re: Glowing Red
I like to call my "Engine Compartment LED"
I noticed it on mine the first night I bought it and was riding around my yard at night and I was wondering why they would install a red LED in the engine compartment.
RWB713 likes this.
Plankk is offline
post #8 of 8 Old July 17th, 2019, 08:04 AM
Max H's Avatar
First Name: Max
My RZR: 2018 XPT 2 seat
Member #16311
View Max H's Photo Gallery(0)
Re: Glowing Red
If you loose your lighter ...you can always use your turbo to light up fresh smoke!
Don't ask me how I know
RWB713 likes this.
Max H is offline
