Turbo XP4 Driveline Noise - Polaris RZR Forum - RZR Forums.net
 11Likes
post #1 of 27 Old July 9th, 2019, 06:47 AM Thread Starter
tstevens's Avatar
My RZR: 2018 XPT4
Member #258314
View tstevens's Photo Gallery(0)
I know there are a bunch of threads on this topic but I'd like to gather opinions on what this noise is. To give you some background on this:
2018 RZR Turbo XP4, 650 Miles
1. Noise starts occurring at 25 MPH, gets louder the faster you go, happens in 2WD or 4WD.
2. This has a brand new front differential in it. Polaris replaced the front differential under warranty less than 2 miles ago, the pinion bearing let loose in the original diff and sounded exactly like this.
3. I checked the belt, its in good shape. I checked the wheel bearings, they're in good shape. The driveshaft seems to spin perfectly straight, has no vibration, the carrier bearing feels tight and the shaft does not move at all when pulled side to side or up and down. There is nothing rubbing on the driveshaft from front to back.
4. I verified that the new differential is full of fresh fluid.
Here are the videos:
Looking down at the driveshaft:
Looking back in the tunnel towards the carrier (noise gets quieter with camera facing away from front diff):
Thoughts? My plan is to contact my dealer this morning and get it back in, been down for over a month now
2018 RZR Turbo XP4
tstevens is offline
post #2 of 27 Old July 9th, 2019, 09:04 AM
quadfather171's Avatar
First Name: mark
My RZR: 2018 rzr xp turbo
Member #222482
View quadfather171's Photo Gallery(0)
Re: Turbo XP4 Driveline Noise
I don't have an answer for you but, mine did a similar thing this weekend. I haven't had a chance to check it out yet. mine made a noise similar to yours and vibrated pretty bad. it's a 2018 xpt 2 dr. mine problem also happened at around 25 mph. but only did it every time I switched back into 2 wd because I was entering a paved road? if I came to a stop and put it in 4 wd I could go as fast as I wanted no noise. put it back in 2 wd while moving and it sounds like the driveshaft is gonna come out? has about a 1000 miles on mine everything seems tight as far as the driveshaft and carrier brg. as well as the axles. I did just change the oil in the diffs front and rear but can't imagine that caused anything to happen . I will pull the tunnel out and get a better look as soon as I can. i'll keep you posted.
quadfather171 is offline
post #3 of 27 Old July 9th, 2019, 10:42 AM Thread Starter
tstevens's Avatar
My RZR: 2018 XPT4
Member #258314
Took it by the dealer today, they believe it's the carrier bearing. I went ahead and ordered a Sandcraft Gen 3 bearing and their front diff bearing kit, will update the post to see if that cures it.
SkullCandy202 likes this.
2018 RZR Turbo XP4
tstevens is offline
post #4 of 27 Old July 15th, 2019, 11:02 AM
Demon_Powersports's Avatar
First Name: Demon Powersports
Member #168049
View Demon_Powersports's Photo Gallery(0)
If you still feel vibration it could be because your drive shaft could be bent. If the carrier bearing does not help sold you issue you might need new drive shaft. We have aftermarket options which are phased and balanced let us know if you need help!!
Follow Us on Instagram : @DemonPowersports
Like Us on Facebook : @DemonPowersports
Demon_Powersports is offline
post #5 of 27 Old July 17th, 2019, 05:44 AM Thread Starter
tstevens's Avatar
My RZR: 2018 XPT4
Member #258314
Thanks! I didn't have any vibration, just noise. I dropped it off last night, they're installing the SandCraft Gen 3 carrier and the SandCraft Noise-B-Gone front diff bearing kit. Hopefully this resolves it, if not I'd assume last check box is the driveshaft at that point.
Demon_Powersports likes this.
2018 RZR Turbo XP4
tstevens is offline
post #6 of 27 Old July 17th, 2019, 09:47 AM
AKFULLTHROTTLE's Avatar
Member #263552
View AKFULLTHROTTLE's Photo Gallery(0)
You will want to phase and balance the driveline when installing a solid carrier bearing.
RZRCrawlin likes this.
AKFULLTHROTTLE is offline
post #7 of 27 Old July 23rd, 2019, 07:45 PM
Dave's turbo's Avatar
My RZR: 2016 rzr turbo
Member #265584
View Dave's turbo's Photo Gallery(0)
I have the noise in my 2016 turbo i had the driveshaft balanced and the Sandcraft motorsport carrier bearing, been thinking of doing their noise be gone kit. Would like to hear how yours does.
Dave's turbo is offline
post #8 of 27 Old July 24th, 2019, 11:58 AM Thread Starter
tstevens's Avatar
My RZR: 2018 XPT4
Member #258314
This issue was resolved with the carrier bearing replacement. I went with a SandCraft Gen 3.
From what we can tell, the carrier bearing must have gone bad and caused a wobble in the front pinion which is what toasted the original differential. After Polaris put a new front differential in it, the noise persisted. Once the carrier bearing was replaced, no more noise!
2018 RZR Turbo XP4
tstevens is offline
post #9 of 27 Old July 24th, 2019, 12:03 PM
Max H's Avatar
First Name: Max
My RZR: 2018 XPT 2 seat
Member #16311
View Max H's Photo Gallery(0)
Thank you for giving us the final results...good to know
Max H is offline
post #10 of 27 Old August 15th, 2019, 06:51 PM
utes1478's Avatar
My RZR: 2018 XP4 Turbo
Member #272122
View utes1478's Photo Gallery(0)
I have this exact noise on my 2018 XP4 Turbo. Is the noise still gone after running it a month? Also, forgive my ignorance, but how do I tell if my front diff is messed up from it, like happened to yours?
utes1478 is offline
post #11 of 27 Old August 16th, 2019, 05:35 AM Thread Starter
tstevens's Avatar
My RZR: 2018 XPT4
Member #258314
After a month of use, still no noise. Pull the drain plug on the differential, mine had a TON of metal shavings and the oil was so dark you couldn't see through it. It also made a different noise when the differential was bad, it sounded more like marbles in a blender whereas the driveshaft noise sounded like someone throwing rocks at a flag pole.
2018 RZR Turbo XP4
tstevens is offline
post #12 of 27 Old August 19th, 2019, 07:38 AM Thread Starter
tstevens's Avatar
My RZR: 2018 XPT4
Member #258314
Unfortunately this did not fix the issue, did about 75 miles of riding and the same noise in OP is back in force.
At this point my thought is that there is an issue with the driveshaft, I wish I would have just done it once and put a driveshaft in it while it was apart. I have a brand new Polaris differential in it and a SandCraft Carrier Bearing. When we pressed the bearing on I was told the driveshaft was true but that's the only part that was not replaced.
Will be looking at replacement driveshafts and report back with my findings.
2018 RZR Turbo XP4
tstevens is offline
post #13 of 27 Old August 20th, 2019, 01:28 AM
mannysouza's Avatar
Member #48340
View mannysouza's Photo Gallery(0)
I did the complete drivetrain upgrade and it is much better. The front diff is a bevel gear setup which are noisy.
mannysouza is offline
post #14 of 27 Old August 20th, 2019, 06:32 AM Thread Starter
tstevens's Avatar
My RZR: 2018 XPT4
Member #258314
It wasn't noisy for the first 600 miles, this isn't a normal noise.
2018 RZR Turbo XP4
tstevens is offline
post #15 of 27 Old August 20th, 2019, 11:28 AM
Loaded4bare's Avatar
Member #272234
View Loaded4bare's Photo Gallery(0)
I'm having the same issue on my 2018 Dynamix 4 seater. Not sure when I started hearing the noise, but didn't pay much attention until around the 500 mile mark. Started researching and realized it was an issue. I brought it in under warranty and they had it for 4 weeks. Told me the ring gear was tore up pretty good. I asked him what caused that and he told me "driver behavior", told the guy that was b.s . because I baby this thing.
Anyhow, had it back a week and the noise came back, they get it back and say its the carrier bearing. Changed that, rode 20 minutes and same noise.....I called and lost my sh!t on them. There is a about 1000 miles on the machine now, and I am purchasing the completed drive train from Sand craft and the dealer agreed to put it in at their cost. I could have kept taking it back and they would fix it with stock stuff, but at this point I want to ride the damn thing and not be pissed the whole time. Hoping this works.
Loaded4bare is offline
Tags
differential , driveline , noise , rzr , turbo
