-   RZR XP 4 Turbo (https://www.rzrforums.net/423-rzr-xp-4-turbo/)
-   -   19 Turbo Sprague (https://www.rzrforums.net/rzr-xp-4-turbo/542666-19-turbo-sprague.html)
AKFULLTHROTTLE July 8th, 2019 11:40 AM
19 Turbo Sprague
So the part number for the 19 Turbo Sprague and gear set has changed from 18, anyone know what changed other than part number? From measuring mine and others it appears the window have a larger OD in the inside part.
tstevens July 8th, 2019 06:49 PM
Re: 19 Turbo Sprague
Following this post as I am curious as well. Can't directly answer your question but we just had a new diff put in our 18 and it was an updated part number for the full diff assembly, 1334182 is the new part number and 1333745 is the old part number. From the outside, the case is different than the 2018 diff that came out of it. It's similar in shape and obviously bolted in but it's definitely different.
AKFULLTHROTTLE July 11th, 2019 02:05 PM
Kinda figured there would not be much info out there, was just hoping.
RZR_Joe July 11th, 2019 02:33 PM
Hub bearings, seals, & hubs are updated.
AKFULLTHROTTLE July 11th, 2019 03:11 PM
What were the actual updates? Material Grade? Size?
RZR_Joe July 11th, 2019 04:04 PM
Updated hubs have a brass plug and rubber seal
XMARGH July 12th, 2019 04:19 AM
Same For The Trail & Rock LE Edition & Highlifter Part No 1334181. They are as what you describe as well.
AKFULLTHROTTLE July 12th, 2019 07:20 AM
So for the sprague part number change, do we know what actually changed?
