Weird oil change questions... - Polaris RZR Forum - RZR Forums.net
 4Likes
  • 1 Post By Rockwerx
  • 2 Post By 185EZ
  • 1 Post By 442raceRZR
post #1 of 13 Old June 21st, 2019, 10:00 PM Thread Starter
VegasZ's Avatar
First Name: Zach
My RZR: 2018 Xp4 T Fox
Member #270542
View VegasZ's Photo Gallery(0)
Hi all!
So tonight I changed my oil for the 4th time in my 2018 xp4 T. Some weird stuff happened though. The first oil out of the drain was purple... like melted grape Popsicle purple. The rest of the oil that drained after that seemed to be a normal color as was the oil in the filter. The oil was PS-4 regular, I used that instead of PS-4 extreme like I normally do, could that have something to do with it?
Also, the drain plug itself had gunk on it. Looked like and had the texture of mud with some very, very small (smaller than a grain of salt) metal flecks in it. Is that bad?
Last weird thing, after I filled up with the 2.75 quarts the book says and after running it for about 30 seconds and letting it rest for another 30, the dip stick is a solid inch above the top "full/safe" hole.
What in the world is going on?? Any help or thoughts would be *MUCH* appreciated. Thanks!
Zach
VegasZ is offline
post #2 of 13 Old June 21st, 2019, 10:01 PM Thread Starter
VegasZ's Avatar
First Name: Zach
Member #270542
Re: Weird oil change questions...
Here is a picture of my oil drain pan which was clean before hand.
Name:	rzr oil pan.jpg
VegasZ is offline
post #3 of 13 Old June 21st, 2019, 10:39 PM
Rockwerx's Avatar
My RZR: 2015 900S 2016 1000S 2018 XP Turbo
Member #85936
View Rockwerx's Photo Gallery(0)
You may have mistakenly drained the transaxle and then added more oil to the engine.
bbyers likes this.
2016 1000S 2018 XPT
Rockwerx is offline
post #4 of 13 Old June 22nd, 2019, 05:27 AM
BWXT's Avatar
My RZR: 2018 XP1000 Black
Member #241858
View BWXT's Photo Gallery(0)
Yep
BWXT is offline
post #5 of 13 Old June 22nd, 2019, 06:05 AM
Eliminator602's Avatar
First Name: Dickhead
Member #62539
View Eliminator602's Photo Gallery(0)
like said, you drained the trans fluid, its purple
Eliminator602 is offline
post #6 of 13 Old June 22nd, 2019, 06:23 AM
Mr. & Mrs. PewPewPew
KC Desert's Avatar
First Name: Kat & Chris
My RZR: 2019 RZR Turbo 4 Dynamix
Member #79033
View KC Desert's Photo Gallery(0)
This.
KC Desert is offline
post #7 of 13 Old June 22nd, 2019, 06:29 AM Thread Starter
VegasZ's Avatar
First Name: Zach
Member #270542
Yep, that is exactly what I did. To think, I was even sober while doing all of this. Thank you guys, I really appreciate the heads up (how embarrassing)!
VegasZ is offline
post #8 of 13 Old June 22nd, 2019, 07:18 AM
RZR_Joe's Avatar
Member #23438
Feedback Score: 6 reviews
It's more common than you think so don't feel bad. There's been several others within the last 2 weeks. One would not admit it though
RZR_Joe is offline
post #9 of 13 Old June 22nd, 2019, 07:20 AM
The Lone Rzr
185EZ's Avatar
My RZR: 2017 1KXP4
Member #89257
View 185EZ's Photo Gallery(0)
lol
RZR_Joe and Kofa2 like this.
185EZ is online now
post #10 of 13 Old June 22nd, 2019, 08:29 AM
BWXT's Avatar
Member #241858
The easiest way to avoid this is by paying attention to the tools required. The engine drain plug is a 6mm hex, while all the other drain and fill plugs on the machine are 8mm. I have to believe Polaris did that deliberately to avoid this issue.
BWXT is offline
post #11 of 13 Old June 23rd, 2019, 09:15 AM
442raceRZR's Avatar
My RZR: 2009 RZR 800 S
Member #264074
We all know polaris did thay because they like to make you use as many tools as possible during any task and standardizing sizes for things is a no no in the poolaris playbook.
BWXT likes this.
AMA D38 - Sportsman UTV
Windansea Coffee / Mass Depot / MassFX / Frank Motors / Blud Lubricants / GL Performance Coatings / M&M Offroad / Big Gun Exhaust / TireJect / RynoPower / SuperATV.com / AG Sandcars / Filterwears / Austin Hose
2009 Polaris RZR 800S
442raceRZR is offline
post #12 of 13 Old June 23rd, 2019, 02:18 PM
FFTodd's Avatar
First Name: Todd
My RZR: 2018 XP4 Turbo
Member #257728
View FFTodd's Photo Gallery(0)
I've got my first oil change coming up in the same machine, so I appreciate you asking the question. You may be embarrassed, but you helped me out for sure. Thank you!
FFTodd is offline
post #13 of 13 Old June 23rd, 2019, 04:34 PM
Rockwerx's Avatar
Member #85936
I am pretty sure one is removed with a torx bit and the other plug is a hex plug. I always use a torx socket but in a pinch a hex key will also fit if you are careful.
2016 1000S 2018 XPT
Rockwerx is offline
