32” Tires Only, How Not To Blow Belts - Polaris RZR Forum - RZR Forums.net
 11Likes
post #1 of 22 Old May 26th, 2019, 02:50 PM Thread Starter
HK45's Avatar
First Name: Noob
Member #269698
View HK45's Photo Gallery(0)
Wife told me if I want a RZR, it better be a 4 seater, so here I am. Been reading through the forum for knowledge but haven’t really found my answer since most situations included engine mods and tuners. Probably somewhere down the line I will do engine mods, but that’s down the line. Until then, I still want 15” bead locks with 32” tires for trail reasons on a stock setup. But that’s a lot of extra weight on the clutches so reading around I would need a clutch kit, ya? Anything else besides tearing into the trans for a gear reduction kit? Or am I destined to just get a tuner or new clutches? And I’m only getting started on these noob questions so be prepared for more.
HK45 is offline
post #2 of 22 Old May 26th, 2019, 04:25 PM
Aspiring Perfectionist
RWB713's Avatar
First Name: Richard
My RZR: 2018 XP4 Turbo
Member #70552
Re: 32” Tires Only, How Not To Blow Belts
Speaking from many bad experiences, I’d run it with the stock clutching and see how it does before you change anything, I’ve been through a lot with the clutches on mine, had many issues, my buddy on stock clutching with no engine or gear mods and 32’s has never had an issue. Peak performance may suffer a bit, but it’s better to try it out and see what you think before you open the can of clutch worms.
Max H, RZR_Joe, DogRunner2 and 1 others like this.
2018 XPT4 - Bailey
RWB713 is online now
post #3 of 22 Old May 26th, 2019, 05:31 PM
SierraTrialRiders's Avatar
Member #265050
View SierraTrialRiders's Photo Gallery(0)
If your willing to spend the money, you could look into Portals.
SierraTrialRiders is offline
post #4 of 22 Old May 26th, 2019, 07:19 PM
BLR549's Avatar
First Name: Brandon
My RZR: 2018 XPT1000 V-Blue
Member #68438
View BLR549's Photo Gallery(0)
Arizona Flag Re: 32” Tires Only, How Not To Blow Belts
This works have one on my 18 Turbo 2 seat, its easy to install....with the correct tools. https://aftermarketassassins.com/pro...oil-clutch-kit
BLR549 is offline
post #5 of 22 Old May 27th, 2019, 01:57 PM
Michale's Avatar
My RZR: 17 XPT2
Member #218193
Get a Razorback belt temp gage would be your first step. Keep an eye on temp. If it starts to get hot, slow down.
Michale is online now
post #6 of 22 Old May 27th, 2019, 03:14 PM
bimmerdog's Avatar
First Name: Pat
My RZR: 2017 XP Turbo
Member #72309
View bimmerdog's Photo Gallery(0)
This should be one of the first mod for any UTV.
2017 XP Turbo
January Ride of the Month
bimmerdog is offline
post #7 of 22 Old May 28th, 2019, 08:10 AM
Max H's Avatar
First Name: Max
My RZR: 2018 XPT 2 seat
Member #16311
View Max H's Photo Gallery(0)
I have a 2018 XPT and just had the gear reduction done ....increased 12% hi and reverse 33% low range
I am not an expert but depending on you riding style I would say the gears are a must
I bought all the gears for $450...and the dealer charged me $650.00 in install
It was one of the best mods I have done
I just realized you said 4 seater ...I am not sure but I think the 4 seaters have the lower gears ? RBW713 can answer this question
Max H is offline
post #8 of 22 Old May 28th, 2019, 08:21 AM
RZR_Joe's Avatar
Member #23438
Feedback Score: 6 reviews
Only 16 & 17 XPT4s had low gearing. In 18 Polaris raised the low gearing.
RZR_Joe is online now
post #9 of 22 Old May 28th, 2019, 08:28 AM
Max H's Avatar
First Name: Max
Member #16311
Thanks Joe ...I couldn't remember ....
To the OP then ...I would recommend the gear reduction
RZR_Joe likes this.
Max H is offline
post #10 of 22 Old May 28th, 2019, 08:35 AM
RWB713's Avatar
First Name: Richard
Member #70552
2018+ 2 seat and 4 seat are very close in L, they just use different tooth count gears to get there. 4 seat has a slightly lower H and a noticeably lower R
XPT ----------------------------------- XPT4
L: 20.25:1 --------------------------- L: 20.27:1
H: 11.58:1 --------------------------- H: 12.46:1
R: 23.36:1 --------------------------- R: 26.23:1
Gear Reduction is very useful and, in my opinion, makes the machine geared the way it should be. But it may not be for everyone. I don't think gear reduction is absolutely necessary, and it's more than some want to dive into. It all depends on how you use it, and how you like the way it behaves while you use it. Just put the 32's on an ride it for a bit, if you find things you don't like, and things you'd like to change, then look into options, but make sure they're what you need / want to do before you do them, and having a good baseline to start with is a crucial part to the right mods, if any.
And having done gear reduction, and messing with every aspect of the clutches, with the AA kit linked above, I will tell you that your clutch setup has more to do with belt life than the gearing ( I initially thought the opposite ), and the stock setup is the baseline you need for clutch setup. I absolutely love my gearing now, don't get me wrong, but I'm only 75% happy with my clutching, and I sit and ponder everyday about just putting all the stock clutch items back in and seeing how it reacts, or why i even messed with it in the first place.
There's a link to my build thread in my signature if you'd like to read the whole story, and you can see how my thoughts and opinions progressed on the whole thing as I went along, might even answer some other questions you'll have in the future too.
I reiterate my first statement here: Put the tires on and run it as is, don't open the can of worms if you don't have to. Your bank account also likes this option.
"If it ain't broke don't fix it"! lol
Max H, RZR_Joe, Rockwerx and 1 others like this.
2018 XPT4 - Bailey
post #11 of 22 Old May 28th, 2019, 08:50 AM
KY-Rider's Avatar
My RZR: 2018 1000XP High Lifter
Member #255129
View KY-Rider's Photo Gallery(0)
Have you considered the High Lifter Edition ?....comes with lower gears than the others. I have a 2-Seater HL that I run 32's on 15 inch beadlocks with no mods at all and no issues. I do alot of trail and rock riding in Kentucky, Tennessee Region
Jollish3076 likes this.
KY-Rider is offline
post #12 of 22 Old May 29th, 2019, 06:17 AM
Chevytahoe4x4's Avatar
Member #230801
View Chevytahoe4x4's Photo Gallery(0)
My wife told me the same thing when I went to get another UTV. I went with the XPT 4. Had 32" tires before I left the dealer. Got home went for a spin and topped out at 45 MPH. Gave aftermarket assassins a call and got a cluthc kit. Only tool about 1 hour to install. Haven't had any issues since. Love the power. I have 1500 miles on it so far. No belt problems. I ride the outlaw's and hatfield and mccoy trail in WVA. I havent found a hill that I didn't have the power to climb.
Chevytahoe4x4 is offline
post #13 of 22 Old May 29th, 2019, 01:49 PM
Jollish3076's Avatar
First Name: Jason
My RZR: 2019 RZR XP4 1000 High Lifter
Member #266130
View Jollish3076's Photo Gallery(0)
Definitely take a look into the High Lifter Edition XP4. Comes with the lower gearing, high clearance A arms and Radius Rods, lower doors, front bumper, winch and snorkels (will never need those myself) out of the box. I put 32's on my stock wheels and so far have not had any issues with the belt or power at all. We do mainly slower technical trail riding in IN, KY and TN so we are mainly in low all the time other than getting to and from trail heads and the campgrounds.
KY-Rider likes this.
2019 XP4 1000 HLE
Jollish3076 is offline
post #14 of 22 Old June 4th, 2019, 11:05 AM
Adam Woolf's Avatar
Member #264568
View Adam Woolf's Photo Gallery(0)
What about just getting an XP4 Turbo S. Problem solved.
Adam Woolf is offline
post #15 of 22 Old June 4th, 2019, 11:55 AM
RZR_Joe's Avatar
Member #23438
Problem not solved, the 18+ XPT (S) have a higher gear ratio than the 16/17 models.
