Tusk Terrebite Tires 301014 - Polaris RZR Forum - RZR Forums.net
post #1 of 9 Old May 21st, 2019, 04:47 PM Thread Starter
SierraTrialRiders's Avatar
Member #265050
View SierraTrialRiders's Photo Gallery(0)
Hello. Just got a set of these to try. Is anyone out there using these and if so, what pressures are you running in them? Can't find any literature on them regarding reccomended running pressure. Only says 32lbs max pressure on the tire. Just trying to get as even of wear as I can on these tires. Thanks.
SierraTrialRiders is offline
post #2 of 9 Old May 21st, 2019, 06:50 PM
Signguy71's Avatar
Member #69444
View Signguy71's Photo Gallery(0)
Re: Tusk Terrebite Tires 301014
I have 32" with beadlocks and run 11 psi. I only trail ride in the woods 35 mph and below.
Signguy71 is offline
post #3 of 9 Old May 21st, 2019, 06:59 PM
PaulK's Avatar
First Name: Paul
My RZR: 17 XP Turbo
Member #34432
View PaulK's Photo Gallery(2)
32x15 Kevlar with Beadlocks 9 psi. Desert Trails and Washes with some hi speed 65+
>500 miles,, Great Tire so far
PaulK is offline
post #4 of 9 Old May 21st, 2019, 07:05 PM Thread Starter
Member #265050
Thanks appreciate the info guys. I don't have headlocks yet but will soon. I'm at 10 in the front and 15 in the back on regular wheels.
post #5 of 9 Old May 21st, 2019, 07:12 PM
Metki's Avatar
Member #164697
View Metki's Photo Gallery(0)
To get them to hook good on rocks I ran 7 psi the side walls are stiff but trail 10 psi did the best for me
Metki is offline
post #6 of 9 Old May 21st, 2019, 07:29 PM Thread Starter
Member #265050
@Metki thank you. I was just eyeballing them as I was adjusting the psi. I havent got to run them yet. 10 psi in the front looked good to me. It didnt look so ballooned. Foot print flattened out better. I left 15 psi in the rear as I carry about 150lbs in my cargo box in the bed and the weight of my high lift jack. We typically do desert trails and forest trails.
post #7 of 9 Old May 21st, 2019, 07:55 PM
rstudner's Avatar
First Name: Roger
My RZR: 2017 XP1000
Member #209049
View rstudner's Photo Gallery(0)
I've run them 17psi at the hatfield mccoy's .. doing 35mph+ oh trails.
Steer like champs
rstudner is offline
post #8 of 9 Old May 29th, 2019, 05:01 PM
Kzneft's Avatar
My RZR: 2019 RZR4 Turbo
Member #68959
View Kzneft's Photo Gallery(4)
In Moab last week ran about 7 to 8 lbs for rock crawling. 32" Terabites Kevlar. So far worked good. Of course you should have bead locks so you don't have the tire slip off the beads.
Kzneft is offline
post #9 of 9 Old May 29th, 2019, 05:07 PM Thread Starter
Member #265050
Thank you for your response. Your right about the beadlocks but being I'm not rock crawling right yet, I'm using regular wheels for desert and forest trails. Will be getting them soon tho. Thanks for the info.
