Primary clutch removal tool. - Polaris RZR Forum - RZR Forums.net
RZR XP 4 900 Specific Discussion For all specific information pertaining to the Polaris RZR XP 4 900.
 4Likes
  • 3 Post By Hunterworks
  • 1 Post By Hunterworks
post #1 of 11 Old August 11th, 2019, 06:23 PM Thread Starter
Shawn Cooke's Avatar
Member #262542
View Shawn Cooke's Photo Gallery(0)
Hi, I have a 2013 900 xp 4 walker Evans esp. It has close to 4000 miles on it. 300 of them might be from me. I haven't had it that long. The guy I bought it from claims to have done regular maintenance on it at his local dealer. From the looks of it and the way it drives, I can tell it was taken care of. I ride it hard. I had noticed a few rides ago that it was sometimes hard to get into and out of a gear. Not always. I did get into water one time and felt a little slip and instantly drained the belt housing. After a few minutes I road and it seemed like it had never happened. The last time I went out I accidentally, and I swear it was an accident, went into a major mud hole and got stuck. I don't have a winch yet, and was alone. I went back and forth for about a half hour, then called for help. On the way home I heard it start squealing a little and still trying to go after applying the brakes. Got it home and can only shift when off. Took belt cover off and there was some mud and water inside. Belt spins all the time. Checked the center bearing and it's froze. That long story leads to this. I don't have the removal tool. I know what most are going to say, and I'll take it, but...I've seen people make home made tools by using a long bolt and adding things like socket extensions or what not in front of the bolt. My question is, can't I use the bolt that came out of it, if I add a piece of round stock, just smaller than the threads of the primary bolt, and it work just the same?
Shawn Cooke is offline
post #2 of 11 Old August 12th, 2019, 04:41 AM
Hunterworks's Avatar
First Name: Todd
Member #47437
Feedback Score: 8 reviews
Re: Primary clutch removal tool.
NO, the puller threads screw into the clutch it is bigger than the bolt that holds it on, it screws into the crank and please don't do the homemade thing, you already got one mess don't make it two.
Use the right puller and then see what you need clutch related, we would have the puller, etc if needed.
Todd
www.hunterworks.com
Todd
Office phone: 601-771-0070
Hunterworks is offline
post #3 of 11 Old August 12th, 2019, 02:57 PM Thread Starter
Member #262542
What all tools do I need for 2013 900 xp 4 walker Evans?
post #4 of 11 Old August 12th, 2019, 03:55 PM
Fastone110's Avatar
First Name: Travis
My RZR: 2016 1000s
Member #31197
What all do you want to do?
Fastone110 is offline
post #5 of 11 Old August 12th, 2019, 05:44 PM Thread Starter
Member #262542
Take clutch off and replace the bearing
post #6 of 11 Old August 12th, 2019, 06:09 PM
Fastone110's Avatar
First Name: Travis
My RZR: 2016 1000s
Member #31197
Primary Clutch Puller atleast... I have never changed that bearing before but a clutch compression tool might assist, which you can make yourself with all thread, etc. Several merchants on this forum sell both items. You may consider a clutch kit if you need one now would be the time.
post #7 of 11 Old August 12th, 2019, 07:17 PM Thread Starter
Member #262542
Remove primary clutch and replace one way or two way bearing. Which ever I have. I'm sure I have engine braking of some sorts. Wouldn't two way bearing be harder on brakes?
post #8 of 11 Old August 12th, 2019, 07:19 PM Thread Starter
Member #262542
I hate to buy specific tools and then upgrade to newer model, if that would make those tools useless to me
post #9 of 11 Old August 12th, 2019, 07:45 PM
Fastone110's Avatar
First Name: Travis
My RZR: 2016 1000s
Member #31197
The 900/1000 puller fits all 900 and all 1000 rangers and all 900/1000 RZR's all years
All Generals
All Turbo RZR's
All ACE 900 any year
post #10 of 11 Old August 13th, 2019, 04:47 AM
First Name: Todd
Member #47437
Here is the tool package to remove and take the primary apart.
The mention of a compressor above is not right, you use it on the secondary
https://www.hunterworks.com/inc/sdetail/46309/80104
Todd
Fastone110 likes this.
www.hunterworks.com
Todd
post #11 of 11 Old August 13th, 2019, 04:15 PM
442raceRZR's Avatar
My RZR: 2009 RZR 800 S
Member #264074
If you're near San Diego. Buy yourself the puller for like $40 and come over to my place, I have all the clutch tools. Bring a 6r of Red Trolley and a burrito.
AMA D38 - Sportsman UTV
Windansea Coffee / Mass Depot / MassFX / Frank Motors / Blud Lubricants / GL Performance Coatings / M&M Offroad / Big Gun Exhaust / TireJect / RynoPower / SuperATV.com / AG Sandcars / Filterwears / Austin Hose
2009 Polaris RZR 800S
442raceRZR is offline
