Need Polaris RZR 900 mechanic service - Polaris RZR Forum - RZR Forums.net
RZR XP 4 900 Specific Discussion For all specific information pertaining to the Polaris RZR XP 4 900.
 3Likes
  • 1 Post By dartersracing
  • 1 Post By ShakyDog
  • 1 Post By sndnsno
post #1 of 14 Old May 8th, 2017, 05:58 PM Thread Starter
sbruflat's Avatar
Member #189009
View sbruflat's Photo Gallery(0)
I need a Polaris Mechanic to adjust the intake valves on my 2012 Polaris RZR 900XP 4. I have two 2012 RZR's and they all all disassembled in my garage where we are installing new transmissions and some other fixes. I checked the valve clearances and they are out of spec; the intake valve clearance reading cold was 0.0015 in; the spec calls for .005 - .007 in. According to the shop manual, shims are required to make adjustments correctly. I am seeking the help of an experienced Polaris mechanic that can do a house call. I live near 55th Avenue and Pinnacle Peak Road in Glendale Arizona, 85310. Even a recommendation would be helpful. My phone number is 602-882-3111. Thank you in advance for reading this message. The engine compartment is completely exposed and the valve cover has been removed so the whole operation should be relatively simple for an experienced mechanic. Thanks Steve
sbruflat is offline
post #2 of 14 Old May 8th, 2017, 06:14 PM
Clubin's Avatar
First Name: Clayton
My RZR: XPT
Member #61303
Re: Need Polaris RZR 900 mechanic service
Bump
2016 XPT
EVO stage 2
EVO captains choice exhaust
EVO charge tube
OSP clutch kit
Rockford Fosgate Stage 4
STI HD5's 31/10.50/15 Super Swamper IROC'S
Clubin is offline
post #3 of 14 Old May 8th, 2017, 09:04 PM
dartersracing's Avatar
First Name: DONNY
My RZR: 2014 PACE Z1 1000
Member #19554
Feedback Score: 15 reviews
wish I was closer..would love to help you out, Nate at Alba sells the shims, if you have what clearances are now he may be able to sell you the shims you need. He has helped me many times.
sbruflat likes this.
209-373-5336 DONNY DARTER
dartersracing is offline
post #4 of 14 Old May 8th, 2017, 11:59 PM Thread Starter
sbruflat's Avatar
Member #189009
How easy is this operation to do yourself? I have the shop manual and the description seems complicated. especially making sure everything is in the right place when it goes back together. Does the cover over the flywheel need to come off? needs a new gasket then? stuff like that...
sbruflat is offline
post #5 of 14 Old May 9th, 2017, 08:27 AM
AlbaNate's Avatar
Member #24131
View AlbaNate's Photo Gallery(0)
House calls are rare... maybe try:
Neil @ ATV Racing
or
Jason @ Weller Racing
They are in that area.
Nate
Alba Racing
[email protected]
LIKE ME AND ALBA!!!
Check us out on Yelp.
AlbaNate is offline
post #6 of 14 Old May 9th, 2017, 08:49 AM
ShakyDog's Avatar
My RZR: 2013 Jagged X
Member #41826
View ShakyDog's Photo Gallery(0)
Swingarm1 Tim is also in that area and he just rebuilt my head, maybe send him a PM and see what he can help with...
Steve
ShakyDog is offline
post #7 of 14 Old May 9th, 2017, 09:23 AM
Matco's Avatar
First Name: Matt
My RZR: 2012 XP 900
Member #197994
View Matco's Photo Gallery(0)
I just did this on my 2012 xp 900, you do have to take the stator cover off to line up the timing mark on the fly wheel to the cases when reinstalling the cams.You will also have to drain the oil and need a new gasket for the cover. As far as the shims you can either order individual ones or you can get a kit, they are the same as the yamaha yfz 450 ATVs and the honda crf 450 dirt bikes. Its pretty straight forward to do, you just have to be patient with it and take your time.
heres a couple pictures I took while working on it
2012 RZR XP 900
2004 YFZ 501
2008 CRF 450X
Matco is offline
post #8 of 14 Old May 9th, 2017, 10:22 AM Thread Starter
sbruflat's Avatar
Member #189009
Matt, Thanks for responding with the pictures and advice. That is helpful.
sbruflat is offline
post #9 of 14 Old May 9th, 2017, 10:23 AM Thread Starter
sbruflat's Avatar
Member #189009
Nate, Thanks for the referrals. i will reach out to them and see if they are interested in helping me. Steve
sbruflat is offline
post #10 of 14 Old May 16th, 2017, 01:54 PM Thread Starter
sbruflat's Avatar
Member #189009
Nate,
If I have the engine down this far what do you think of installing the Alba Stage 2 kit? Where do i purchase this kit? Need advice on what performance enhancement kit to add to my 2012 RZR 900XP 4; the Alba Stage 2, the Jagged X kit; or what else is available that works. My machine already has the following: Dragonfire Fire breather intake system; ZFIMX BAZZAZ fuel injection tuning; Muzzy Perfoemance Exhaust system; oversized radiator; revalved walker evans shocks; 28" tires on 14" rims. Nothing has been done to the clutch. It now has a new transmission. I have it all tore down to install the transmission and checked the valve clearances and found all four intake valves out of spec at .0015 in. Since I am this far into the engine i thought i should look putting in better cams and valve springs and whatever else these high performance kits provide.
Where can I purchase the Alba Stage 2 kit for this machine?
Steve
sbruflat is offline
post #11 of 14 Old May 16th, 2017, 06:11 PM
sndnsno's Avatar
First Name: Ken
My RZR: 2014 XP1K
Member #25844
View sndnsno's Photo Gallery(0)
Steve-
I agree with the post above. Swingarm (Tim) is up in Prescott. He did my 800 years ago and now my daughter has it. Still going strong. Send him a PM.
sndnsno is offline
post #12 of 14 Old May 16th, 2017, 07:36 PM Thread Starter
sbruflat's Avatar
Member #189009
The RZR site cant find anyone in their data base called Swingarm (Tim). Any suggestions?
sbruflat is offline
post #13 of 14 Old May 16th, 2017, 07:38 PM
PNIrzr's Avatar
First Name: Adam
My RZR: 2013 XP4 900
Member #6106
View PNIrzr's Photo Gallery(0)
Swingarm1
PNIrzr is offline
post #14 of 14 Old May 16th, 2017, 09:42 PM
sndnsno's Avatar
First Name: Ken
My RZR: 2014 XP1K
Member #25844
That is the one. He may be up at the rally so give it a couple days for him to get back to you.
sndnsno is offline
[UPDATED 2019] UTV INC RZR Wheel Bearing Greasing Tool UTV Inc. UTV Inc 147 May 2nd, 2019 08:17 AM
rzr 1000 seats charlie78 RZR 570 Specific Discussion 7 September 16th, 2016 06:11 AM
'15 RZR S 900 UTV INC Build UTV Inc. UTV Inc 17 November 13th, 2015 03:48 PM
