Primary Clutch Won't Pop Off - Polaris RZR Forum - RZR Forums.net
 13Likes
  • 1 Post By sandblster
  • 1 Post By SNWMBL
  • 2 Post By Jbbooks
  • 3 Post By Hunterworks
  • 4 Post By RZR_Scott
  • 2 Post By JHMartin
post #1 of 12 Old September 14th, 2019, 01:48 PM Thread Starter
JHMartin's Avatar
First Name: Jay
My RZR: 2017 XP 4 1000
Member #271860
View JHMartin's Photo Gallery(0)
Hi,
I sent an email to @Hunterworks from where I bought my primary clutch puller, but they are closed for the weekend. So in the interest of time, I thought I would reach out to you all. The OEM bolt came right out, but the primary clutch itself doesn't want to break free using Todd's puller and my impact wrench. I did try some light taps on the end of the puller as is suggested in one of Todd's videos. But maybe I'm being too gentle as I don't want to damage something. I could put some Kroil in there or spray Liquid Wrench in. Thoughts, tricks, advice?
Thanks,
Jay
JHMartin is online now
post #2 of 12 Old September 14th, 2019, 01:56 PM
sandblster's Avatar
My RZR: 2018 Dynamix
Member #46247
Re: Primary Clutch Won't Pop Off
Use a hammer with some weight to it. You want to jar it not tease it. Old say, if it doesn't work get a bigger hammer. Some times the weight is what is needed to jar it loose. Have a 3# sledge I have used over the years that has saved a lot of problems a lighter hammer will not touch. Again, jar it don't try to destroy it. Sometimes a rubber hammer on the rim on all side can help. Be very careful with light taps. You what to jiggle it from side to side just a bit. Use caution on all of this. Tap the end of the puller bolt a good solid tap. Is your impact up to the job of loading the puller bolt? Good luck.
sandblster is offline
post #3 of 12 Old September 14th, 2019, 04:20 PM Thread Starter
JHMartin's Avatar
First Name: Jay
Member #271860
Originally Posted by sandblster View Post
...Is your impact up to the job of loading the puller bolt? Good luck.
That's a good question. I have 115 lbs of pressure, but my tank is so small it can only deliver that for about 5 seconds before the compressor comes on. Maybe I have to break down and buy one of those Milwaukee units like Todd uses.
In the meantime I have changed out the square pucks for rollers on the secondary.
Jay
post #4 of 12 Old September 14th, 2019, 04:28 PM
sandblster's Avatar
Member #46247
Electric impacts are totally awesome. You will appreciate it a great deal. Take my along for changing trailer tires if needed. It is a good investment. I like the DeWalt, Milwaukee are great as well.
JHMartin likes this.
post #5 of 12 Old September 14th, 2019, 04:57 PM
SNWMBL's Avatar
First Name: Caleb
Member #207521
The primary bolt is torqued in 2 sequences, I canít remember the initial torque to seat the primary on the crank stub, but the second torque is 96 ft lbs. I think your impact is just too weak, 115 ft lbs isnít much from an impact.
2017 RZR XP4 1000
SNWMBL is online now
post #6 of 12 Old September 14th, 2019, 04:59 PM
b.lee's Avatar
First Name: Bill
My RZR: 2012 900 XP
Member #261164
View b.lee's Photo Gallery(0)
Have you continued to tighten it and hit it, tighten it, hit it, tighten it, hit it?
I did this a few times and about the 3rd time it came off.
But I was using the rod that goes thru the end of the puller, no impact guns
I did have to lodge a piece of wood very carefully under the primary go it couldn't spin backwards
Polaris needs a primary clutch holder tool like skidoo has...
2012 RZR 900 XP - Street Legal
KFI Winch - Wheels/Tires - Soundbar
Alba cam chain tensioner - Inline CVT Cooling fan
b.lee is offline
post #7 of 12 Old September 14th, 2019, 07:05 PM Thread Starter
JHMartin's Avatar
First Name: Jay
Member #271860
I did this a few times and about the 3rd time it came off...
Yes, several times now. I am going to borrow a friend's cordless impact wrench tomorrow and see if that doesn't do the trick.
Thanks,
Jay
post #8 of 12 Old September 15th, 2019, 04:51 AM
Jbbooks's Avatar
First Name: Jeff
My RZR: 2015 XP1000
Member #48508
View Jbbooks's Photo Gallery(0)
Thanks,
Jay
Id buy one. The most handy tool in the shop!
SkullCandy202 and JHMartin like this.
Jbbooks is offline
post #9 of 12 Old September 15th, 2019, 05:57 AM
Hunterworks's Avatar
First Name: Todd
Member #47437
Feedback Score: 8 reviews
bigger impact and bigger swings with hammer
There are several electric impacts and I use Milwaukee, I have two one is 450lbs and one is 1500, I would not be using the 1500, I use it to remove bolts not put them on.
Todd
bduncan1231, Larryg82 and JHMartin like this.
www.hunterworks.com
Todd
Office phone: 601-771-0070
Hunterworks is offline
post #10 of 12 Old September 15th, 2019, 10:24 AM
RZR_Scott's Avatar
My RZR: 2014 800 XC
Member #271236
Thanks,
Jay
Keep the threads on the puller oiled too, it helps to not have the resistance in the threads hold you back too. Not to mention saves them from getting worn out/galled up.
RZR_Scott is offline
post #11 of 12 Old Yesterday, 05:39 PM Thread Starter
JHMartin's Avatar
First Name: Jay
Member #271860
Thought I should close out this thread. The primary clutch came right off with a better impact wrench. Hunterworks white washer now in place.
Jay
Hunterworks and RZR_Scott like this.
post #12 of 12 Old Today, 05:57 AM
First Name: Todd
Member #47437
Thanks,
Jay
Our pullers come lubricated with a nano particle lube
www.hunterworks.com
Todd
