Drive axle (Right Rear) Issue! - Polaris RZR Forum - RZR Forums.net
 6Likes
  • 2 Post By bbyers
  • 1 Post By 2012TxRzrS
  • 1 Post By AustonsRZR
  • 2 Post By TennesseeRZR
post #1 of 13 Old August 18th, 2019, 02:31 PM Thread Starter
AustonsRZR's Avatar
First Name: Shawn K
My RZR: XP4 1000
Member #69850
View AustonsRZR's Photo Gallery(0)
I am trying to remove right rear drive axle. I give it a sharp pull
And it pulls apart inside at the transmission side!
Now I知 having trouble getting last piece out. It seems stuck .
Any suggestions please
AustonsRZR is offline
post #2 of 13 Old August 18th, 2019, 02:47 PM
bbyers's Avatar
First Name: Brian
My RZR: 2017 XPT4
Member #175225
View bbyers's Photo Gallery(0)
Re: Drive axle (Right Rear) Issue!
use a flat pry bar between what remains of the cv shaft and the alum housing and work it out easily. pry evenly all the way around. also grab the cv shaft with vice grip pliers to pull on cv shaft while your prying.
Fastone110 and RZR_Scott like this.
-2017 XPT4-Polaris roof, sliders, trailing arm guards, half windshield, front winch bumper & rear mesh screen, Warn 4500 winch, Ride Command w/rear camara, Razorback 3.0, Evo charge tube, intake tube & Bov, Dyno jet JUNK power vison((ITS HAD BLUE SCREEN OF DEATH FOR OVER A YEAR. ZERO HELP FROM DYNOJET!))w/AA stage 3 tune, Empire exhaust w/quite cores, NRP gated shifter, NRP radius rods, 32" curved led light bar, lower door inserts, PRP door bags, R2C filter. AIRDAM CLUTCHES Best purchase so far!
bbyers is offline
post #3 of 13 Old August 18th, 2019, 02:50 PM Thread Starter
AustonsRZR's Avatar
First Name: Shawn K
My RZR: XP4 1000
Member #69850
Ok cool will try! Thanks!!
post #4 of 13 Old August 19th, 2019, 11:12 AM
2012TxRzrS's Avatar
My RZR: 2016 XP 1000
Member #189609
View 2012TxRzrS's Photo Gallery(0)
Take the left rear axle out and tap the right rear out from the other side.
RZRCrawlin likes this.
2012TxRzrS is offline
post #5 of 13 Old August 19th, 2019, 11:36 AM
Demon_Powersports's Avatar
First Name: Demon Powersports
Member #168049
View Demon_Powersports's Photo Gallery(0)
You would have to use a pry bar and gently wedge it between the CV and diff while having another pair of hands tug the housing to pop it out. Another option if you have tools for welding is to weld a rod to where the axle broke if it is broken. You might need to purchase a new axle if the axle shaft is damaged. Otherwise you just need a c-clip to get things fixed. If you have any questions please DM us.
Follow Us on Instagram : @DemonPowersports
Like Us on Facebook : @DemonPowersports
Demon_Powersports is offline
post #6 of 13 Old August 19th, 2019, 12:05 PM Thread Starter
AustonsRZR's Avatar
First Name: Shawn K
My RZR: XP4 1000
Member #69850
Thank guys!!
I値l get at it again tomorrow (axle isn稚 broken) I知 just checking everything out and greasing
everything good. I値l try those things!
Demon_Powersports likes this.
post #7 of 13 Old August 19th, 2019, 06:05 PM
TennesseeRZR's Avatar
First Name: Pete
My RZR: 2011 800 RZR LE, 2014 Black Pearl XP 1K
Member #28240
View TennesseeRZR's Photo Gallery(0)
Use lots of PB blaster and one of these?....................https://www.amazon.com/OTC-Inner-CV-...79548009&psc=1
Max H and Fastone110 like this.
TennesseeRZR is offline
post #8 of 13 Old August 19th, 2019, 06:59 PM Thread Starter
AustonsRZR's Avatar
First Name: Shawn K
My RZR: XP4 1000
Member #69850
I will have to find me one of those tools, cause I have tried the pry bar and vise grips but no luck yet! I might try removing right axle though cause right now unit is up in the air on my hoist and the weight of tire, suspension, etc is on the right axle wondering if things are cocked a bit and it won稚 come out! Thanks guys!!
post #9 of 13 Old August 19th, 2019, 08:02 PM
AFGVET42's Avatar
Member #178713
View AFGVET42's Photo Gallery(0)
I used a 3 inch exhaust clamp and welded chain to each side and a slide hammer. Bunch of YouTube videos on how to.
AFGVET42 is offline
post #10 of 13 Old August 23rd, 2019, 06:59 PM Thread Starter
AustonsRZR's Avatar
First Name: Shawn K
My RZR: XP4 1000
Member #69850
OMG still won稚 come out!!
So if I pull L/H axle I should be able to hammer on it?
post #11 of 13 Old August 23rd, 2019, 07:07 PM
First Name: Pete
Member #28240
It seems to be the quick snap with the slide hammer is what is most effective. Sorta give it slack then snap it.
post #12 of 13 Old August 23rd, 2019, 08:49 PM Thread Starter
AustonsRZR's Avatar
First Name: Shawn K
My RZR: XP4 1000
Member #69850
I’ll go at it again tomorrow!! Tried pulling L/H
And it’s the same thing!!
post #13 of 13 Old August 24th, 2019, 10:44 AM
AFGVET42's Avatar
Member #178713
Make sure you load up the new axles with anti seize.
AFGVET42 is offline
