Bigger tires without a new clutch? - Polaris RZR Forum - RZR Forums.net
 13Likes
post #1 of 17 Old January 17th, 2018, 10:19 AM Thread Starter
xpmattyb's Avatar
First Name: Matt
My RZR: 2017 XP 1000 4
Member #231473
View xpmattyb's Photo Gallery(0)
Usa Bigger tires without a new clutch?
Looking at moving to 30's on the 2017 xp4. Do I need to upgrade the clutch? What's the biggest tire I could do without a clutch upgrade? Any recommended rock crawlers?
xpmattyb is offline
post #2 of 17 Old January 17th, 2018, 10:49 AM
GimpyRZR's Avatar
Member #208177
View GimpyRZR's Photo Gallery(0)
Re: Bigger tires without a new clutch?
it'll be fine. make sure you research the tire you chose, not all run true to the size. some 30's can actually be smaller/or same size as the 29" big horns. For example, the 30" pro armor crawlers on the gold edition are pretty close in size to the 29" big horns. Or another example, I just got some 32" tusk terrabites that run about 30.5" mounted, whereas my 32" roctanes are about 32.5.
xpmattyb likes this.
GimpyRZR is offline
post #3 of 17 Old January 17th, 2018, 11:36 AM
Discount Tire's Avatar
Member #22031
Feedback Score: 4 reviews
View Discount Tire's Photo Gallery(0)
Going to a 30/10R-14 tire size is very common. Just pay attention to be in low when you need to be to not overtax your belt. This is no different than you should be doing now, plus it's only an inch larger than stock.
dartersracing and xpmattyb like this.
Low Prices! More Choices! Trusted Experts!
At The Store: discounttire.com
To Your Door: discounttiredirect.com
Discount Tire is offline
post #4 of 17 Old January 17th, 2018, 03:33 PM
Dirtracer9's Avatar
Member #221345
View Dirtracer9's Photo Gallery(0)
We have a 2017 xp4 1000 with 30íinch rocktanes. Machine has 130 miles on it and already burnt 2 belts. These machines have extra weight and the transmission gearing isnít low enough. Just installed a gear reduction to mine but havenít went on a ride yet.
Dirtracer9 is offline
post #5 of 17 Old January 17th, 2018, 05:15 PM
WORKINGONJUNK's Avatar
My RZR: RZR41000
Member #77008
View WORKINGONJUNK's Photo Gallery(0)
Originally Posted by Dirtracer9 View Post
We have a 2017 xp4 1000 with 30’inch rocktanes. Machine has 130 miles on it and already burnt 2 belts. These machines have extra weight and the transmission gearing isn’t low enough. Just installed a gear reduction to mine but haven’t went on a ride yet.
If you are using low gear most the time , something is up man 130 miles & 2 belts is a little much. Only time I have burnt a belt is in the sand pushing it a little to much.... ( we ride a tad aggressive in the sand )
To the OP, I ran 30's on my 2014 for years with no clutch upgrade with no issues , other than the sand .... LOL
Waynoroy and xpmattyb like this.
WORKINGONJUNK is offline
post #6 of 17 Old January 17th, 2018, 05:30 PM
Dirtracer9's Avatar
Member #221345
We ride very rough mountains most of the time and the new transmission gears arenít made for rock crawling. Spoke to several people about my issue one being Todd at hunterworks and he explained to me that the new machine in low is like starting off in 3rd gear. And rock crawling that doesnít work. Running 50+ over dunes I? can see where you wouldnít have a problem
post #7 of 17 Old January 17th, 2018, 07:44 PM
Metki's Avatar
Member #164697
View Metki's Photo Gallery(0)
Rocktanes are super heavy also
MNawman likes this.
Metki is offline
post #8 of 17 Old January 17th, 2018, 08:31 PM
Xfire's Avatar
Member #51143
View Xfire's Photo Gallery(0)
I think the weight of the tire you choose will play heavily into how much you need a clutch. Pun intended. Some tires are very heavy. Manufactures seem to have moon scales also.
2016 XP 4 1000
Xfire is offline
post #9 of 17 Old January 17th, 2018, 08:35 PM
BLOODY BILL's Avatar
First Name: CHRIS
My RZR: 2016 xp1000 eps
Member #22587
Feedback Score: 16 reviews
Colorado Re: Bigger tires without a new clutch?
you might check out maxxis carnivores 8ply and one of the lighter tires out there these are good for crawling too
really though with the oem clutch
you seriously might consider at least a clutch up grade you should talk to hunterworks todd
Hunterworks, xpmattyb and Copcoman like this.
BLOODY BILL is offline
post #10 of 17 Old January 18th, 2018, 04:43 AM
Hunterworks's Avatar
First Name: Todd
Member #47437
Feedback Score: 8 reviews
Need and want is two different things and for sure swap out the square pucks in the secondary to round rollers no matter what you do.
Polaris RZR XP 1000 900, Polaris Ranger 800 - 16-18 Secondary Roller Kit
People ask me everyday if they need a clutch kit because they changed tires etc. The answer is not black and white.
Almost everyone benefits from a properly calibrated clutch, about the only person who does need one is a guy who simply eases around 20-30 mph like he is on a Sunday afternoon cruise. There are a few people who do this and no matter what tires etc they do, I can't see them needing to do anything.
Everyone else no matter what will benefit but you need to realize that there is no one clutch set up that does everything, so you can't rock crawl and dune with the same clutch set up, it simply does not work like that. You also need to know that depending on what you are doing your butt dyno may not notice the change. A slow rider that has set his clutch up for that can't feel it, he just is not slipping his belt. The performance oriented driver knows it for sure.
Clutch tuning for performance is important to faster moving people who mash the go pedal to the floor because you need the clutch to get in the right RPM range to propel you as quick as you can. Slow riders like a rock crawler or technical riders simply should not be concerned about what shift RPM is and say if it was 8400 rpm why are you concerned about that? You are never there and you are using low range anyway.
With all this being said the point I am trying to make is, depending on what you are doing as to how you set your clutch up and you need to know that what you set it up for is what it will do best and it will suffer at other activities. There is no such thing as a clutch set up or calibration that works everywhere well, all will do one thing better than another.
Most people ride their RZR in the manner it was created for which is faster trail riding on and off the throttle and the instructions in the clutch kit we sell is written for you and it covers duners as well, just no mention of slow technical riding. I can help the slow riders with theirs via the phone.
www.hunterworks.com
Todd
Office phone: 601-771-0070
Hunterworks is offline
post #11 of 17 Old January 18th, 2018, 06:08 AM
GimpyRZR's Avatar
Member #208177
2 belts in 130 miles makes me think you maybe aren't breaking the belt in properly?
GimpyRZR is offline
post #12 of 17 Old January 19th, 2018, 03:15 PM
My RZR: RZR41000
Member #77008
Sorry Todd , I didn't get past this in the post.... LOL !
post #13 of 17 Old January 20th, 2018, 07:02 AM
First Name: Todd
Member #47437
Unless your foot uses that go pedal you can't feel the 110 hp either!!! LOL
Just because you can't feel it does not mean it is not doing positive things for you
www.hunterworks.com
Todd
post #14 of 17 Old January 25th, 2018, 06:18 PM
Gary Jones's Avatar
My RZR: 1000 4
Member #222562
View Gary Jones's Photo Gallery(0)
30in gbc's so far so good!!! Been 800 miles! Same belt!
Gary Jones is offline
post #15 of 17 Old January 25th, 2018, 06:19 PM
Granite Guru
CrawlerJamie's Avatar
First Name: Jamie
Member #131777
View CrawlerJamie's Photo Gallery(3)
Stock clutch original belt 32s. Works fine for me
CrawlerJamie is offline
900 Trail new tires.... new clutch and belt? TinnyRZR RZR 900 - 50'' Trail Models 3 October 29th, 2017 08:00 PM
Expectations of a Clutch kit Article Hunterworks Hunterworks 5 October 20th, 2017 05:10 AM
Clutch kit to run larger tires? Motoman314 RZR XP 900 15 August 7th, 2017 04:40 AM
28x10-14 tires, potential clutch problems? Yardgoat RZR XP 900 H.O. Jagged X Edition 2 June 26th, 2017 05:06 AM
Clutch covers for xp1000? Bigger shocks zachadams55 General RZR Discussion 0 April 26th, 2016 04:40 PM
