Cat removal, fuel controller? - Polaris RZR Forum - RZR Forums.net
 10Likes
LinkBack Thread Tools
Old July 20th, 2017, 01:16 PM Thread Starter
Jeddy's Avatar
First Name: Jed
My RZR: 2015 XP4 1K
Member #52601
View Jeddy's Photo Gallery(0)
My cat is getting very hot on my 2015 XP4. Much, much hotter than I'd like to see. Thinking about removing it by cutting a weld, gut, and weld back together.
I've searched quite a bit, but can't find a straight answer on if I will need a fuel controller after the delete. I'd like to add a turbo in a year or two, so it wouldn't bother me to buy a fuel controller now (obviously one that can handle boost). We tend to ride pretty hard in the dunes, so I'm concerned about running too lean and cooking the engine. I have a Boondocker Ripp Tied clutch, but otherwise pretty stock. Any thoughts are appreciated
Jeddy is offline
Old July 20th, 2017, 01:25 PM
2015 XP 1K
Oilcan's Avatar
My RZR: 2015 XP1K
Member #66512
View Oilcan's Photo Gallery(0)
Re: Cat removal, fuel controller?
sub'd
Only in Canada... Eh !
Oilcan is offline
Old July 20th, 2017, 01:56 PM
familywagon's Avatar
First Name: Jonathan
My RZR: 2015 xp4 Z1 fire breathing duner
Member #47967
View familywagon's Photo Gallery(0)
I have cut several stock mufflers and removed some have had controller and some without, it didnt seem to harm them without a controller and they run glamis pretty hard also. i even have a couple mufflers already done that the guys removed for a full exhaust
familywagon is offline
Old July 21st, 2017, 08:08 AM Thread Starter
Jeddy's Avatar
First Name: Jed
My RZR: 2015 XP4 1K
Member #52601
familywagon, thanks! That's the type of response I'm looking for. I think I'll do some cutting this weekend...
Jeddy is offline
Old July 21st, 2017, 08:15 AM
The Lone Rzr
185EZ's Avatar
My RZR: 2017 1KXP4
Member #89257
View 185EZ's Photo Gallery(0)
I gutted my cat and O2 still connected.
I don't have any scientific proof but it seems to run cooler and even takes awhile to heat up to operating temp even in 100*+ temps.
10 miles of riding and idling for a few minutes the fan finally came on.
185EZ is offline
Old July 29th, 2017, 07:53 AM
Xfire's Avatar
Member #51143
View Xfire's Photo Gallery(0)
I did mine. No issues. I did just add a tune. No time on it yet. Tonight will be first good ride with tune.
2016 XP 4 1000
Xfire is offline
Old September 7th, 2017, 06:49 AM Thread Starter
Jeddy's Avatar
First Name: Jed
My RZR: 2015 XP4 1K
Member #52601
So as a follow up, I did cut out my cat and welded it back together. The muffler case had noticeable hot spots on it, and I have no doubt that a couple more aggressive rides at the dunes would have burnt through the muffler. It's slightly louder, but not enough that I could even tell if someone else's cat was cut or not. I've given it a few runs around my property with good results, no dunes trips planned until October. I'll try and report back then.
Overall, I'd strongly recommend it.
Jeddy is offline
Old September 7th, 2017, 10:26 AM
RZRWorks's Avatar
First Name: Carl
My RZR: 2016 XP1K
Member #132361
View RZRWorks's Photo Gallery(0)
RZRWorks is online now
Old September 7th, 2017, 11:32 AM
bagman's Avatar
My RZR: 2015 1K Havasu Red
Member #649
If you're worried about you might think about adding a fuel/air meter to be sure. If you do add the turbo down the road it will be good for that too.
bagman is offline
Old September 7th, 2017, 05:22 PM
The Lone Rzr
185EZ's Avatar
My RZR: 2017 1KXP4
Member #89257
My follow up after gutting my cat is over 200 miles and no problems
No codes
No noticeable difference in decibels.
Has a better sound to it
qdttracer9 and RZRWorks like this.
185EZ is offline
Old September 7th, 2017, 09:59 PM
44newman's Avatar
My RZR: 16 XP4 1000
Member #148873
View 44newman's Photo Gallery(0)
Did you guys take any pics of the muffler cutting?
44newman is offline
Old September 8th, 2017, 05:26 AM
The Lone Rzr
185EZ's Avatar
My RZR: 2017 1KXP4
Member #89257
If you're good with a grinder you shouldn't have to cut anything.
The elbow is inserted into the muffler and comes right out when weld is removed.
You can see @.56 where you need to grind the weld and remove the elbow.
RZRWorks and CodyKneifl22 like this.
185EZ is offline
Old September 8th, 2017, 05:57 AM
RZRWorks's Avatar
First Name: Carl
My RZR: 2016 XP1K
Member #132361
Very nice 185EZ, we all appreciate this
11XPherlicane and 185EZ like this.
Old September 8th, 2017, 06:39 AM Thread Starter
Jeddy's Avatar
First Name: Jed
My RZR: 2015 XP4 1K
Member #52601
Mine had two layers of pipe at the cat. I assume when they make the mufflers the cat is in it's own piece of tubing. I assume they slip it into the muffler then position the elbow over it, then the big ugly weld goes over all of it. I was able to cut thru a single, outside layer of the pipe right at the weld with a cutoff wheel on a grinder. This left me an easy way to reattach the pipe. Don't worry about trying to make it look nice
The cat was a total pain to remove. I figured a hole saw was the way to go, it wasn't. I ended up splitting the muffler lengthwise for a few inches and chiseling out the cat. Just welded the seam back up when rewelding the elbow back on.
Also, not sure if it's a problem or not, but I'd rec'd anyone welding it back together to disconnect their battery. Don't want to damage any electronics
Jeddy is offline
Old September 8th, 2017, 07:34 AM
The Lone Rzr
185EZ's Avatar
My RZR: 2017 1KXP4
Member #89257
Jeddy, you did it all without removing the muffler?
The cat is tough as nails and I recommend drilling as many holes as possible for smaller pieces.
I had one piece a bit too large and had a hard time getting it out.
Once you get around to the outside of the cat it comes out pretty easy.
I had a lot of tiny pieces and wanted to make sure everything was cleaned out so I did a lot of shaking and blowing out with compressed air.
185EZ is offline
Xp1000 fuel pump removal help Thexjguy RZR XP 1000 3 October 10th, 2018 03:55 AM
MCX Fuel controller issue boosted2g RZR Turbo Engine 2 June 5th, 2017 11:39 AM
Fuel Controller or ECU Reflash RZR Rocks RZR 570 Specific Discussion 5 February 8th, 2017 11:05 AM
Fuel Controller or ECU Tune?? notenufftoys RZR 1000 Engine 19 May 27th, 2016 10:30 AM
Alba fuel controller and Alba intake set up new UNI/outerwares 2011redxp Polaris RZR Parts For Sale 10 February 25th, 2016 03:26 PM
