2017 XP TURBO 4 DRIVE CLUTCH HORRID NOISE - Polaris RZR Forum - RZR Forums.net
post #1 of 6 Old May 28th, 2017, 12:47 PM Thread Starter
Method Rzr Wheels's Avatar
Member #200473
View Method Rzr Wheels's Photo Gallery(0)
Have 2017 turbo XP 4 100 hours has horrid metal scraping noise from behind drive clutch assembly when idle any help would be appreciated.
Method Rzr Wheels is offline
post #2 of 6 Old May 28th, 2017, 01:07 PM
Clubin's Avatar
First Name: Clayton
My RZR: XPT
Member #61303
Re: 2017 XP TURBO 4 DRIVE CLUTCH HORRID NOISE
Take the clutch cover off and inspect it. Without seeing pictures. It's impossible to know.
2016 XPT
EVO stage 2
EVO captains choice exhaust
EVO charge tube
OSP clutch kit
Rockford Fosgate Stage 4
STI HD5's 31/10.50/15 Super Swamper IROC'S
Clubin is offline
post #3 of 6 Old May 28th, 2017, 01:12 PM Thread Starter
Member #200473
I'm in process of getting proper tool to remove by this afternoon. When I turn it by hand there's is something dragging on the edge of plate inside.
post #4 of 6 Old May 28th, 2017, 01:26 PM
Clubin's Avatar
First Name: Clayton
My RZR: XPT
Member #61303
Damn. Maybe the same problem as the 16's. The bolts back out behind the primary!!? Nothing physically looked munched?
2016 XPT
EVO stage 2
EVO charge tube
OSP clutch kit
Clubin is offline
post #5 of 6 Old May 28th, 2017, 01:42 PM Thread Starter
Member #200473
No metal but there is A fine Gray Dust Present , Soon as I heard the noise I loaded on trailer. It happened yesterday after I hard ride in the desert of Mojva, ca.
post #6 of 6 Old May 28th, 2017, 03:46 PM
glamisfan's Avatar
First Name: Steve
My RZR: XP Turbo
Member #21731
View glamisfan's Photo Gallery(0)
Sounds like the bolts behind the primary. I would take it to the dealer and have them fix it under warranty. Good chance you'll need a new primary if the fins behind it are chewed up a little bit.
glamisfan is offline
2016 XPT to 2017 XPT Primary and Secondary Clutch Conversion jcandrew RZR XP 4 Turbo 2 March 13th, 2017 03:51 PM
Branden Sims wins Baja 1000 / Dalton turbo clutch kit helix Dalton Industries 0 December 9th, 2016 10:26 AM
Best clutch kit for 2017 Turbo with stage two? jcweiss28 RZR XP Turbo 4 December 5th, 2016 05:22 AM
BMP XP Turbo Magnetic Adjustable Clutch Weights In Stock Bikeman Performance Bikeman Performance 4 September 28th, 2016 02:20 PM
xp1000 turbo clutch covers on xp 1000? armageddon1 RZR 1000 Engine 4 January 2nd, 2016 06:24 AM
