bad primary after 200 miles - Polaris RZR Forum - RZR Forums.net
 2Likes
  • 2 Post By PaulK
post #1 of 12 Old May 9th, 2017, 06:51 PM Thread Starter
IdahorzrXP4's Avatar
Member #182066
View IdahorzrXP4's Photo Gallery(0)
I bought a 17 XP1K4 back in January and have put 197 miles on it since. I tried to do a high speed run in it last weekend and could only get 55mph, so I decided to pull the clutch cover. I discovered pretty bad grooving on the fixed sheave only. what could have caused this? Could it have been something in the way I drove it? Do you think it could still be under the factory 6 month warranty? I'm pretty new to Rzrs and this is the first time I've dug into a clutch.
Name:	Photo May 09, 4 49 01 PM.jpg
ID:	421809   Click image for larger version
Name:	Photo May 09, 4 50 31 PM.jpg
IdahorzrXP4 is offline
post #2 of 12 Old May 9th, 2017, 07:05 PM
acomic's Avatar
Member #76164
View acomic's Photo Gallery(0)
Re: bad primary after 200 miles
I have a 2015 xp1k4. Secondary went out at 1500 miles. Primary got a freshen up but is still in great shape. Sounds really weird that yours would be gone by the 200 mark. I'd check on that warranty for sure. Also make sure factory or otherwise whoever does your work... check the primary & secondary.
acomic is offline
post #3 of 12 Old May 9th, 2017, 07:22 PM
PaulK's Avatar
First Name: Paul
My RZR: 17 XP Turbo
Member #34432
View PaulK's Photo Gallery(2)
Looks like it was hot then got wet
DoinIt and Hunterworks like this.
PaulK is offline
post #4 of 12 Old May 10th, 2017, 04:37 AM
Hunterworks's Avatar
First Name: Todd
Member #47437
Feedback Score: 8 reviews
Normally just two things cause that water in there or spider nut and spider backed off causing the belt to slip and do that.
I see rust on the pivot pins and weights so water has been in there.
Doubt warranty covers it, maybe you will get lucky
Todd
www.hunterworks.com
Todd
Office phone: 601-771-0070
Hunterworks is offline
post #5 of 12 Old May 10th, 2017, 05:29 AM Thread Starter
Member #182066
How hot would it have to get to cause that? Would getting it wet at normal operating temp cause this? Also, wouldn't you see it on both sheaves if it were due to getting hot and wet? The movable sheave is undamaged.
post #6 of 12 Old May 10th, 2017, 05:35 AM
cwarner's Avatar
First Name: Chuck
My RZR: 2016 XP 1000
Member #4015
View cwarner's Photo Gallery(0)
I've seen more than one person post up their primary being like this or worse. My question is , how did you not know there was an issue ? I bought a '16 XP at the end of last year which has the worst clutching on it from the factory so bad that in a few rides I went thru two belts and was able to tell exactly when the clutch was slipping. Usually you could smell it, or feel it and I would lift on the throttle. Are you guys just holding it WFO regardless of how it feels ? Not trying to start anything but just curious.
I just pulled my clutches to do an alignment and clutch kit and there was zero damage to them.
cwarner is offline
post #7 of 12 Old May 10th, 2017, 06:24 AM
First Name: Todd
Member #47437
Can't explain why it does it on one side not other just does
www.hunterworks.com
Todd
post #8 of 12 Old May 10th, 2017, 06:42 AM
DoinIt's Avatar
First Name: Todd
My RZR: 2016 XP1K4 Electric Blue
Member #43515
View DoinIt's Photo Gallery(0)
That looks really bad for 200 miles. Good luck getting Polaris to replace it under warranty.
DoinIt is offline
post #9 of 12 Old May 10th, 2017, 06:48 AM
First Name: Todd
Member #47437
I been wondering too how these clutches get this far, I would think you could tell but I have not had it happen to me so I don't know.
www.hunterworks.com
Todd
post #10 of 12 Old May 10th, 2017, 06:59 AM Thread Starter
Member #182066
I haven't ridden it but 4 miles down the paved road since I took it out last, but I didn't feel anything weird. We did ride through a creek the last time I had it out, but it wasn't deep. I was also right next to the pickup and it was at the end of the ride, so no miles put on afterwards. No way that it could have been above normal operating temp at the time I went through the creek. Again, this is my first rzr so I may not know what I'm feeling either. No sounds or hesitation that i noticed. I took these pictures to the dealer yesterday so I should find out today what the verdict is on the warranty coverage.
Thanks for replies.
Shaun
post #11 of 12 Old May 10th, 2017, 10:22 AM
PaulK's Avatar
First Name: Paul
My RZR: 17 XP Turbo
Member #34432
Did you ever drive it in the snow,, these clutches will suck in powder and turn it to water,, high rpm snow riding could contribute also
looks like lots of oxidation on the aluminum in the pics also
PaulK is offline
post #12 of 12 Old May 10th, 2017, 11:17 AM Thread Starter
Member #182066
We ride in the mountains in norther Idaho and we've had a snow-heavy winter this year. Every trip out this year has been in the snow at some capacity, and this machine is going to see this regularly. Whats best way to prevent this in the future? Snorkel? Aftermarket clutch? I ride with a lot of other Polaris machines and have not seen anything like this before.
2016 rzr 570 primary in pieces? Wazntme Engine and Drivetrain 12 March 1st, 2017 08:38 PM
2016 Baja 1000 Shock Therapy Pre Run Report Shock Therapist General RZR Discussion 4 January 15th, 2017 07:26 PM
2016 Baja 1000 Shock Therapy Pre Run Report Shock Therapist Shock Therapy 1 January 9th, 2017 03:31 PM
2010 Porsche Panamera 4S in TN w/WARRANTY & low miles!!! JGlover Misc For Sale 2 June 22nd, 2016 08:48 AM
Primary clutch toast SM6666 RZR XP Turbo 6 December 7th, 2015 02:59 PM
