Whats considered high milage on a XP1000 - Polaris RZR Forum - RZR Forums.net
 11Likes
post #1 of 19 Old September 30th, 2019, 03:30 PM Thread Starter
az erik's Avatar
My RZR: Shopping for s, xp
Member #273256
View az erik's Photo Gallery(0)
Arizona Flag Whats considered high milage on a XP1000
Poking around in the used sales locally and it seems like everyone here is 4K+ in miles. 2014 through 2017. All virtually the same price, $12k. Which to me seems high but they're modded, usually. I'm curious if RZRs have the "didn't use enough, or used it way too much" adage.
What's you alls feelings on the amount of miles per year is acceptable.
I'm trying to figure out also about how many miles is reasonable (to that people have been getting out of a motor) to believe you'd be rebuilding the top end.
BTW I saw a XP800 listed the other day with 16,000 on it for $6k to give you an idea of what we seem to have here lol
az erik is offline
post #2 of 19 Old September 30th, 2019, 03:55 PM
sand shark's Avatar
First Name: Noel
My RZR: XP1000
Member #23358
View sand shark's Photo Gallery(0)
Re: Whats considered high milage on a XP1000
I sold my 2014 XP1000 with 5500 miles on it almost 2 years ago. If it is well take care of the mileage is no big deal.
sand shark is online now
post #3 of 19 Old September 30th, 2019, 04:58 PM
ShredTheLedge
Jamison Raymond's Avatar
My RZR: 18 XP 1000 TRE
Member #223282
View Jamison Raymond's Photo Gallery(0)
What part of the country is “local” to you? What kind of trails, mud, rock, fire roads ect?
I’ll surpass 2000 miles after this years season is over.
Jamison Raymond is offline
post #4 of 19 Old September 30th, 2019, 06:01 PM Thread Starter
az erik's Avatar
Member #273256
Southwest. Dunes, desert, forest. And in Scottsdale.. cruising to Whole Foods
Wheel likes this.
az erik is offline
post #5 of 19 Old September 30th, 2019, 06:04 PM
sand shark's Avatar
First Name: Noel
My RZR: XP1000
Member #23358
I would ask the person in detail about the maintenance on the XP1000 you are interested in. The only concern would be the bearings in the transmission and clutch wear. If the clutches have been replaced you are good there.
The motors are good for a lot of miles.
Wheel likes this.
post #6 of 19 Old October 2nd, 2019, 02:20 AM
Hartman's Avatar
My RZR: 2017 XP 1000 EPS
Member #116577
View Hartman's Photo Gallery(0)
Being a four stroke motor it shoiud last a long time if someone takes care of it and doesn't beat on it every ride. Look how long a quad motor lasts or motorcycle. The big but is.......but it all depends on where it was driven. If its whole life was in the sand with poor filter clean it could hsve a much shorter life. Same applies if it was a mudder machine and spent most of its life with the motor in the water compared to a woodland trail machine so there is no real answer......too many variables but I could pick out an abused and beat up machine a mile away. Just look for rust or heavy mud stuck in nooks and crannies.
Hartman is offline
post #7 of 19 Old October 2nd, 2019, 07:28 AM
ljheptig's Avatar
First Name: Larry
My RZR: 2015 XP1000 Voodoo Blue
Member #12879
View ljheptig's Photo Gallery(0)
My 2015 XP1000 has 8500 plus miles.
Still looks and runs great, have always changed oil and filters at regular intervals or after every week long trip,
Replaced the tranny and secondary clutch at 8100, Primary clutch at 6000, wheel bearings as needed, carrier bearing and prop shafts at 4000, brake pads at 6000, replaced front diff at 3500, O2 sensor at 8500. We ride a lot of challenging stuff at Moab, UT, Taylor Park & Silverton, CO, Mulberry Mountain, AR, Lake Pleasant, AZ, and a few easy rides near home.
TOD likes this.
ljheptig
ljheptig is offline
post #8 of 19 Old October 2nd, 2019, 10:06 AM
load97's Avatar
My RZR: 2019 XP 1000 Dynamix
Member #44070
View load97's Photo Gallery(0)
Hard to get a consensus on it. I wouldn't buy one with more than 1000-1500 miles on it. For me, 4000-6000 miles is up there. Clutches, trans, and the effing wheel bearings I'm always hearing about go out.
If I didn't have to think about clutches or at least the trans and bearings so soon I wouldn't consider 4000-6000 miles to be high. But since those things typically go out I do. My Jeep can go a lot longer before a wheel bearing fails (probably not in mud as much as some RZR's) or a clutch goes to shit. Hope Polaris gets away from the belts and does the CVT or something else.
FRAZR likes this.
2019 RZR XP 1000 Dynamix Edition
load97 is offline
post #9 of 19 Old October 2nd, 2019, 04:15 PM
FRAZR's Avatar
My RZR: XPT4 Velocity
Member #82174
View FRAZR's Photo Gallery(0)
The big thing to keep in mind is with more mile equals more maintenance. If the previous owner hasn't replaced wear items you will and it could get expensive.
FRAZR is offline
post #10 of 19 Old October 2nd, 2019, 09:39 PM
grantndozzer01's Avatar
Member #81703
View grantndozzer01's Photo Gallery(0)
Constant maintenance on my 2015 with 8000 miles. Replaced primary clutch at 7000 miles. Transmission lost a bearing at 2500 miles, new one put in under warranty. Agree with others, maintenance is key. Fluids sitting in a low milage rzr for 3 years can cause more issues then a higher milage maintained rzr.
DogRunner2 likes this.
grantndozzer01 is offline
post #11 of 19 Old October 3rd, 2019, 06:38 AM
oldnslow's Avatar
First Name: Phil
Member #167137
View oldnslow's Photo Gallery(0)
My 2017 1000 xp has 3500 mountain trail miles on it. Lots of water crossings, not much mud. Machine has been used, but not abused. So far I've had to replace 2 wheel bearings, and changed the belt so I could have a spare one. Very reliable machine. I almost traded it a couple of months ago, dealer was a little shocked at the high mileage. So I guess mileage is really relative to where you live.
It might be lonely at the top, but it's a bitch at the bottom.
oldnslow is offline
post #12 of 19 Old October 3rd, 2019, 11:26 AM
Hartman's Avatar
Member #116577
The dealer being shocked at 3,500 miles sure as hell is not a testimonial for the faith in his product line. I didn't spend $20 grand plus $5 grand of options with the expectation to have my XP disposable at 3,500 miles like a disposable Bic Razor. Geeses.....
Wheel likes this.
Hartman is offline
post #13 of 19 Old October 3rd, 2019, 06:31 PM
Roger Lee's Avatar
First Name: Roger
My RZR: 2015 1K
Member #69952
I have a 2015 Rzr 1K. Over 15K miles. yes I have replaced several worn parts and I'm easy on my equipment and perform all my preventive maint.
Wheel, TOD, 185EZ and 1 others like this.
Roger Lee is offline
post #14 of 19 Old October 3rd, 2019, 06:47 PM
The Lone Rzr
185EZ's Avatar
My RZR: 2017 1KXP4
Member #89257
View 185EZ's Photo Gallery(0)
I was hoping to hear of some high milers out there.
I just turned 2100 miles on my 2017 xp41k
Doesn't burn oil and still on original tires and that's riding a lot of asphalt
Doing a full fluid change
Not sure what it's worth but I sure hope to get double that mileage before I need to replace anything
Wheel likes this.
185EZ is online now
post #15 of 19 Old October 3rd, 2019, 09:07 PM
Berzerker
ruggbutt's Avatar
First Name: Randy
My RZR: '16 XP1k Titanium Matte
Member #72023
View ruggbutt's Photo Gallery(0)
7200 on mine. As is usual for Polaris the trans died. Extended warranty replaced that. Then the motor got dusted right after the trans replacement. I suspect the mechanics didn't seal up my airbox as well as they should have. So now it's got a new motor with lightweight aftermarket rods and valves. It's like new again!
2014 800-S, Fox White Lightning LE *SOLD*
2016 XP1K Titanium Matte
ruggbutt is offline
