2019 XP 1000 suspension squeak? - Polaris RZR Forum - RZR Forums.net
 2Likes
  • 1 Post By Max H
  • 1 Post By todztoyz
post #1 of 5 Old July 16th, 2019, 12:01 PM Thread Starter
Lamekurt's Avatar
Member #270374
View Lamekurt's Photo Gallery(0)
Been loving my new RZR so far however one thing I have noticed is there aren’t many grease fittings on suspension components. My suspension is beginning to squeak really bad which isn't abnormal to me as I usually run trails/water and mud. However I clean it off after every big run but I’d love to know what you guys do to decrease the amount of squeaking. Is WD40 recommended? Or something like white lithium grease in an aerosol can because as stated, there aren’t many grease fittings at all. Thanks guys.
Lamekurt is offline
post #2 of 5 Old July 16th, 2019, 12:13 PM
Max H's Avatar
First Name: Max
My RZR: 2018 XPT 2 seat
Member #16311
View Max H's Photo Gallery(0)
Re: 2019 XP 1000 suspension squeak?
Use good waterproof grease on the zerk points... and Tri Flow on all other points ...it is clean and wont attract a lot of dirt if you let it dry for a bit
The guys at FOX suspension recommend it ....it is Teflon based and penetrates well in Heim joints and other tight tolerance areas
RZR_Joe likes this.
Max H is offline
post #3 of 5 Old July 16th, 2019, 12:14 PM
RZR_Joe's Avatar
Member #23438
Feedback Score: 6 reviews
Do not use petroleum based products as it will attract dirt and cause premature wear. After pressure washing the shock bushings and all suspension components thoroughly I use dry silicon spray lube on all the moveable parts that no not have grease fittings. This will prevent squeaks not attract dirt.
RZR_Joe is offline
post #4 of 5 Old July 16th, 2019, 04:06 PM
topgun's Avatar
My RZR: 2019 Turbo RZR
Member #17581
The spherical balls on the ends of the shocks will squeak. I took mine apart and used a little anti seize on them. They are sealed with an O ring on each side so just spraying will probably not help.
2019 RZR Turbo Titanium
2008 Can Am Renegade 800
2018 RZR RS1 Black Pearl
2011 Can Am Outlander 650 XTP
topgun is offline
post #5 of 5 Old July 19th, 2019, 02:58 PM
todztoyz's Avatar
My RZR: 14 xp1k
Member #193809
View todztoyz's Photo Gallery(0)
Shock eyes....# 1 squeak point! Remove and lube....should last 1-2 years. I use a white lithium grease but I'm sure that's not forum correct! 😉
Sent from my SM-G950U using RZRForums.net mobile app
JPicard06 likes this.
todztoyz is offline
