14 1000 exhaust glowing red - Polaris RZR Forum - RZR Forums.net
 1Likes
post #1 of 23 Old July 9th, 2019, 10:44 AM Thread Starter
Jamesman's Avatar
Member #267804
View Jamesman's Photo Gallery(0)
My rzr got extremely hot the other day, and melted the bed right above the factory exhaust. Last night I was riding around the neighborhood, and when I got home I noticed the head of the exhaust at the manifold all the way to the muffler was glowing red hot. Any idea??
Jamesman is offline
post #2 of 23 Old July 9th, 2019, 11:46 AM
controlled force's Avatar
Member #24860
View controlled force's Photo Gallery(0)
Re: 14 1000 exhaust glowing red
Stock exhaust?
Sent from my SM-N950U using Tapatalk
controlled force is offline
post #3 of 23 Old July 9th, 2019, 01:44 PM
Michale's Avatar
My RZR: 17 XPT2
Member #218193
red hot exhaust normally means its running too lean. do you get a slight exhaust backfire when you let off the throttle?
another sign of running to lean. If you changed the exhaust to a more free flow it could cause it to run lean.
Michale is offline
post #4 of 23 Old July 9th, 2019, 02:34 PM
The Lone Rzr
185EZ's Avatar
My RZR: 2017 1KXP4
Member #89257
View 185EZ's Photo Gallery(0)
You seem to have had a plethora of problems since you purchased your rzr
Limited speed and you said timing was off and then chain broke
Are you sure you got timing marks all lined up properly?
185EZ is offline
post #5 of 23 Old July 9th, 2019, 03:35 PM
Member #24860
I've seen this happen plenty of times where the packing in the stock muffler completely plugs the spark arrester screenClick image for larger version
post #6 of 23 Old July 9th, 2019, 06:07 PM Thread Starter
Jamesman's Avatar
Member #267804
Iím positive! Could it be that my exhaust is leaking at the joint?? I donít know if it it but I used to work at a muffler shop and I know those joints can be stubborn
Jamesman is offline
post #7 of 23 Old July 9th, 2019, 06:37 PM Thread Starter
Jamesman's Avatar
Member #267804
Originally Posted by controlled force View Post
I've seen this happen plenty of times where the packing in the stock muffler completely plugs the spark arrester screenAttachment 579882
I donít have a spark arrestor??
Jamesman is offline
post #8 of 23 Old July 10th, 2019, 06:29 AM
Bikerdude101's Avatar
Member #271040
View Bikerdude101's Photo Gallery(0)
I'm having the same issue on my 2018 RS 1 . Bone stock no spark arrester installed. About 60 hours on motor. I ask this question in the RS 1 forums and have not yet gotten a response. Any idea guys ?? Thanks for your input.
old school likes this.
Bikerdude101 is offline
post #9 of 23 Old July 10th, 2019, 07:41 AM
Roger Lee's Avatar
First Name: Roger
My RZR: 2015 1K
Member #69952
They all came with one and unless you bought the Rzr second hand and someone took it out it should be held in place by the screw in the end of the tail pipe.
It is required in most states. Maybe all for all I know.
Roger Lee is offline
post #10 of 23 Old July 10th, 2019, 08:02 AM
Member #271040
Mine has been removed to see if it would help the situation, but it did not .
post #11 of 23 Old July 10th, 2019, 07:16 PM
Lastminute rex's Avatar
Member #265982
View Lastminute rex's Photo Gallery(0)
Did the 14 have a cat in the muffler? I know the 15 did. Cut the pipe near the muffler. Remover the ďhoneycombĒ looking crap and re-weld your pipe back on. Be sure to mark your pipe with a paint pen prior to cutting to ensure you weld it back exactly where it goes. Some good videos on YouTube. Good luck
Lastminute rex is online now
post #12 of 23 Old July 10th, 2019, 07:31 PM
Member #24860
No
post #13 of 23 Old July 11th, 2019, 04:02 AM
Member #271040
After removing the packing inside exhaust, will there be a lean issue because of the O2 sensor ? Thanks
post #14 of 23 Old July 11th, 2019, 08:39 AM
Michale's Avatar
My RZR: 17 XPT2
Member #218193
The 02 sensor is before the cat, not after so it wont know. But by removing the packing you now have a more free flowing exhaust. More air, less fuel=lean
Michale is offline
post #15 of 23 Old July 11th, 2019, 08:57 AM
Member #271040
I see,. So could this possibly damage the machine in anyway ? Thanks ag
