2018 XP downhill clutch noise - Polaris RZR Forum - RZR Forums.net
post #1 of 18 Old July 8th, 2019, 06:11 AM Thread Starter
ktl5005's Avatar
First Name: Keith
My RZR: 2018 1000XP Ride Command
Member #215297
View ktl5005's Photo Gallery(0)
Hi guys. 2018 XP Ride Command. Around 600 miles.
Recently last few rides on downhills, especially loose dirt or rocks, I get a “tire lock up and drag” noise from the left rear but the wheel is moving fine. Happens for less than 5 seconds and goes away. Can hear it multiple times on the same hill at certain speeds. Easily goes away by hitting the gas to speed up and hitting the brake to slow down faster. No signs of bet slip or speed or anything and I have yet to pull the cover to check things out.
Is it belt slap? Secondary not disengaging properly? Doesn’t seem to affect performance or Be causing a problem, but it sounds terrible. Lol.
ktl5005 is offline
post #2 of 18 Old July 8th, 2019, 08:18 AM
topgun's Avatar
My RZR: 2019 Turbo RZR
Member #17581
Re: 2018 XP downhill clutch noise
It's probably the sound the belt makes when engaging and disengaging based on your slow speed. You hit the gas it reengages, slow down it disengages and freewheels. I agree that it sounds terrible. If you use low range, it will lower the speed at which this happens. A clutch kit can change this as well but best to talk to someone like Hunterworks.
2019 RZR Turbo Titanium
2008 Can Am Renegade 800
2018 RZR RS1 Black Pearl
2011 Can Am Outlander 650 XTP
topgun is offline
post #3 of 18 Old July 13th, 2019, 04:41 PM
Gold Nugget's Avatar
First Name: Robert
My RZR: 2017 Gold Matte T&R
Member #238362
View Gold Nugget's Photo Gallery(0)
This was happening to me also. I was use to my CanAm that had engine braking and would almost stop on downhills. When I first got my RZR T&R if freaked me out going down the same steep hills. I would do exactly what you do...add a little throttle and brake at the same time.
Now I keep it in 4wd and low gear and no longer have issues. Hope it helps.
19Woody19
Gold Nugget is offline
post #4 of 18 Old July 19th, 2019, 05:26 PM
gfmgp's Avatar
First Name: Gary
My RZR: 2017 XP 1000
Member #50487
View gfmgp's Photo Gallery(0)
My 2017 XP1000 did this with the stock OEM belt. I put a Hunterworks HD belt on and the noise went away. It would sound like the back tires were sliding in gravel when I hit certain spots going down hills.
gfmgp is offline
post #5 of 18 Old August 14th, 2019, 05:04 PM
patrick113z's Avatar
Member #271836
View patrick113z's Photo Gallery(0)
my 2019 xp 1000 does the same thing. Its annoying and embarrassing when everyone turns and looks at you. Mine does it every time i coast to a stop. sounds like the tire is dragging. ive had it back to the dealer three different times and they adjust the clutch and a few other thing the Polaris engineers tell them. I need all the ideas you can give me to get this fixed before i go back to can am
patrick113z is offline
post #6 of 18 Old August 14th, 2019, 07:05 PM
sandblster's Avatar
Member #46247
Could the belt be hitting the case? Look at the top by the exhaust air vent. Things are tight inside the clutch area. Would be worth an inspection. Have not heard that noise on mine. I have smoked a couple of belts. Totally OP error. Could you have smoked a belt? It leaves a flat spot on belt that could be causing all kinds of weird noise.
sandblster is offline
post #7 of 18 Old August 14th, 2019, 09:51 PM
Hartman's Avatar
My RZR: 2017 XP 1000 EPS
Member #116577
View Hartman's Photo Gallery(0)
Change your flat pucks to Hunter Works rollers.
Hartman is offline
post #8 of 18 Old August 15th, 2019, 06:18 AM
sandblster's Avatar
Member #46247
Yes if this is a non turbo. At 600 miles you will probably need to replace the secondary as the punks destroy things quick. If the metal is worn in the puck area, do your self a big favor and replace the secondary now. Hunterworks sells a replacement with their rollers installed.
post #9 of 18 Old August 15th, 2019, 07:08 AM
Fastone110's Avatar
First Name: Travis
My RZR: 2016 1000s
Member #31197
Just installed Hunterworks secondary after 3400 miles.
Note the puck area wear.
Sent from my SM-G930V using Tapatalk
Fastone110 is offline
post #10 of 18 Old August 15th, 2019, 07:29 AM
SNWMBL's Avatar
First Name: Caleb
Member #207521
Yes if this is a non turbo. At 600 miles you will probably need to replace the primary as the punks destroy things quick. If the metal is worn in the puck area, do your self a big favor and replace the primary now. Hunterworks sells a replacement with their rollers installed.
The pucks are in the driven(secondary) clutch.
2017 RZR XP4 1000
Alaska UTV Fab LLC
Instagram: alaska_utv_fab
FOR SALE
- Hunterworks secondary rollers, set of 2, $35 shipped
- Sinister Fabrication A pillar bungs, set of 2, $45 shipped
SNWMBL is offline
post #11 of 18 Old August 15th, 2019, 07:37 AM
sandblster's Avatar
Member #46247
Corrected the post. Too big of a hurry.
post #12 of 18 Old August 15th, 2019, 07:44 AM
RZRCrawlin's Avatar
My RZR: 2017 RZR XP4T
Member #17965
View RZRCrawlin's Photo Gallery(0)
I'm not sure if what you described is what was happening for me, but here's my take. I have a 2017 XP4T. I have about 1,800 miles on it. For the past couple of months when I was engine braking down declines, the engine brake would "slip out" and it would make terrible sounds. I'd stop, let the revs go down, take off again, and it would be fine.
I took off the secondary clutch (driven) and took it apart to inspect. Just to be on the safe side, I replaced the sliders and the buttons, which were showing wear since my last replacement at 750 miles. Then I inspected the helix. The top of the ramp on the helix was severely worn. Because I heard they made more of a straight cut on the '18 helix, I replaced the '17 helix with an '18 helix because it would likely have better wear characteristics.
Took it out and it ran like a champ. Solid engine braking engagement. Solid performance through all conditions.
Not sure if that helps you or not. But, that was my experience.
Let me know if you're heading to Sand Hollow to rock crawl!
RZRCrawlin is offline
post #13 of 18 Old August 17th, 2019, 02:15 PM
Easy-E's Avatar
My RZR: 2017 RZR XP 1000 Ride Command
Member #68353
View Easy-E's Photo Gallery(0)
Happened to me as well, belt disengaging and making contact with the clutch cover... Stopped when I replaced my belt but came back after about 750 miles. I have replaced my belt again and stopped it but likely going to need to align the clutches with the tool from hunterworks... just putting of making the purchase. My clutch cover has a pretty good wear mark in it now, too many more rubs and the belt will go through.
2017 RZR XP 1000 Ride Command edition. EMP rear view mirror, UTV giant roof, UTV giant lower doors.
Easy-E is offline
post #14 of 18 Old August 17th, 2019, 03:18 PM
sandblster's Avatar
Member #46247
Yes on alignment. Had same problem on belt hitting top. Would tear top of belt off. All stopped with alignment.
post #15 of 18 Old August 17th, 2019, 04:28 PM
bbyers's Avatar
First Name: Brian
My RZR: 2017 XPT4
Member #175225
View bbyers's Photo Gallery(0)
does it sound like this, i had some weird noise from mine when going downhill before i switched to airdam.
the video is from a turbo so it might not help you, but the noise i was hearing was normal according to polaris
https://www.rzrforums.net/rzr-xp-4-t...ease-help.html
-2017 XPT4-Polaris roof, sliders, trailing arm guards, half windshield, front winch bumper & rear mesh screen, Warn 4500 winch, Ride Command w/rear camara, Razorback 3.0, Evo charge tube, intake tube & Bov, Dyno jet JUNK power vison((ITS HAD BLUE SCREEN OF DEATH FOR OVER A YEAR. ZERO HELP FROM DYNOJET!))w/AA stage 3 tune, Empire exhaust w/quite cores, NRP gated shifter, NRP radius rods, 32" curved led light bar, lower door inserts, PRP door bags, R2C filter. AIRDAM CLUTCHES Best purchase so far!
bbyers is offline
