Clean those frog skins!! - Polaris RZR Forum - RZR Forums.net
 6Likes
  • 1 Post By 185EZ
  • 4 Post By 185EZ
  • 1 Post By PhillyPyro
post #1 of 8 Old June 22nd, 2019, 11:54 AM Thread Starter
Vmaxpro's Avatar
Member #211097
View Vmaxpro's Photo Gallery(0)
Cant believe how restrictive they get! Az dust out really clogged mine. It felt so choked off and wouldnt go past maybe 6500rpm and belts temps were creeping higher. Going to look into a better solution cuz its crazy dusty here!
Vmaxpro is offline
post #2 of 8 Old June 22nd, 2019, 12:19 PM
The Lone Rzr
185EZ's Avatar
My RZR: 2017 1KXP4
Member #89257
View 185EZ's Photo Gallery(0)
Re: Clean those frog skins!!
And this is what gets past the frog skinz in AZ dust
20180925_081028 by 185 EZ, on Flickr
185EZ is online now
post #3 of 8 Old June 22nd, 2019, 02:43 PM
Hartman's Avatar
My RZR: 2017 XP 1000 EPS
Member #116577
View Hartman's Photo Gallery(0)
I really like that flip up spare tire carrier. I've been looking at getting one. What make is that and who sells it? Apart from restricting the rear view mirror field, any change in riding characteristics from the extra weight higher up?
Hartman is offline
post #4 of 8 Old June 22nd, 2019, 02:59 PM
The Lone Rzr
185EZ's Avatar
My RZR: 2017 1KXP4
Member #89257
[quote=Hartman;5908102]
It's similar to the polaris one but I got one on ebay.
https://www.ebay.com/itm/2014-19-Pol...0AAOSwU-pXugMb
I think I paid $220.
I raised it up just high enough to fit in my trailer and open up my cooler.
Don't notice anything as far as driveability issues.
Being up high does let me see enough out the back
ID:	579030   Click image for larger version
Hartman likes this.
185EZ is online now
post #5 of 8 Old June 22nd, 2019, 11:10 PM
Hartman's Avatar
Member #116577
[quote=185EZ;5908110]
Thx for the info I'll check out eBay. I torn between you flip up tire mount versus the one where the tire sits horizontal just below the roof line.
Hartman is offline
post #6 of 8 Old June 23rd, 2019, 05:21 AM
jonthefireman's Avatar
First Name: Jon
My RZR: 2018 XP 4 Ride Command Edition
Member #269390
View jonthefireman's Photo Gallery(0)
Is that just HVAC filter media that you cut for the inside of the cover? That's a great idea, did you lightly spray the media with a filter oil or just run dry? Any restriction notice?
jonthefireman is offline
post #7 of 8 Old June 23rd, 2019, 07:57 AM
The Lone Rzr
185EZ's Avatar
My RZR: 2017 1KXP4
Member #89257
yep, a sheet of a/c filter you can get at walmart
You can't see but they're shaped to a V to fit inside.
I spray a little KN oil on them
Someone mentioned not to spray the clutch side because some oil might pass through with the dirt on to the clutches.
Haven't noticed that and haven't noticed any restrictions to the motor
It's not very dense material so I think it breathes well
If I know I'm going to ride in real dusty area I also put the foam shop vac filters around the air cleaner
Also not very dense material. Not much dirt gets to my air filter
20180925_081439 by 185 EZ, on Flickr
185EZ is online now
post #8 of 8 Old Today, 08:36 AM
PhillyPyro's Avatar
First Name: Stephen
My RZR: XP 1000
Member #91401
View PhillyPyro's Photo Gallery(0)
I’m going to try the green filter trick. Great idea
185EZ likes this.
PhillyPyro is online now
