Question about loading my new RZR onto a trailer? - Polaris RZR Forum - RZR Forums.net
 33Likes
post #1 of 28 Old June 16th, 2019, 05:41 AM Thread Starter
Lamekurt's Avatar
Member #270374
View Lamekurt's Photo Gallery(0)
Hi all, first post on this forum. I just purchased a new RZR XP 1000 and pick it up Tuesday. I went online and downloaded the PDF of the owners manual to familiarize myself with some things and as I went through the manual it had mentioned using 4 low to load and unload the machine onto/ off of a trailer. Is this required and is it something most of you RZR owners do? I’d love to know before I go to load it on when I pick it up Tuesday! Thanks in advance!
Lamekurt is online now
post #2 of 28 Old June 16th, 2019, 05:53 AM
Hunterworks's Avatar
First Name: Todd
Member #47437
Feedback Score: 8 reviews
Re: Question about loading my new RZR onto a trailer?
Can't imagine 4wd is necessary but yes on using low range and do not make a habit of easing on the gas, you are just slipping and wearing your belt away.
Check our round rollers for secondary too, now is the time to do those
RZRdavid likes this.
www.hunterworks.com
Todd
Office phone: 601-771-0070
Hunterworks is offline
post #3 of 28 Old June 16th, 2019, 05:54 AM
Herdfan's Avatar
Member #203033
View Herdfan's Photo Gallery(0)
Don't know about using 4WD in Low, but certainly use Low. (I have a General so I use 1 Low).
You should always use Low when pulling something or continued riding below 25-30.
Herdfan is online now
post #4 of 28 Old June 16th, 2019, 06:02 AM Thread Starter
Lamekurt's Avatar
Member #270374
No easing on the gas? Are you always suppose to start off by giving it a shot on the throttle so the clutch engages quicker? Is that the logic behind not easing the gas? Thanks
post #5 of 28 Old June 16th, 2019, 06:37 AM
First Name: Todd
Member #47437
Well you can't always do that but it would be best, easing on the gas is like riding the clutch on a 5 speed car or truck, just wears the clutch away
www.hunterworks.com
Todd
post #6 of 28 Old June 16th, 2019, 07:35 AM
madsonp's Avatar
My RZR: 2017 XP 1000
Member #189721
View madsonp's Photo Gallery(0)
It just depends on how steep your loading ramps are, if they aren't very steep, 2WD high is fine.
madsonp is offline
post #7 of 28 Old June 16th, 2019, 08:47 AM
BWXT's Avatar
My RZR: 2018 XP1000 Black
Member #241858
View BWXT's Photo Gallery(0)
For the life of me I cannot think of any reason you would load in high range.
To the OP; They are telling you to load in 4-Lo because it is less likely to slip the belt, will give you more control, allow you to load more slowly, and will reduce/eliminate the possibility of slipping the rear tires and causing the unit to slide laterally on the ramp(s). I load mine in 4-Lo because why not?
Rockwerx, RZRdavid, Bizill and 2 others like this.
BWXT is offline
post #8 of 28 Old June 16th, 2019, 11:34 AM
madsonp's Avatar
Member #189721
AGAIN, it depends on how steep your loading ramps are, on my trailer I have a 2' rise and my ramps are 6' long which isn't steep at all. I highly doubt you put yours in 4 low anytime you come to a slight incline, what's the difference ?
madsonp is offline
post #9 of 28 Old June 16th, 2019, 03:25 PM
Aspiring Perfectionist
RWB713's Avatar
First Name: Richard
My RZR: 2018 XP4 Turbo
Member #70552
Put it in low, drive it on the trailer. 4wd or 2wd is irrelevant unless the rear wheels slip. Donít over think it.
SpdBump, RZR_Joe, Rockwerx and 3 others like this.
2018 XPT4 - Bailey
RWB713 is online now
post #10 of 28 Old June 16th, 2019, 03:28 PM
Herdfan's Avatar
Member #203033
I don't understand your opposition to people putting it in Low?
Rockwerx and BWXT like this.
post #11 of 28 Old June 16th, 2019, 04:34 PM
madsonp's Avatar
Member #189721
I'm not opposed to it, you can put it in any gear that makes you happy, I'm saying it's not necessarily mandatory you be in 4 low, you just need to base it on your specific circumstances.
madsonp is offline
post #12 of 28 Old June 16th, 2019, 05:00 PM
Jasonv's Avatar
Member #154033
View Jasonv's Photo Gallery(1)
If you plan on ramping over the trailer and/or tow vehicle you will need to be in high range.
Rockwerx, Mcebull, BWXT and 2 others like this.
Jasonv is offline
post #13 of 28 Old June 16th, 2019, 05:09 PM
RWB713's Avatar
First Name: Richard
Member #70552
Send it!
FRAZR likes this.
2018 XPT4 - Bailey
post #14 of 28 Old June 17th, 2019, 09:19 PM
madsonp's Avatar
Member #189721
Yep, that's true if you're an idiot, and don't know how to drive the thing.
Gregg628 likes this.
madsonp is offline
post #15 of 28 Old June 17th, 2019, 10:59 PM
Reuven's Avatar
My RZR: 2015 XP1K Voodoo Blue
Member #77974
View Reuven's Photo Gallery(0)
I back mine onto the trailer so the engine is farther forward. I drive until my tires rest against the tube rails and use 4 tie downs. My utility trailer tows better and less sway with the weight forward. Congrats on the machine m, donít overthink it!
Reuven is online now
