4+3 with 32” tires and rock crawling? - Polaris RZR Forum - RZR Forums.net
post #1 of 10 Old May 13th, 2019, 10:47 AM Thread Starter
Vmaxpro's Avatar
Member #211097
View Vmaxpro's Photo Gallery(0)
I feel like I already know the answer, however, am I asking for blown eps fuses and other issues? Id really like the height gain and extra width but if 5+2 is that much better ill go that route. Thanks!
Vmaxpro is offline
post #2 of 10 Old May 13th, 2019, 06:47 PM
dartersracing's Avatar
First Name: DONNY
My RZR: 2014 PACE Z1 1000
Member #19554
Feedback Score: 15 reviews
Re: 4+3 with 32” tires and rock crawling?
you would actually lose ride height with 4+3 due to more leverage on springs.
209-373-5336 DONNY DARTER
dartersracing is offline
post #3 of 10 Old May 14th, 2019, 10:35 PM
vidwiz's Avatar
My RZR: 2019 XP1000 Trails and Rocks Edition
Member #16877
View vidwiz's Photo Gallery(0)
4+3 not good for front. While not without some disadvantages, I went with 32's, 4+3 rear, 5+2 front, works for me!
vidwiz is offline
post #4 of 10 Old May 15th, 2019, 02:40 AM
GreggC's Avatar
First Name: Gregg
My RZR: 2014 XP1K Black Pearl "Darth"
Member #32940
View GreggC's Photo Gallery(0)
Trouble free for 3000 miles.
XP1K Black Pearl
"Darth"
GreggC is offline
post #5 of 10 Old May 15th, 2019, 05:06 AM Thread Starter
Vmaxpro's Avatar
Member #211097
Looks good! Do you do any crawling?
Vmaxpro is offline
post #6 of 10 Old May 15th, 2019, 07:13 AM
RZRCrawlin's Avatar
My RZR: 2017 RZR XP4T
Member #17965
View RZRCrawlin's Photo Gallery(0)
I had a XP 900 running 4+3s and loved it. Never an issue with anything after more than 4,000 miles.
Now, I have an XP4T and started out with 5+2 because I was all in the head about scrub. I moved to 4+3, because my aftermarket high clearance forward A Arms would cause the wheel/tire to rub on the lower shock mount because of the 5 in the 5+2. The 4+3 is more stable on off camber situations in crawling. It also looks better IMHO. The argument with 4+3 is scrub. Because you should be running lower tire pressures crawling, you don't "feel" anything extra from the scrub feedback. Just keep an eye on ball joints. But, I've never had a problem. And, if you feel you have an issue with ride height, just adjust your preload. I crawl 75% of the time and would never go back to 5+2.
The next question is how is your machine turning 32s? That's going to be a clutch question. It really depends on your driving style and how heavy your tire/wheel combo is. You may consider at least a clutch kit, if you're crawling. But, a gear reduction is the way to go. It's just more money.
Let me know if you're heading to Sand Hollow to rock crawl!
RZRCrawlin is offline
post #7 of 10 Old May 15th, 2019, 08:14 AM Thread Starter
Vmaxpro's Avatar
Member #211097
Well Ive been talking with hunterworks about the duraclutch and I think im going that route. For the gear reduction im lost, I know I want high range reduction to run like stock and I for sure want a little deeper gear in low.
Vmaxpro is offline
post #8 of 10 Old May 15th, 2019, 08:19 AM
RZRCrawlin's Avatar
Member #17965
The Duraclutch is a phenomenal setup. I wish they had it for the turbos.
post #9 of 10 Old May 15th, 2019, 09:28 AM Thread Starter
Vmaxpro's Avatar
Member #211097
Is it that it just cant handle the extra torque or is it a different design?
Vmaxpro is offline
post #10 of 10 Old May 15th, 2019, 10:21 PM
Reuven's Avatar
My RZR: 2015 XP1K Voodoo Blue
Member #77974
View Reuven's Photo Gallery(0)
I would start with clutching. Stock clutch setup and maintained will work great. I recommend slp magnum force clutch kit as its tunable without removing anything. Ive run 27-32 bfg with the same kit. Ran 32 for 2 years without issues. Yes occasional power steering reset but that can happen with stock setup. Wicked built makes heavier duty power steering unit, dont do the Saturn based kit, too many problems.
Reuven is offline
Rock crawling tires gomerpyell RZR XP 1000 2 April 23rd, 2017 07:17 AM
Lets discuss BIG tires for Rock Crawling Cadiero Wheels and Tires 4 June 7th, 2012 09:33 AM
Rock Tires for crawling... Trakker Wheels and Tires 17 March 26th, 2012 08:32 AM
Rock crawling tires? alaska Wheels and Tires 17 March 22nd, 2011 07:22 PM
whats the best tires for rock crawling??? racen Wheels and Tires 17 January 22nd, 2011 08:24 PM
