Review on Hunterworks thick belt - Polaris RZR Forum - RZR Forums.net
 12Likes
post #1 of 39 Old March 20th, 2019, 05:20 PM Thread Starter
Roger Lee's Avatar
First Name: Roger
My RZR: 2015 1K
Member #69952
Just a prologue:
I have a 2015 RZR 1K EXP 2 seater. I have right at 12K miles. I drive like a normal person and do not abuse my Rzr. My trail riding is usually between 10-20 mph and my smooth road between 30-40. Some riding lower than 10 in rough terrain and occasionally at 45 mph. My original OEM belt lasted 3500 miles and I just tossed it and put on a Gates belt and it and the next one lasted 3500 miles each. All three belts always looked good when I changed them. I did have a lot of belt/clutch squeal and high rpm belt noise, but no issues.
So I decided to try the Hunterworks thick belt to compare.
I broke the belt in for 30 miles in low at varying speeds and towards the end in high at 30 mph. I now have about 230 miles on it. It does seem to engage at lower rpms better, but does have a little squeal for 2 seconds as you just start. It is much quieter after you get going than the the OEM or Gates. It seems to stay engaged much better at low down hill rpms with engine braking. It does run 15F hotter across the board than the others, but that can probably be expected with a thicker heavier belt. I run a Razorback temp gauge.
So far everything seems to be good and other than the temp increase and tiny squeal (minor) at take off I have no complaints and it seems to work well. There is no fixing belt noise and if you have it you have it.
By the end of August I'll have around 3000 miles on the belt and will know more.
Dunepilot and Carhauler38 like this.
Roger Lee is offline
post #2 of 39 Old March 20th, 2019, 05:40 PM
Odogtriever's Avatar
Member #264946
View Odogtriever's Photo Gallery(0)
Re: Review on Hunterworks thick belt
Wow you really put on the miles! How much of that is street driving? What's the cost compared to oem? If it engages quicker do you feel any low end increase in power?
Sent from my SM-N950U using Tapatalk
Odogtriever is offline
post #3 of 39 Old March 20th, 2019, 05:45 PM
btrshoes's Avatar
My RZR: 900S
Member #48027
View btrshoes's Photo Gallery(0)
I too am curious about this. I switched to the thick belt and the roller upgrade. I smelled rubber alot the first day, hardly at all the second day...this weekend will be the 3rd ride. reason I went to heavier belt is I installed 32s...So im not surprised if the belt burns or shreds. Im waiting to see...
btrshoes is offline
post #4 of 39 Old March 20th, 2019, 06:55 PM
RMR Man's Avatar
First Name: Steve
Member #11566
I put on the HW thick belt, after the factory belt and then a Gates HD belt from HW. 4500 miles between the first 2 belts. The first 2 performed as expected and gave very good control from low speed to WOT.
Did 47 miles of rather rough and steep trails last weekend, and this new thick belt was amazing. The low speed control and grunting out of some nasty uphills was fantastic. The only thing I didn't like, was it sounded like a bird singing during low speed level driving, up until about 10 mph. At $124 or so, I think it's going to worth the extra money.
RMR Man is offline
post #5 of 39 Old March 21st, 2019, 04:03 AM
Hunterworks's Avatar
First Name: Todd
Member #47437
Feedback Score: 8 reviews
From our Belt FAQ's
Notice your old belt and you will see you can see the cords on the side all the way around and a new belt ours or a OE the cord is not exposed all the way around, once driven the excess rubber wears off fast and causes a smell sometimes, once broken in that goes away.
www.hunterworks.com
Todd
Office phone: 601-771-0070
Hunterworks is offline
post #6 of 39 Old March 21st, 2019, 04:04 AM
First Name: Todd
Member #47437
Thanks Guys for your comments, we really are trying and not resting until we get these as perfect as they can be. I like feedback good or bad.
Todd
Zonk and d00by like this.
www.hunterworks.com
Todd
post #7 of 39 Old March 21st, 2019, 07:41 AM Thread Starter
Roger Lee's Avatar
First Name: Roger
My RZR: 2015 1K
Member #69952
I have done and still do a lot of testing and research in the Light Sport aircraft industry so I try to be methodical and rule in or out as many factors as I can and make sure results are repeatable.
I didn't have any rubber smell. I have that little squeal noise when I take off to about 5 mph for about 2 seconds then all is quiet. The belt engages smoother than my Gates and quicker. The belt has gotten better over the miles of break in. Most of that last couple hundred miles have been dirt, but some asphalt to. I try to stay away from asphalt, but that has become an unreasonable task.
I have Tensor 30x10x14 tires with 8 psi.
The thick belt is more costly than a Gates. I never had an issue with the Gate's except the noise.
So far I'm a happy camper.
p.s.
I do have the Hunterworks secondary clutch parts
post #8 of 39 Old March 21st, 2019, 08:20 AM
wiersy111's Avatar
First Name: Steve
My RZR: 2017 RZR 1000 xp
Member #80279
View wiersy111's Photo Gallery(5)
I was saving my Hunterworks thick belt for spring but after blowing a Gates belt (Totaly my own fault) playing in the snow I decided to put the thick belt on early.
I broke it in last fall when I got it just so it was ready to go when I needed it. The engagement is quick and solid, but there is the "chirping" at low speed. I have taken a few higher speed runs with it but it was used mostly for plowing this winter.
Now that spring looks like it might be here it is time to open the clutches and clean everything up real good so I can see how it will perform under normal conditions.
So far all things considered I like it.
Sent from my SM-G960U using Tapatalk
wiersy111 is offline
post #9 of 39 Old March 21st, 2019, 10:11 AM
rea
Have RZR...will travel
rea's Avatar
First Name: Bob
My RZR: 2015 1K HL Desert Panther
Member #21304
View rea's Photo Gallery(6)
I ride on 32" tires and have about 2500 miles on a HW belt. Odor and squeal disappeared long before I reach breakin mileage. Better engagement with no chatter on take off even in reverse and better 'engine braking effect' especially when descending. Temperature seems the same if not lower. Got about 3500 miles on first 3 belts without any breaking. Replaced as I noticed signs of cracking on inside valleys and/or chunking on outside ribs. Hoping for 5 k on HW belt. Does what it claims, better than others in all respects just like those amazing HW rollers with 10k+ miles! Thanks again Todd.
15 RZR 1K HL, 32x10x15R Tusk Kevlar Terrabite tires on MSA M21 beadlocks, WE custom built 2.5" needle valve shocks, WartHog front axles, WE sway bar links, S&B particle separator and air filter, roof, windshield, doors, bumpers, Pro Armor Assault steering wheel, Trail Armor 1/2" skid/sliders, 4500 winch, Ryco street legal kit, RLB, 30" combo light bar, Rugged RM25RW radio/RRP660, Sirius XM/radio, PIDD, F/Rearview camera mirror, tools, recovery, safety & survival gear.
rea is offline
post #10 of 39 Old March 21st, 2019, 10:29 AM
First Name: Todd
Member #47437
Dang, thanks for the review!!!
www.hunterworks.com
Todd
post #11 of 39 Old March 21st, 2019, 10:59 AM
rea
rea's Avatar
First Name: Bob
Member #21304
Your welcome but no thanks needed! Your products and service speak for themselves.
Hunterworks likes this.
rea is offline
post #12 of 39 Old March 21st, 2019, 07:47 PM
Jake ND's Avatar
First Name: jacob
My RZR: 2019 XP 1000
Member #266248
View Jake ND's Photo Gallery(0)
I have a stock machine and do mainly trail riding not much mud bogging and no rock crawling so would I be better off with the regular belt ? I did some research and it seems like the thick belt is for the extreme mud boggers and people with big tires. any info would be good im in need for a spare belt or possibly put a hunter belt on immediately since I been hearing good reviews.
Jake ND is offline
post #13 of 39 Old March 22nd, 2019, 04:16 AM
First Name: Todd
Member #47437
Our tech articles cover this well, but mainly it is slow guys who need a lot of belt grip should go with the thick and faster rider the Std belt
Todd
www.hunterworks.com
Todd
post #14 of 39 Old March 22nd, 2019, 05:17 AM
Member #264946
Todd
What if I ride fast and slow? We do a lot of rock crawling here in Utah and drive really fast in the desert too.
post #15 of 39 Old March 22nd, 2019, 06:18 AM
First Name: Todd
Member #47437
Better go with std then, the slow part will be on par with any other belt you can buy
www.hunterworks.com
Todd
How to pick a Brand of CVT Belt Hunterworks Hunterworks 0 August 30th, 2018 05:41 AM
Positive HW Belt Reviews Racking up!! Hunterworks Hunterworks 0 August 30th, 2018 04:58 AM
Gates RZR Belt Part number confusion Hunterworks Hunterworks 1 March 12th, 2017 06:26 AM
15 1000 guys use a 14 belt!!! Read this!! Hunterworks Hunterworks 35 May 18th, 2015 02:02 PM
