'16 XP 1000 o2 Sensor, replace or delete along with cat? - Polaris RZR Forum - RZR Forums.net
 3Likes
post #1 of 22 Old January 10th, 2019, 01:55 PM Thread Starter
Bizill's Avatar
My RZR: 2016 XP 1000
Member #261600
View Bizill's Photo Gallery(0)
My used 2016 xp1000 w/ride command has an o2 code (P0030 / 520209) when I bought it but didn't have a clue until after I got her home. It doesn't seem to be in any "limp mode" that others mention so I haven't addressed the issue yet. My research shows here that most just replace the $120 oxygen sensor and move on. But I'm wondering what kills them at such a tender age?
Is it possible that the catalytic converter retains too much heat, thus causing premature wear on the sensor? I've read also that the sensor's connection may be bad but I've checked that and it seems fine. Anyway, I was debating pending further research whether or not to hollow out my cat and while I was at it I had considered getting that Bikeman's Performance 02 delete meant for aftermarket exhaust. I'll be keeping the stock exhaust, and especially keeping the spark arrestor.
I wanted to get some of everyone's thoughts who may have experience with this because after reading multiple threads on the subjects I can't seem to make up my mind which road to travel. Thanks in advance, guys and gals.
Bizill is offline
post #2 of 22 Old January 10th, 2019, 02:18 PM
The Lone Rzr
185EZ's Avatar
My RZR: 2017 1KXP4
Member #89257
View 185EZ's Photo Gallery(0)
Re: '16 XP 1000 o2 Sensor, replace or delete along with cat?
We have someone else that did the O2 delete but we haven't figured too much out yet lol
His mileage dropped quite a bit
https://www.rzrforums.net/rzr-xp-tur...-thoughts.html
As Rzrjoe stated if someone ran avgas it could damage the sensor as well as the cat.
I have pictures how much a cat retains the heat.
I gutted my cat but I'm not going to tell you to do it.
RWB713 likes this.
185EZ is offline
post #3 of 22 Old January 10th, 2019, 02:22 PM
The Lone Rzr
185EZ's Avatar
My RZR: 2017 1KXP4
Member #89257
You can see hot hot the muffler gets with the cat in
1497559378298_temp1_zpsqtcrlk0f by 185 EZ, on Flickr
185EZ is offline
post #4 of 22 Old January 10th, 2019, 02:24 PM Thread Starter
Bizill's Avatar
Member #261600
185EZ, I've been keeping tabs on your cat delete, so much so that I pm'ed you asking about it but I think your pm box is full as you didn't get back to me. I'll have to read that thread you linked...
Bought from an old man and for all I know he may have run 85 octane but did say he used 91...
Bizill is offline
post #5 of 22 Old January 10th, 2019, 02:33 PM Thread Starter
Bizill's Avatar
Member #261600
In my research it seemed like o2 sensor failures came up often, but considering the amount of members here, it's probably just a drop in a bucket.
Bizill is offline
post #6 of 22 Old January 10th, 2019, 02:50 PM
The Lone Rzr
185EZ's Avatar
My RZR: 2017 1KXP4
Member #89257
I apologize for that. I may have forgot to get back to you and i just deleted 1000 pm's this year.
I have plenty of room, lol.
You have 256 messages stored, of a total 10,050 allowed
Cat delete isn't difficult. Main thing is to have a welder or mark where you cut and take it to someone
185EZ is offline
post #7 of 22 Old January 10th, 2019, 02:53 PM Thread Starter
Bizill's Avatar
Member #261600
So EZ, you thinking the best I should do is replace the o2 sensor and also delete the cat? I think that's the route I'll end up travelling. Yes, I can weld it up with my Hobart MVP210.
Bizill is offline
post #8 of 22 Old January 10th, 2019, 03:11 PM
The Lone Rzr
185EZ's Avatar
My RZR: 2017 1KXP4
Member #89257
Me? I would try the O2 delete before spending $120
RZR o2 Sensor Blockoff Kit
If you want to do an ecu flash I believe Aftermarket Assasins has the delete in their tune
I just did the Dynojet tune but it doesn't delete the O2
As far as the cat I would delete that on any ride i had.
I think intoxicated had a meltdown with his muffler
I won't actually "tell" someone to do it though if you know what i mean.
185EZ is offline
post #9 of 22 Old January 10th, 2019, 03:16 PM Thread Starter
Bizill's Avatar
Member #261600
Yeah, I've studied up on the cat delete so I know how to go about doing it. Thanks, EZ....wink, wink.
So you're with me in trying the o2 delete? I probably won't flash ecm anytime soon as the bikeman has a resistor so it tricks the ecm, yes? So that other thread where guy who did the o2 delete claiming to get worse milage, a fluke on his part you think?
mccrory66 likes this.
Bizill is offline
post #10 of 22 Old January 10th, 2019, 03:22 PM
The Lone Rzr
185EZ's Avatar
My RZR: 2017 1KXP4
Member #89257
Ya we don't know what the other guy did with the delete
Limited info to go on so far
That's one of those problems we all would like to know and how to fix it
185EZ is offline
post #11 of 22 Old January 10th, 2019, 03:24 PM
The Lone Rzr
185EZ's Avatar
My RZR: 2017 1KXP4
Member #89257
I really think you should try the bikeman delete
Then let us know
So I can do it, lol
Weststsh likes this.
185EZ is offline
post #12 of 22 Old January 10th, 2019, 05:35 PM Thread Starter
Bizill's Avatar
Member #261600
I think I'll call Bikeman tomorrow and pose some queries, that is, unless someone can furnish me with a value resistor to wire into the factory harness. Then I'll just leave the bad o2 sensor in....
ETA: No, I didn't mean for the to read as though I was gonna ask BM to give me values and not buy from them...
Bizill is offline
post #13 of 22 Old January 10th, 2019, 06:06 PM
Quest96's Avatar
Member #257160
View Quest96's Photo Gallery(0)
I just bought my 16 xp about a month and a half ago. When i got it home the engine light came on as soon as i unloaded it. It had the o2 code in it. I changed the sensor and its been good since. The o2 delete us just a resistor. The o2 helps with fuel correction.
Quest96 is offline
post #14 of 22 Old January 10th, 2019, 06:24 PM
Rockymtn5280's Avatar
My RZR: 2018 RZR 1000 TRE
Member #223457
A resistor wired in is not going to fool the ECM. You will probably set more codes than you can shake a stick at.
Rockymtn5280 is offline
post #15 of 22 Old January 10th, 2019, 06:52 PM Thread Starter
Bizill's Avatar
Member #261600
So then the bikeman delete would only be good in conjunction with an ecm tune then? That's what I was afraid of and sort of a reason I posed this to you all.
Bizill is offline
[UPDATED 2019] UTV INC RZR Wheel Bearing Greasing Tool UTV Inc. UTV Inc 147 May 2nd, 2019 08:17 AM
RZR Turbo Stop Sale - 2018 Why? dafish RZR XP Turbo 16 April 3rd, 2018 04:46 PM
UTV INC eBay LISTINGS - NEW & USED Inventory! UTV Inc. UTV Inc 32 September 10th, 2016 10:26 AM
Arctic Cat WildCat 1000 side by side Demo Ride Discount Tire Discount Tire 5 December 9th, 2011 02:18 PM
