Gauge Cluster Issue - Polaris RZR Forum - RZR Forums.net
post #1 of 2 Old December 19th, 2018, 10:38 PM Thread Starter
Timcolyer1's Avatar
Member #176521
View Timcolyer1's Photo Gallery(0)
Gauge Cluster Issue
2017 RZR 1000 XP, Gauge cluster not working, coming on, nor lighting up. Showed Over Voltage before it went out...
So far Ive replaced the following:
ENTIRE wiring harness, front to back
New battery leads to starter and to accessory block
Cleaned and Regrounded the ground cable
Load test on and charged Battery
Swapped out gauge cluster with "known to work" gauge cluster
New starter Solenoid (just because)
Replaced all relays and fuses
New Voltage Mosfet Regulator from RMSTATOR
New ignition coil and wires (just because)
Tested the pins (wire harness side) for 12 volts
Need help please!!!
Timcolyer1 is offline
post #2 of 2 Old July 11th, 2019, 11:37 AM
mikesooter's Avatar
Member #271002
View mikesooter's Photo Gallery(0)
Did you ever figure out what the problem was? I’m having similar issues.
mikesooter is offline
Instrument cluster lighting issue. Helowarrior Lighting, Stereo and Electrical 3 November 12th, 2013 06:14 AM
Looking for Polaris rzr Gauge Cluster toyota_101 Polaris RZR Parts For Sale 4 July 2nd, 2013 12:19 PM
MY new gauge cluster cwspfx General RZR Discussion 23 February 4th, 2010 03:59 PM
Billet gauge cluster bezel- new in package fourseventeen Polaris RZR Parts For Sale 1 July 28th, 2009 04:03 PM
Dakota Digital RZR Factory replacement gauge cluster fourseventeen Lighting, Stereo and Electrical 40 May 28th, 2009 05:41 PM
