Tender spring swap - where to set the compression adjuster - Polaris RZR Forum - RZR Forums.net
 16Likes
post #1 of 33 Old November 27th, 2018, 01:02 PM Thread Starter
polarisrzr18's Avatar
Member #234306
View polarisrzr18's Photo Gallery(0)
Just picked up some rzr aid tenders for my 16 1kxp.
I have a pretty decent sized front bumper, a winch, (2) 200lb passengers.
What should I set the collars at front and back? I have them adjusted down and I'm pretty sure the original owner had adjusted them. So I'm not sure where stock is.
What should I set it at for my bumper, winch and passengers. Have 30"s so I'm looking for what about 14" gc?
** I understand I will have to fine tune. Looking for ballpark **
polarisrzr18 is offline
post #2 of 33 Old November 27th, 2018, 01:06 PM
FRAZR's Avatar
First Name: Bruce
My RZR: 2017 XPT
Member #82174
View FRAZR's Photo Gallery(0)
Re: Tender spring swap - where to set the compression adjuster
I'd post this question under Shock Therapy also.
FRAZR is offline
post #3 of 33 Old November 27th, 2018, 01:10 PM Thread Starter
Member #234306
But I dont have shock therapy springs.
post #4 of 33 Old November 27th, 2018, 01:14 PM
RZR_Joe's Avatar
Member #23438
Feedback Score: 6 reviews
Set them where it gives you the desired right height.
RZR_Joe is online now
post #5 of 33 Old November 27th, 2018, 01:17 PM Thread Starter
Member #234306
Thank you for all of the information!!!
I mean I'm not trying to be a dick but no shit?
I know this has been done thousands of times and I'm sure someone has a pretty good idea of where the stock setting is. And where I should approximately set it.
Even if someone says "put collar 1in from the top" that is still helping me. Because I dont know what it was stock. I just need a ballpark idea. I know I will have to fine tune it.
post #6 of 33 Old November 27th, 2018, 01:27 PM
rynomx785's Avatar
First Name: Ryan
My RZR: 17 XP 4 Turbo
Member #61131
View rynomx785's Photo Gallery(0)
16" is too much ride height. I would be shooting for ~14" in the rear and ~14.5" in the front.
As far as stock preload measurement goes, it is pretty much irrelevant now that you have different springs.
rynomx785 is offline
post #7 of 33 Old November 27th, 2018, 01:27 PM
FRAZR's Avatar
First Name: Bruce
My RZR: 2017 XPT
Member #82174
Shock Therapy is very helpful. Hope you get your answer.
FRAZR is offline
post #8 of 33 Old November 27th, 2018, 01:29 PM Thread Starter
Member #234306
Is shock therapy a sub forum on here? Never have seen it
post #9 of 33 Old November 27th, 2018, 01:31 PM
Rocky_Top's Avatar
First Name: Bradley
My RZR: 2018 Polaris RZR 1000 XP
Member #80320
View Rocky_Top's Photo Gallery(0)
I found this and was going to try it. Let me know if it is close to being right.
Rocky_Top is offline
post #10 of 33 Old November 27th, 2018, 01:31 PM Thread Starter
Member #234306
Ah that is closer. I just seen factory ride height is around 13.5".
post #11 of 33 Old November 27th, 2018, 01:32 PM
FRAZR's Avatar
First Name: Bruce
My RZR: 2017 XPT
Member #82174
They are in the vendor section;
https://www.rzrforums.net/375-shock-therapy/
FRAZR is offline
post #12 of 33 Old November 27th, 2018, 01:33 PM Thread Starter
Member #234306
Attachment 565542
Nice! I've not seen this before. I will try it and let ya know
post #13 of 33 Old November 27th, 2018, 01:35 PM
RZR_Joe's Avatar
Member #23438
There is NO "answer" other than set it you get the ride height you want by trail and error. To many factors to say "set @ xx". Maybe Facebook is more your speed
Wheel, RZRdavid and GimpyRZR like this.
post #14 of 33 Old November 27th, 2018, 01:38 PM Thread Starter
Member #234306
You see how other people actually helped? Like gave me pointers. Said what ground clearance was to much. Said an ideal clearance. Steered me in the right direction.
You didnt do that. Your contribution didnt help me one bit.
If your response was deleted, i wouldnt lose any knowledge.
Comeon dude I obviously understand that its not cookie cutter. I'm looking for a ball park idea, as I stated.
Nowhere did I say "I want the right exact measurement and dont want to deal with it".
Actually I made that clear in the response to your first post.
post #15 of 33 Old November 27th, 2018, 01:45 PM
RZR_Joe's Avatar
Member #23438
You still don't get it and your smartass response was not called for. Ride height is personal preference. You added weight and changed springs, the ONLY answer is adjust them to get the ride height YOU want. It's not rocket science. Good luck
GimpyRZR likes this.
XP4 Tender spring swap on 2 seater Zapo RZR XP 1000 105 August 9th, 2016 08:39 AM
Shock Therapy XP Turbo suspension Shock Therapist Shock Therapy 0 September 1st, 2015 03:33 PM
1k tender spring swap lifted800s RZR XP 1000 7 May 25th, 2015 09:27 PM
xp 1000 spring math ????? KING OF THE HILL RZR XP 1000 27 February 25th, 2015 05:11 AM
I Need upgrade shock with stock A-arms BBlakewv80 Suspension 17 June 25th, 2009 07:56 PM
