Drive belt info? - Polaris RZR Forum - RZR Forums.net
 3Likes
post #1 of 24 Old September 21st, 2018, 06:25 PM Thread Starter
dustinbirchard's Avatar
Member #260964
View dustinbirchard's Photo Gallery(0)
Drive belt info?
So I was looking for belts and found a Gates belt 21G4140 I was wondering if this is the correct belt for a 2014 XP 1000. Itís a little confusing with all the different belts and numbers out there and all the updated versions. Thanks for any help on breaking this down for me
dustinbirchard is offline
post #2 of 24 Old September 22nd, 2018, 03:47 AM
XMARGH's Avatar
Member #241850
Re: Drive belt info?
https://www.hunterworks.com/hw_polaris_cvt_belts
First recommendation for belts would be Hunterworks.
If you really want a Gates Belt:
https://www.hunterworks.com/inc/sdetail/56301/62969
Shawn
2018 Polaris RZR XP 1000 EPS Highlifter Edition
XMARGH YouTube Channel
XMARGH is offline
post #3 of 24 Old September 22nd, 2018, 06:43 AM
liftedpsd2010's Avatar
First Name: Michael
My RZR: 2018 rzr 4 highlifter 1000
Member #85073
View liftedpsd2010's Photo Gallery(0)
Just break down and get the oem belt. Youíll get the best results from it. Speaking from experience with gates and other aftermarket belts.
liftedpsd2010 is offline
post #4 of 24 Old September 22nd, 2018, 06:49 AM Thread Starter
Member #260964
Thanks for the suggestions guy but I have friend that gave me this belt and was looking to see if it would be a good emergency belt to keep for getting back home
post #5 of 24 Old September 22nd, 2018, 06:55 AM
First Name: Michael
Member #85073
As far as I can tell yes it will fit. But from my experience I wonít ever use a cheap belt for a spare ever. Iíve broken 3 total belts between my rZr and ranger and when they broke it took out the belt seal and screwed up the covers. I mean if you use it as a spare put it on and go straight to the trailer and get it off. Itís not worth 200 plus dollars of parts that might break if it shreds.
post #6 of 24 Old September 22nd, 2018, 07:21 AM Thread Starter
Member #260964
Just wondering, would you consider a Gates belt cheap? It seems as most people go Polaris or Gates for a belt
post #7 of 24 Old September 22nd, 2018, 07:25 AM
First Name: Michael
Member #85073
That gates belt you gave a part number from yes is the cheapest gates belt they offer. I have tried hunterworks, gates carbon and oem. Oem is what I will stick with after those companies.
post #8 of 24 Old September 22nd, 2018, 07:28 AM Thread Starter
Member #260964
Oh okay thanks for that I was just wondering.
post #9 of 24 Old September 22nd, 2018, 07:31 AM
Hunterworks's Avatar
First Name: Todd
Member #47437
Feedback Score: 8 reviews
I like this answer!!! LOL
www.hunterworks.com
Todd
Office phone: 601-771-0070
Hunterworks is offline
post #10 of 24 Old September 22nd, 2018, 07:34 AM Thread Starter
Member #260964
I bet you do! HAHA. But does that belt work?
post #11 of 24 Old September 22nd, 2018, 07:39 AM
First Name: Michael
Member #85073
post #12 of 24 Old September 22nd, 2018, 07:39 AM
First Name: Todd
Member #47437
While technically correct the G part means it is the cheaper of their two belts with the C being the better of the two since it is carbon fiber
That belt is a 11-14 XP 900 belt and a 14 XP 1000 belt part number, it would be ok as a back up and as mentioned, if you have to install in the field I would remove it and install a better one when you can.
Unfortunately we have had less than 5 failures with our belts and nearly 1500 sold and one of the guys commenting is one of the failures so his opinion won't be a good one for us and I get that.
Every belt has it's application and some do better at some activities than others and that sometimes is the trick to figure out.
As a matter of fact, that belt you have might actually perform and last if you only ran high speed for long periods of time due to the fact it is thin and dissipates heat well.
All belts by anyone fail at times, that is one thing we can count on.
Now that we have around 1500 belts out, a handful of folks with over 1000 miles and one I know over 1500 miles on our belts my opinion is pretty simple.
As good as OEM or better depending on the application, less money and has a warranty while limited is still a warranty where the OEM has none.
If you want to argue with that then you just want to argue!! LOL
Todd
buddymc likes this.
www.hunterworks.com
Todd
post #13 of 24 Old September 22nd, 2018, 07:44 AM Thread Starter
Member #260964
Todd
And this is why when I posted this I was thinking damn I canít wait for Todd to reply so I can get the right info
post #14 of 24 Old September 22nd, 2018, 07:49 AM
First Name: Todd
Member #47437
BTW, I am a victim of my own belt and don't mind telling it, I blew the hell outta one in 5 min, had a thick belt on, had a EBS helix I added to my secondary then got on a race track and got some serious air, engine returned nearly to idle being the air so long, EBS notch was engaged when I hit the ground, belt was loose due to what was going on inside at the time, landed and shoved it into the exhaust duct and ripped it to pieces, looked like the piece above. What did I do? Put one of our std belts on and ran the total crap out of it the rest of the day and moved on.
of course the issue was being on a track with a thick belt made for slow tech technical riding and having a engine braking helix on made for the same and then doing something neither worked for.
Application and understanding of clutching is required.
www.hunterworks.com
Todd
post #15 of 24 Old September 22nd, 2018, 07:51 AM
First Name: Todd
Member #47437
And Thanks for understanding Dustin and the comments!!!
www.hunterworks.com
Todd
Positive HW Belt Reviews Racking up!! Hunterworks Hunterworks 0 August 30th, 2018 04:58 AM
Clutch discussion, causes of heat/belt failures (long) cwarner Engine and Drivetrain 19 February 4th, 2018 10:36 AM
Gates RZR Belt Part number confusion Hunterworks Hunterworks 1 March 12th, 2017 06:26 AM
best drive belt for the 2012 polaris 900xp Happynthehollar General RZR Discussion 6 May 10th, 2016 01:50 PM
Replaced drive belt...Will not go into gear Derekwit RZR 800 Specific Discussion 7 May 9th, 2016 07:07 AM
