Banging under front end Please help! - Polaris RZR Forum - RZR Forums.net
 3Likes
post #1 of 26 Old January 11th, 2018, 02:29 PM Thread Starter
PARKERS250R's Avatar
Member #77535
View PARKERS250R's Photo Gallery(0)
Hey there, I have a 2017 1000xp, that has a banging noise under the front end sometimes driverside sometimes passenger side. Sounds like you are throwing up a rock or someone is hitting it with a hammer. Shock bolts are tight, front drive shaft is tight, all a arm bushings are good and a arms are tight. this noise happens driving down a bumpy trail but the suspinsion is not fully extended, ball joints and bearings all good. Rzr drives fine it just sounds like a piece of crap, completely irritating. Please help!!
PARKERS250R is offline
post #2 of 26 Old January 11th, 2018, 02:49 PM
todztoyz's Avatar
My RZR: 14 xp1k
Member #193809
View todztoyz's Photo Gallery(0)
Re: Banging under front end Please help!
Steering rack tight?
todztoyz is offline
post #3 of 26 Old January 11th, 2018, 02:54 PM Thread Starter
Member #77535
yes sir and several people I ride with have the same issue
post #4 of 26 Old January 11th, 2018, 02:55 PM
Dizzledog1's Avatar
First Name: Josh
My RZR: 2016 xp 1000
Member #70121
View Dizzledog1's Photo Gallery(0)
Carrier bearing. Even though it's new they can still go out. Steering rack as suggested above also . Have you checked your tie rod ends?
Dizzledog1 is offline
post #5 of 26 Old January 11th, 2018, 04:15 PM
Addicted
CFDWheeler's Avatar
First Name: Steve
My RZR: 17' White/Reflex Blue XP1k
Member #6186
Feedback Score: 13 reviews
View CFDWheeler's Photo Gallery(0)
Mine does the same thing under suspension droop. I can really feel it in the steering wheel and with my feet. Everything is tight, as I've had it apart a few times. There's less than 200 miles on it. Dealer couldn't find anything either. I'm thinking about putting a camera under there.
2017 1000XP. White w/ Reflex Blue
FUTV UHMW Full skid package; SATV radius rods,
Viper Elite 5K Wide on Bad Dawg front bumper, SATV rear bumper
SSV Works Stereo; Axiom Roof, 30" front LED radius bar
RacerTech Heavy Springs, 32" Carnivores on STI HD9's
XXL Front fenders with Mudbuster Max rear.
IAFF LOCAL 38 Covington KY
CFDWheeler is offline
post #6 of 26 Old January 11th, 2018, 05:28 PM
RickRou56's Avatar
My RZR: 2017 XPT Velocity Blue
Member #28887
View RickRou56's Photo Gallery(0)
Had this on a 14XP. Spring of last year. Steering wheel felt like a homemade go kart when suspension dropped. Pulled on it. And felt like a hammer underneath it.
At the same time I decided to do a full Shock modification.
When I pulled the right front Shock off I found the top bolt loose. Dealer had just put A arm bushings in it week the before.
Go figure!!
When the shocks came back and I reinstalled them. Bang was gone.
So was it bad Shock? Or a loose shock bolt? Guy that did rebuild didnít see anything off in the shock.
Check those shock bolts. Have to have suspension hanging or right at neutral to feel loose bolt. Or just put a couple wrenchís on them.
Fi
RickRou56 is offline
post #7 of 26 Old January 11th, 2018, 05:37 PM
Dewars's Avatar
My RZR: '17 1000xp Gold
Member #212009
View Dewars's Photo Gallery(0)
The front shocks bottom out with a nasty thud with the 2017 front suspension. My Gold LE does it at all speeds when either side drops out. Other than adding limiting straps, I donít think itís easy to get rid of...
timberdawg likes this.
Dewars is offline
post #8 of 26 Old January 11th, 2018, 06:28 PM
WORKINGONJUNK's Avatar
My RZR: RZR41000
Member #77008
View WORKINGONJUNK's Photo Gallery(0)
I know you said the A arm bushings are good , my 14 had a bad bushing (sounded exactly as your description) and took me a bit to figure out which one. Double check those since they are an easy fix. When jacked up are the tires loose ( slop )? If they are , one by one check every joint and bushing for slop.
WORKINGONJUNK is offline
post #9 of 26 Old January 12th, 2018, 08:27 AM Thread Starter
Member #77535
Thanks for all the info, will check all suggestions and reply back, thanks again!!
post #10 of 26 Old January 12th, 2018, 08:37 AM
petedog's Avatar
First Name: Dan
My RZR: 2015 XP 1000 Fox Ed.
Member #156953
View petedog's Photo Gallery(0)
When my front diff went out, it felt like somebody was knocking on my floorboards. I would start there... If the shocks do bottom out, you will feel the same thud. Limiting straps can fix that.
petedog is offline
post #11 of 26 Old January 13th, 2018, 06:49 AM
Hendy's Avatar
First Name: Hendy
My RZR: 2011 RZR 900 XP LE, 2015 XP 1000 High Lifter
Member #19873
View Hendy's Photo Gallery(0)
I had a similar "hammer banging" underneath my 2015 Highlifter. My driver's side rear shock had leaked all of it's oil out. I had the shock rebuilt for about $100, and now it's sounds totally fine.
Hendy is offline
post #12 of 26 Old January 13th, 2018, 03:06 PM
jim v's Avatar
Member #65015
View jim v's Photo Gallery(0)
I thought mine had a bad shock ended up being coolant lines under tunnel cover couple zip ties no more banging
Sent from my SM-G930V using RZRForums.net mobile app
jim v is offline
post #13 of 26 Old January 14th, 2018, 05:57 AM
Florida Yankee's Avatar
Member #231489
View Florida Yankee's Photo Gallery(0)
If all is tight and no noticeable shiny wear, I might think that @ suspension travel, there is something loose. Iíd check all bolts with the suspension to make sure they have washers and are tight to spec.
Maybe lift the front end up in the air with a frame jack and look to see whatís going on under there as the suspension travels. Not being a super consistent noise to me sounds like loose something.
Also if a bushing broke off you will hear metal bang against metal. There is prolly some play in there thatís not being corrected.
Florida Yankee is online now
post #14 of 26 Old January 14th, 2018, 07:58 AM
Vigs07r's Avatar
Member #225913
View Vigs07r's Photo Gallery(0)
Mine will randomly do the same. Sometimes on flat sometimes on bumps. Haven't tracked it down yet.
Sent from my Pixel XL using RZRForums.net mobile app
Vigs07r is offline
post #15 of 26 Old January 28th, 2019, 03:28 PM
btrshoes's Avatar
My RZR: 900S
Member #48027
View btrshoes's Photo Gallery(0)
Resurrecting this, I have this up front too on a 2019 xp 1000 but I installed shock therapy stage 4 kit. Its very random, mine sounds like its on the drivers side most of the time when i hit certain bumps. I also removed my front sway bar, any ideas?
btrshoes is offline
Help with loud clunking coming from the front end. RzrriderX RZR S 900 23 January 28th, 2018 06:55 PM
Parts list for 2018 front end on 2014 XP4 1000? tjZ06 General RZR Discussion 13 December 10th, 2017 02:27 PM
Installed Highlifter helper springs, need to raise front end. oldnslow RZR XP 1000 10 October 2nd, 2017 04:24 AM
Front end sound JerryCanada RZR S 900 4 September 21st, 2016 07:30 PM
Rattle in front end when hill climbing OutbackDuramax RZR XP 1000 6 August 23rd, 2016 10:34 AM
