Changing wheel bearings help - Polaris RZR Forum - RZR Forums.net
 2Likes
post #1 of 20 Old May 2nd, 2017, 05:14 PM Thread Starter
imrede73's Avatar
First Name: kevin
My RZR: 2015 XP1000
Member #38139
View imrede73's Photo Gallery(0)
I have a 2015 xp 1000 and i am in the middle of changing the front wheel bearings, every video i watched they show the bearing comes out the outer side and pressed back in the outer side and thats what polaris parts exploded view shows but from what i can tell mine have to come out and in through the inner side,i ran the numbers on the spindles and they match oem, can anyone shed some light on this for me, i am the 2nd owner and it does have super atv A arms, thanks for any info.
imrede73 is offline
post #2 of 20 Old May 2nd, 2017, 05:21 PM
kfxnow's Avatar
My RZR: 2010 RZR 800
Member #191625
View kfxnow's Photo Gallery(0)
Re: Changing wheel bearings help
2010 800, so YMMV, but mine came out the outside. There is a C-ring that holds them for 'falling out' of the outside. Pull that, then push them out from the inside.
untillater likes this.
kfxnow is offline
post #3 of 20 Old May 2nd, 2017, 05:25 PM
tbg120's Avatar
My RZR: 2015 XP1K
Member #28610
View tbg120's Photo Gallery(0)
They come out and go back in on whatever side the spring clip is on which is I believe the outside.
Sent from my iPhone using Tapatalk Pro
tbg120 is offline
post #4 of 20 Old May 2nd, 2017, 05:34 PM Thread Starter
imrede73's Avatar
First Name: kevin
My RZR: 2015 XP1000
Member #38139
I dont remember what side i took the ring out of, it looks like there is grooves on both sides, plus the new bearing will not fit in the front but will fit in the back thats why im confused.
imrede73 is offline
post #5 of 20 Old May 2nd, 2017, 05:50 PM
tbg120's Avatar
My RZR: 2015 XP1K
Member #28610
I just watched a YouTube video to make sure since my memory isn't that great. The clip comes off the outside (hub) side and is pressed out from the inside.
Mwolf83 likes this.
tbg120 is offline
post #6 of 20 Old May 2nd, 2017, 08:03 PM Thread Starter
imrede73's Avatar
First Name: kevin
My RZR: 2015 XP1000
Member #38139
Unless i got the wrong bearing it will only go in from the back side, it is a moose and i ran the #s and it's supposed to be for my rzr.
imrede73 is offline
post #7 of 20 Old May 2nd, 2017, 09:39 PM
Mwolf83's Avatar
First Name: M
My RZR: 2014 RZR XP1K
Member #58440
View Mwolf83's Photo Gallery(12)
If you happen to have some way to measure it, the outside diameter is supposed to be 2.83". So if that is what it is then you have the correct bearing, if it isn't then the bearing is wrong.
The bearing will be held in by a C-clip/snap ring, on the outside of the hub. It gets pressed out from the inside out. Then the new one is pressed in from the outside in.
Link to a video of the process:
'14 XP1K with lots of stuff
Mwolf83 is offline
post #8 of 20 Old May 3rd, 2017, 02:42 AM
tbg120's Avatar
My RZR: 2015 XP1K
Member #28610
If you do some searching on this forum you will probably find most here prefer and have had the best luck with OEM bearings. I for one have tried several from the aftermarket and have found the OEM the best quality and longest lasting.
Whatever bearing you choose make sure to grease it when you do the install.
tbg120 is offline
post #9 of 20 Old May 3rd, 2017, 06:59 AM Thread Starter
imrede73's Avatar
First Name: kevin
My RZR: 2015 XP1000
Member #38139
Thanks for everyone's input but i am 100% positive my bearings press out from the front because the snap ring was in the back, not sure why its different from the rest but it is.
ID:	419305   Click image for larger version
ID:	419313   Click image for larger version
imrede73 is offline
post #10 of 20 Old May 3rd, 2017, 07:04 AM Thread Starter
imrede73's Avatar
First Name: kevin
My RZR: 2015 XP1000
Member #38139
1st pic is from the front 2 1/2" 2nd pic is the new bearing 2 7/8" 3rd pic is from the back side 2 7/8"
imrede73 is offline
post #11 of 20 Old May 3rd, 2017, 05:11 PM Thread Starter
imrede73's Avatar
First Name: kevin
My RZR: 2015 XP1000
Member #38139
After doing a lot of research apparently i have turbo knuckles, not sure why but the bearings are pressed in from the opposite side than others!Click image for larger version
imrede73 is offline
post #12 of 20 Old May 3rd, 2017, 05:26 PM
Mwolf83's Avatar
First Name: M
Member #58440
That is insane, why would they put different front hubs (Rears are the same as all the others) and bearings on the 2 seat turbo than the 4 seat and every other RZR 1000 out there?! It would be one thing if they were bigger and better bearings, but they're smaller. Polaris does some mindboggling stuff sometimes.
Mwolf83 is offline
post #13 of 20 Old May 3rd, 2017, 05:30 PM Thread Starter
imrede73's Avatar
First Name: kevin
My RZR: 2015 XP1000
Member #38139
Yea definitely weird, haven't pulled the rears yet but will post what i find.
imrede73 is offline
post #14 of 20 Old May 3rd, 2017, 07:06 PM
the_owl's Avatar
Member #33649
View the_owl's Photo Gallery(0)
Id say youre doing it wrong. get a autozone torch and heat the crap out of it. I banged mine with a 2x4 block and a piece of PVC from home depot. Just did them last month
the_owl is offline
post #15 of 20 Old May 3rd, 2017, 07:16 PM Thread Starter
imrede73's Avatar
First Name: kevin
My RZR: 2015 XP1000
Member #38139
I haven't tried yet, gonna bring them to work tomorrow and use our press, i will get them out i was just confused because polaris was showing mine should press out from the inside but thats not the case on mine, i pulled the clips from the backs.
imrede73 is offline
Greasing wheel bearings Rzr800s2009 RZR-S Specific Discussion 71 November 19th, 2017 08:48 AM
2015 Wheel Bearings mattre69 RZR 570 Specific Discussion 31 June 30th, 2017 04:56 AM
Issues changing rear wheel bearings bobbybog Engine and Drivetrain 15 December 8th, 2016 03:12 PM
XP4 1000 Wheel Bearings RWTDCT General RZR Discussion 0 October 29th, 2016 12:16 PM
wheel bearings olddog RZR XP Suspension 2 September 22nd, 2016 07:15 AM
