Engine choking at cruise speed - Polaris RZR Forum - RZR Forums.net
 7Likes
  • 2 Post By RZRNADS
  • 1 Post By dezertBandito
  • 1 Post By mHMFs
  • 1 Post By Eliminator602
  • 2 Post By dezertBandito
post #1 of 14 Old March 22nd, 2017, 09:24 AM Thread Starter
dezertBandito's Avatar
My RZR: xp 1000 fox edition
Member #63545
View dezertBandito's Photo Gallery(0)
Hey Guys, I've tried searching around for a bit and I've seen similar problems on here but most are at WOT. This seems like the car is running out of gas or not getting enough air. The engine kinda chokes out for a second, goes away chokes out, wash rinse repeat. This seems to happen at near mid speed mid throttle, where I'm thinking the clutch might be in a higher gear but not higher rpm. As soon as I stab the gas the problem goes right away. I'm nearing my second service level and I've got about 1,000 miles on my 2015 rzr.
Anyone experience anything similar? Did anyone have any luck going to dealer? I've got the extended warranty, but nervous about taking it in as I have the last trip of the season coming up in a couple weeks.
dezertBandito is offline
post #2 of 14 Old March 22nd, 2017, 12:04 PM
Dizzledog1's Avatar
First Name: Josh
My RZR: 2016 xp 1000
Member #70121
View Dizzledog1's Photo Gallery(0)
Re: Engine choking at cruise speed
Tps sensor ? Any codes come and go?
Dizzledog1 is offline
post #3 of 14 Old March 22nd, 2017, 12:08 PM Thread Starter
Member #63545
Not that I've seen.. at least they dont stay to a stopping point.
post #4 of 14 Old March 22nd, 2017, 02:41 PM
Clubin's Avatar
First Name: Clayton
My RZR: XPT
Member #61303
Fuel pump? Sounds like it may be possible fuel pump isn't generating enough pressure.
2016 XPT
EVO stage 2
EVO captains choice exhaust
EVO charge tube
OSP clutch kit
Rockford Fosgate Stage 4
STI HD5's 31/10.50/15 Super Swamper IROC'S
Clubin is offline
post #5 of 14 Old March 22nd, 2017, 02:48 PM Thread Starter
Member #63545
But then why would it work like a champ as soon as you give it more gas?
post #6 of 14 Old March 22nd, 2017, 03:29 PM
RZRNADS's Avatar
First Name: Rod
My RZR: 2013 RZR 900XP WE EPS
Member #162881
View RZRNADS's Photo Gallery(0)
Sounds to me,very likely you got a load of junk gas.I'd top it off with premium and see if it will burn out.
Expat and Motoman314 like this.
RZRNADS is offline
post #7 of 14 Old March 22nd, 2017, 07:53 PM
CaseyK's Avatar
First Name: Casey
My RZR: Xp1K
Member #65900
View CaseyK's Photo Gallery(0)
I'd bet it's the purple wire at the tps sensor
CaseyK is offline
post #8 of 14 Old March 23rd, 2017, 09:15 AM Thread Starter
Member #63545
I suppose that's possible based on the fact that i've filled from the toy hauler a few times..
Other than that i only ever put premium in it..
RZRNADS likes this.
post #9 of 14 Old March 23rd, 2017, 09:41 AM
mHMFs's Avatar
My RZR: 2015 900 S
Member #5186
View mHMFs's Photo Gallery(0)
Check injector wiring harness right where it plugs into the injectors and Check MAP sensor wires on the passenger side just behind the head. These are both known spots where many have had broken/bad connections in the harness. These are also problems that can cause symptoms you describe. I have fixed 2 MAP sensor harnesses and 2 of my friends have had to fix injector harnesses. Both that I fixed were revealed by the "wiggle test". With engine idling wiggle the wires at these locations. Chances are you will here a change in the way the engine runs indicating you found the problem. Hope its one of these as they are easy fixes.
Motoman314 likes this.
mHMFs is offline
post #10 of 14 Old March 25th, 2017, 01:29 PM Thread Starter
Member #63545
I think you hit the nail here I believe this is the MAP sensor. but wiggiling these wires will kill the engine at idle. whats the fix?
post #11 of 14 Old March 27th, 2017, 04:19 AM
mHMFs's Avatar
My RZR: 2015 900 S
Member #5186
Yep that's it. Both that I worked on had broken wires near the connector, under the insulation so I had to cut the wires and fix the connections. Can be kind of difficult because you don't have much slack in the wire to work with but its not all that bad. Squeeze the wires in different spots. You'll probably find a soft spot indicating the break.
mHMFs is offline
post #12 of 14 Old March 27th, 2017, 06:05 AM
Eliminator602's Avatar
First Name: Dickhead
Member #62539
View Eliminator602's Photo Gallery(0)
This
https://otbpowersports.com/product/t...epair-harness/
dezertBandito likes this.
Eliminator602 is offline
post #13 of 14 Old March 27th, 2017, 06:29 AM
mHMFs's Avatar
My RZR: 2015 900 S
Member #5186
Yeah good call pay the money. Its worth it to not have to try & fight with the short wires. Saving that link for the next one I run into. Thanks for that.
mHMFs is offline
post #14 of 14 Old April 4th, 2017, 03:42 PM Thread Starter
Member #63545
Wow, that was dead nuts accurate, Thank you so much for the info. I went out this weekend and was showing my group the issue. Sure as shit as I did that, the purple wire broke off in my fingers.. we took the connector apart with a paper clip and cut apart a ring terminal to sacrifice the crimp and crimped the purple wire back on. The problem was gone all weekend. Now I simply need to get it into a dealer and tell them to fix it.. wonder how they will do it...
Motoman314 and RZRNADS like this.
2017 XP1K Timing Chain Tensioner - I Think Polaris Fixed It! Sshsjd10 RZR XP 1000 89 September 28th, 2018 01:12 PM
Deeper Explanation of Shift RPM Hunterworks Hunterworks 18 June 13th, 2017 06:55 AM
280hp 07' Turbo R1 Engine Complete for sale!!! BigFanFoam General RZR Discussion 0 March 6th, 2016 04:59 PM
polaris 4014934 vane sensor new slumper1 Polaris RZR Parts For Sale 5 November 23rd, 2015 06:09 AM
