XP1000 Suspension set ups! - Polaris RZR Forum - RZR Forums.net
 19Likes
post #1 of 1149 Old August 18th, 2014, 05:24 PM Thread Starter
Ed, The Suspension Guy
Pound Sand's Avatar
First Name: Ed
My RZR: Xp1000, XP900
Member #12748
View Pound Sand's Photo Gallery(0)
What up UTV owners!
I apologize ahead of time, if I break any rules here! Just spreading the good word on advice from owners. Last post here was 4 years ago! I'm not a big Internet site type guy, I'm on Glamis dunes sometimes, and that's about it! To busy working and playing!
I'm "The Suspension Guy". I set up big off road dez and sand cars, but in the last few years, the UTV market has exploded and I have found myself working on these almost as much as big cars now days! I own a polaris xp900, and xp1000 that are used often to test and play.
I'm a King and Walker Evans dealer and I'm into making thier products work well for the racer or recreational user.
But of course, I work on all popular brand shocks!
I put all this stuff to the test! I drive it at the sand, the dez and the track, always trying to make it better! So, if its just cruising the dez, or racing around Glamis, it gets tuned to fit the the way you drive! I don't "copy" anyone's work! No need to! It's all my own!
I often have demo shocks for the xp1000 and 900, or you can come out and drive one of mine!
Sometimes you don't realize how much better your car can handle till you drive one with an optimum set up!
Hope to chat soon!
Thanks,
Ed
[email protected]
714-343-3399
Pound Sand is offline
post #2 of 1149 Old August 18th, 2014, 09:09 PM Thread Starter
Pound Sand's Avatar
First Name: Ed
Member #12748
Re: XP1000 Suspension set ups!
Xp1000, Front, Walker Evans, 2.5 Dual Rate spring needles ! These leave your stock 2.0 fronts in the dust! I have lots of hours of testing into these, and I valve them to be plush in the rough, while still having great bottom out resistance and way less fade as compared to the poor stock 2.0s
post #3 of 1149 Old August 18th, 2014, 09:14 PM Thread Starter
Pound Sand's Avatar
First Name: Ed
Member #12748
2.5 fronts
post #4 of 1149 Old August 18th, 2014, 09:24 PM Thread Starter
Pound Sand's Avatar
First Name: Ed
Member #12748
These King IBP are the cream of the crop! 2.5 front and rear. Talk about a butter smooth ride! I valve these to be smoother in the beginning movement, and firmer on the ends! So just when you think they are to soft to get aggressive, they firm up when they should! These are truly confidence builders!
post #5 of 1149 Old August 18th, 2014, 09:28 PM Thread Starter
Pound Sand's Avatar
First Name: Ed
Member #12748
King 2.5 IBP front, xp1000
post #6 of 1149 Old August 18th, 2014, 09:30 PM
dartersracing's Avatar
First Name: DONNY
My RZR: 2014 PACE Z1 1000
Member #19554
Feedback Score: 15 reviews
pm me price for some king's for my xp1k..thanks
209-373-5336 DONNY DARTER
dartersracing is offline
post #7 of 1149 Old August 18th, 2014, 09:35 PM Thread Starter
Pound Sand's Avatar
First Name: Ed
Member #12748
You have internal valving control on both compression and rebound on the bipass portion of the shock. Two compression stacks, as well as two rebound valve stacks in each King IBP as well as the external adjuster.
post #8 of 1149 Old August 18th, 2014, 09:48 PM Thread Starter
Pound Sand's Avatar
First Name: Ed
Member #12748
Every set up gets tested. Because one set up definitely does not fit all drivers! Lots of valving recipes are needed for all sorts of drivers for either the track, dez or sand, or a combination!
M06450rrider likes this.
post #9 of 1149 Old August 19th, 2014, 10:51 AM Thread Starter
Pound Sand's Avatar
First Name: Ed
Member #12748
And don't forget about the stock shocks! They can be revalved to work a ton better than the stock valving!
You get the most bang for your buck by valving the shock to work the way you want! The valving that comes stock was decided by Polaris management and engineers (not Walker Evans) to fit a wide wide range of driving and conditions. So it's far from the best it can be.
The magic is in the valving! You can spend a lot of money on just springs and other hardware, but that is only a portion of the pie and gets you only limited results! I have valving recipes that will work with just your stock springs to help keep the cost down and get real results!!
If you want to go that extra yard, then you can add springs, and crossovers to compliment your valving recipe! Just adding crossovers to the front stock 2.0 shock, and using the stock springs will make a huge handling difference! Body roll is drastically reduced and actually helps the rear stay planted and car run level with the revalved rear shocks.
All this can be done without spending a ton of cash! But don't get pulled into spending a ton of money on the front 2.0s, in my opinion, when for a little more, you can simply upgrade to the 2.5 walker Evans needles with all the good stuff, that I custom valve. Then your DONE! Revalve the rear, stock springs. Run it!!! And enjoy your machine that much more!!
post #10 of 1149 Old August 19th, 2014, 11:04 AM
That One Guy's Avatar
Member #68731
View That One Guy's Photo Gallery(0)
This guy knows his stuff! Ed has been the go to guy for all of the high end sand rails in Glamis for years and is now working miracles with theses stock rzr shocks. Highly recommended!
That One Guy is offline
post #11 of 1149 Old August 19th, 2014, 11:21 AM
AJsRZR's Avatar
Member #30576
Feedback Score: 12 reviews
View AJsRZR's Photo Gallery(0)
How much for new 2.5 fronts and my stock rear shocks re valved? Setup for trail riding and rock crawling.
Sent from my SCH-I545 using Tapatalk 2
2010 LE Flat Black 800 Turbo with +6 Long Travel
Kit
AJsRZR is offline
post #12 of 1149 Old August 19th, 2014, 11:29 AM
Thunder45's Avatar
Member #2071
View Thunder45's Photo Gallery(0)
I would be interested in the front 2.5's also pm me price please.
Thunder45 is offline
post #13 of 1149 Old August 19th, 2014, 02:41 PM
desertfox's Avatar
My RZR: 2016 1000XP4/2017 900 Trail
Member #12425
View desertfox's Photo Gallery(0)
Same question, Cost of... Front 2.5's and revalve the rear WE. I have the Racertech heavy desert springs on it. Ride hard and fast in the lower AZ deserts. Also, whats the cost of a complete set of 4 kings? Thanks
desertfox is offline
post #14 of 1149 Old August 19th, 2014, 03:32 PM
Smkngstv's Avatar
First Name: steve
My RZR: 2014 rzr 1000
Member #70357
View Smkngstv's Photo Gallery(0)
do you only do shock set up for desert ,what about mud riding,up here in alberta our sand is full of oil so not very good to ride on lol,where i ride its 60 % trail and 40 % mudding.what can we do to enhance the ride and still hit the big mud holes,i like what you are saying about less roll and the rear tires staying planted.can you set these up so they just bolt on and go
Smkngstv is offline
post #15 of 1149 Old August 19th, 2014, 03:37 PM
sandfreak's Avatar
First Name: Don
Member #21329
View sandfreak's Photo Gallery(0)
I thought you had your heart set on badass internal bypass Fox's?
sandfreak is offline
FCR Suspension rework review on Xp1000 edge22 RZR XP 1000 34 July 10th, 2014 04:57 AM
Xp1000 4 suspension setup supt8513 RZR XP 4 1000 4 March 30th, 2014 11:00 PM
Complete Stock Xp1000 Suspension Minus Shocks Naatv Polaris RZR Parts For Sale 0 March 26th, 2014 07:05 PM
