Throttle Mapping (Limiting) Occurring In Both Low and High Range - Page 2 - Polaris RZR Forum - RZR Forums.net
RZR XP 1000 Trails & Rocks LE Forum Discussions related to the RZR XP 1000 Trails & Rocks LE Edition
 11Likes
post #16 of 16 Old April 4th, 2019, 04:32 AM
XMARGH's Avatar
My RZR: 2019 RZR Turbo S Velocity
Member #241850
Re: Throttle Mapping (Limiting) Occurring In Both Low and High Range
Originally Posted by bluetoad7 View Post
Originally Posted by XMARGH View Post
The Highlifter also shares the same throttle mapping as the TRE. I personally love the throttle mapping in Low for tight technical areas, if the throttle is too jumpy you can get yourself in trouble no matter how good of a driver you think you are.
With that said, something is keeping that machine from reaching the proper shift out. You should be seeing 8K+ Shiftout then slowly climbing to the rev limiter. Even on 33" Tires on stock clutching I'm hitting 8K rpm shift out. You've got a lot of miles on your clutches though at 5K. Can you confirm the parts are not wore beyond spec? When it hits the shiftout does it continue to climb or just hold at that rpm?
As I said in the first post, it did this before and after I replaced the Primary with a new Polaris P-85 clutch with a Dalton oversize tire clutch kit and a new Hunterworks belt. It revs (in both low and high gear) to 7500 rpm and lays down to about 6500 rpm, then will shift slowly out by milking the throttle to get about 55 mph, but still only at 6800 to 6900 rpm. I've had the secondary apart to check the rollers and replace the helix with the Dalton helix. All looks well in the secondary. I had installed new Hunterworks rollers in place of the square pucks when the machine was new. All rollers are still at "new" specs. I am inclined to think this is throttle mapping, but have no way to verify this. My buddly's 2017 TRE is doing nearly the same thing with 55 mph being his top speed also.
I'm well aware of speed limiters, on my HLE it is 70MPH the throttle plate closes up. It would be interesting to see you have that machine tuned to see the difference.
Shawn
XMARGH YouTube Channel
XMARGH is offline
2015 trail edition high and low range questions RebelRZRrider RZR 900 - 50'' Trail Models 16 November 21st, 2016 08:17 PM
noise when in high range when u let off the throttle Jring General RZR Discussion 6 August 22nd, 2013 09:28 AM
High or Low range Jeepz RZR-S Specific Discussion 14 July 22nd, 2012 12:16 PM
Low or High Range? RdRunner Engine and Drivetrain 3 June 20th, 2010 08:30 AM
High or Low Range For Mud HivoltageRZR General RZR Discussion 13 October 12th, 2009 07:47 PM
