Top Speed - Polaris RZR Forum - RZR Forums.net
 3Likes
  • 1 Post By Rockymtn5280
  • 1 Post By Wtrskinut1
  • 1 Post By Highrider
post #1 of 13 Old August 24th, 2019, 12:41 PM Thread Starter
Wtrskinut1's Avatar
Member #271790
View Wtrskinut1's Photo Gallery(0)
Top Speed
Just getting to the broke in point. Tried a wide open run today 9200RPM and 62MPH. Seems off, is the rocks and trails clutched differently?
Wtrskinut1 is offline
post #2 of 13 Old August 24th, 2019, 01:31 PM
Rockymtn5280's Avatar
My RZR: 2018 RZR 1000 TRE
Member #223457
Re: Top Speed
I've had mine up to 65. Don't know RPM.
That's fast enough for me on the places I have had my TRE.
Did not buy my TRE for top speed. Bought it for what it does at low speed. And it does that extremely well.
RZR_Scott likes this.
Rockymtn5280 is offline
post #3 of 13 Old August 24th, 2019, 01:47 PM
BWXT's Avatar
My RZR: 2018 XP1000 Black
Member #241858
View BWXT's Photo Gallery(0)
Re: Top Speed
It has been my understanding that the TRE is geared the same in high as the regular XP1K. If that is true, something is amiss with yours. I hit 80mph last weekend with mine. Had to lift at that point cause I was running out of road, but I never felt the rev limiter. Seemed like it was still pulling. Even if it is geared a little lower, I think it should do more than 62. My buddy’s 800 tops out at 63.
BWXT is offline
post #4 of 13 Old August 24th, 2019, 02:21 PM Thread Starter
Wtrskinut1's Avatar
Member #271790
Re: Top Speed
That's what I thought. Back to the dealer I guess. I am not worried about top speed, very seldom will go over 50, but if it should go 80 it is going to go 80!!
post #5 of 13 Old August 24th, 2019, 02:24 PM
superjunior's Avatar
First Name: Dan
My RZR: 2015 900S
Member #74479
Re: Top Speed
62 does seem kinda low, I've had my 900S up to 75. I dont know a whole lot about the trails and rocks edition but there are 2 in our group, but we rarely go over 50 on the trails
superjunior is offline
post #6 of 13 Old August 24th, 2019, 03:33 PM
Aspiring Perfectionist
RWB713's Avatar
First Name: Richard
My RZR: 2018 XP4 Turbo
Member #70552
Re: Top Speed
You should be way higher than 62, I’d geared lower than the T&R I believe and can still hit around 80 at 8600 rpm....do you have a tuner? I didn’t think the rev limit was that high in a 1K...
2018 XPT4 - Bailey
RWB713 is online now
post #7 of 13 Old August 24th, 2019, 05:24 PM
GPS GURU
702youngbergs's Avatar
My RZR: 2019 XP1000 RC
Member #269632
View 702youngbergs's Photo Gallery(0)
I am thinking elevation has a lot to do with your top speed, our xp4 hasn’t seen a shade over 72 on level +/- pavement. With 92 octane and clean filters, I was told they were governed at 84 but it would take a hurricane for a tail wind to hit that in this desert
702youngbergs is offline
post #8 of 13 Old August 24th, 2019, 05:38 PM
Michigan man's Avatar
First Name: Dan
My RZR: 2019 xpt titanium
Member #130625
Re: Top Speed
62mph is low.....and 9200rpm is high, too high
AA level 2 tune, S2 clutch kit, half tinted windshield, polaris roof. Polaris lower doors, fang light kit, with more to come
Michigan man is offline
post #9 of 13 Old August 25th, 2019, 08:01 AM Thread Starter
Wtrskinut1's Avatar
Member #271790
Re: Top Speed
Pulled the clutch cover off. The spider nut is totally off. This forum is a vast supply of helpful knowledge.
RWB713 likes this.
post #10 of 13 Old August 25th, 2019, 11:29 AM
Dirt-junkie's Avatar
Member #246626
View Dirt-junkie's Photo Gallery(0)
Top speed for my 2017 xp4 1000 ends up at 67 maybe 68 miles an hour which is very annoying. I'm also at around 8700 RPM which I understand is way too high
Dirt-junkie is offline
post #11 of 13 Old August 25th, 2019, 12:39 PM
BWXT's Avatar
Member #241858
Re: Top Speed
Kinda curious you guys with the low top speeds; Did you ever change out the square pucks in the secondary? Also how many miles?
BWXT is offline
post #12 of 13 Old August 25th, 2019, 04:16 PM
NVERL8's Avatar
Member #222041
View NVERL8's Photo Gallery(0)
Was just going to ask about the spider nut. We found one off on my brother in laws highlifter last week. Same type of issue.
NVERL8 is offline
post #13 of 13 Old August 26th, 2019, 07:59 AM
Highrider's Avatar
Member #54711
Re: Top Speed
2019 T&R 815 miles elevation @ 7800' can top 8350 RPM and 75ish MPH ( stock set-up from the dealer)
The T&R is geared the same as a standard XP1000 in high range.
If your dealer is a good dealer he will change the weights ( If required-at a minimum) and set up the car for the recommended elevation (dealer location)
I cannot get the performance out of my RZR if it had weights/springs for flatlander elevation,way to heavy for the lack of air up here.
Allot of testing and dealer time is spent to set (dealer prep) the car up for the elevation where it is to be ridden...
Max H likes this.
2019 XP 1000 Trails and Rocks
Highrider is offline
