Anyone else cutting tires? Patterns? - Polaris RZR Forum - RZR Forums.net
 2Likes
  • 1 Post By Trailratedcj7
  • 1 Post By 442raceRZR
post #1 of 9 Old May 20th, 2019, 11:06 AM Thread Starter
Trailratedcj7's Avatar
First Name: Ted
My RZR: XP1K Gold Matte Crawler
Member #57325
View Trailratedcj7's Photo Gallery(0)
Started grooving my tires a couple of years ago to sharpen up my tires to get a bit better bite out of our tires.
It has seemed to help a lot but I was curious if anyone else is trying it and does anyone have any other tips?
These are my proarmor XG's.
I need to try siping a bit as well but haven't gotten that far.
ID:	577344   Click image for larger version
17' 1000 XP LE Gold Matte Crawler
Sold 13' 900 XP LE Orange Madness
Trailratedcj7 is online now
post #2 of 9 Old May 20th, 2019, 11:47 AM
442raceRZR's Avatar
My RZR: 2009 RZR 800 S
Member #264074
Re: Anyone else cutting tires? Patterns?
You will get some more "bite" but at the expense of wear. We race and asked our tire grooving expert from trophy trucks to short courses and said tire pressure above all on UTV's affects handling and traction the most.
AMA D38 - Sportsman UTV
Windansea Coffee / Mass Depot / MassFX / Frank Motors / Blud Lubricants / GL Performance Coatings / M&M Offroad / Big Gun Exhaust / TireJect / RynoPower / SuperATV.com / AG Sandcars / Filterwears / Austin Hose
2009 Polaris RZR 800S
442raceRZR is offline
post #3 of 9 Old May 20th, 2019, 11:56 AM Thread Starter
First Name: Ted
Member #57325
Yes I agree that air pressure is my biggest asset. For crawling I am running 4 psi but I did notice a big change in traction with the right grooves.
I absolutely agree tire wear goes up but to me its worth the expense. For the little bit I run our machine by the time I wear out a set of tires the next latest and greatest tire had just been released.
I haven't played with siping because of chunking concerns with too soft of a tire compound. Just the grooving I haven't seen much chunking. I would think on slick rock like I run in MOAB that siping would increase traction as well.
442raceRZR likes this.
post #4 of 9 Old May 20th, 2019, 12:24 PM
442raceRZR's Avatar
Member #264074
Siping is common on ice/snow. For rock, if it's slick you want a sticky contact patch so more grooves are going to give you less traction. However, if you're looking for grip in loose rocks or lips/jagged edges, the grooving will work best.
post #5 of 9 Old May 20th, 2019, 02:26 PM Thread Starter
First Name: Ted
Member #57325
Yes snow and Ice around here is where I learned to sipe and stud.
The gravel type stuff on Behind the Rocks and Pritchett is where I could tell a difference so your comment is true based on my small experiment.
I only started the thread as a couple of guys at MOAB Rim noticed the grooving in my tires and were intrigued over grooving and I hadn't seen too many others doing it.
I only have one more season on these tires so I am intrigued to see how the outside lugs hold up. Most of the grooving I have done is to sharpen the existing pattern on the tires without opening them up too much. The rears I made the cuts to the face of the center lugs as the factory siping was gone but I didnt notice a huge difference in it as they were really shallow grooves.
Probably a waste of time but it gives me something else to do in the shop on our long crappy winters in Wisconsin.
post #6 of 9 Old May 20th, 2019, 10:34 PM
SNWMBL's Avatar
First Name: Caleb
Member #207521
I have a set of Interco LTB’s I grooved extensively and they work awesome.
2017 RZR XP4 1000
Alaska UTV Fab LLC
Instagram: alaska_utv_fab
FOR SALE
- Hunterworks secondary rollers, set of 2, $35 shipped
- Sinister Fabrication A pillar bungs, set of 2, $45 shipped
SNWMBL is offline
post #7 of 9 Old May 22nd, 2019, 12:14 PM
442raceRZR's Avatar
Member #264074
If the tires are toast... grove em for sure. Tires are good. I wouldn't.
Dwight45 likes this.
post #8 of 9 Old June 2nd, 2019, 03:23 PM
Irondogracer's Avatar
First Name: Rob
My RZR: 2017 XP1000 Gold Matte, 2011 Ranger XP 800 LE, 2009 Ranger XP700, 2012 Yamaha 700EPS
Member #98841
View Irondogracer's Photo Gallery(0)
What is the differnece between siping and grooving?
Irondogracer is offline
post #9 of 9 Old June 2nd, 2019, 08:58 PM
SNWMBL's Avatar
First Name: Caleb
Member #207521
Siping is essentially cutting slits in the tread. All the little slits in your automotive tires would be sipes.
Grooving refers to opening up the voids between tread blocks or removing chunks of rubber from a tread block to make multiple tread blocks. Can also just mean removing the tread wear bars.
Google “off road tire grooving” and you’ll get a plethora of images.
2017 RZR XP4 1000
Alaska UTV Fab LLC
FOR SALE
SNWMBL is offline
Truck/SUV: Atturo Off-Road Tires | Now Available at Discount Tire Direct Discount Tire Discount Tire 0 December 5th, 2016 12:21 PM
Going to Baja on GMZ tires. NIKAL Wheels and Tires 23 September 21st, 2015 06:50 PM
My Sand Tire Experience VailAve General RZR Discussion 3 September 7th, 2013 10:36 AM
LT tires, or Trailer tires... Whats best ? allcool Tow Rigs, Trailers and Camping 19 April 17th, 2012 11:03 AM
Pit Bull Growler Tires Part 2 LouDiamond Wheels and Tires 41 October 18th, 2010 08:09 PM
