Seat adjuster - Polaris RZR Forum - RZR Forums.net
 1Likes
  • 1 Post By Highrider
post #1 of 8 Old April 16th, 2019, 08:09 AM Thread Starter
Highrider's Avatar
Member #54711
Seat adjuster
This might be already known- but ran across this and bought one to put under the passenger seat, that is non movable in the 2019 T&R edition.
Strange that this is not put on from factory as it is standard on othere RZR's but not all.
Anyhoo wanted to share...https://rzr.polaris.com/en-us/shop/a...seats/2879460/
2019 XP 1000 Trails and Rocks
2015 XP 1000.
Dealer for :
Mower Adjustable Glass Windshield
www.sxswindshields.com
Highrider is offline
post #2 of 8 Old April 16th, 2019, 03:21 PM
Rockymtn5280's Avatar
My RZR: 2018 RZR 1000 TRE
Member #223457
Re: Seat adjuster
I've kicked around the idea of adding the pass seat adjuster. Wife is OK with the fixed position.
Always kind of wondered why the TRE did not get a pass seat adjuster. Of course if it was as sloppy as my drivers seat, no wonder.
Had to take mine apart to tighten the bolts & nuts since it was so loose. Took it to the dealer and tried to get it covered under warranty since my drivers seat was so sloppy. Jerked back and forth about an inch when locked in any position. Dealer said "that's normal"
No! Its not if the fasteners are tightened correctly. T27 torx and a 10mm wrench is all it took. No more loose drivers seat and the slider works better.
Rockymtn5280 is offline
post #3 of 8 Old May 6th, 2019, 08:01 AM
Pro4driver's Avatar
My RZR: Trails & Rocks Edition
Member #261784
View Pro4driver's Photo Gallery(0)
Usa Re: Seat adjuster Flexing
I'm a big guy and the seat base and or seat flexes too much for me. I like the adjustable seat, but can't stand the seat squeaking and moving around so much like it's not secured. I added washers to my slider bolts that fit over the bushing that lets the seat slide. That allows me to bolt it down tight where it no longer slides at all. The washers take about half that slop out. It's not for everyone, but it works for me until I find a better solution that doesn't eat up a $100 bill. If that doesn't satisfy me over time I'll eliminate the slider or swap it to the passenger side. I always keep my seat to the rear anyway.
Pro4driver is offline
post #4 of 8 Old May 20th, 2019, 07:15 AM
Trailratedcj7's Avatar
First Name: Ted
My RZR: XP1K Gold Matte Crawler
Member #57325
View Trailratedcj7's Photo Gallery(0)
Re: Seat adjuster
For me the adjustment isnt worth the slop and play in the base. I didn't get to it yet but I was actually disable mine by changing something so its solid. My wife and I are the same height and no one else drives it so no need to adjust it.
17' 1000 XP LE Gold Matte Crawler
Sold 13' 900 XP LE Orange Madness
Trailratedcj7 is offline
post #5 of 8 Old May 20th, 2019, 07:51 AM Thread Starter
Highrider's Avatar
Member #54711
Re: Seat adjuster
My lady is alot shorter than I, so switching back and forth we needed the option.
I see some have issues with seat slop? I have zero side to side movement.
2015 XP 1000.
Dealer for :
post #6 of 8 Old May 20th, 2019, 08:01 AM
First Name: Ted
Member #57325
Re: Seat adjuster
Put a few miles on it and you will. I only have 400 miles on mine and its terrible. To be fair its 400 miles of MOAB trails which is no trail ride situation and I am 260lbs.
post #7 of 8 Old May 20th, 2019, 10:28 PM Thread Starter
Highrider's Avatar
Member #54711
Re: Seat adjuster
750 miles and it's tight as frog skin- 220 lbs and no smooth miles seen so far .
Guess I got a Wednesday build ..LOL
2015 XP 1000.
Dealer for :
post #8 of 8 Old May 20th, 2019, 10:31 PM Thread Starter
Highrider's Avatar
Member #54711
Re: Seat adjuster
But to be fair I have never even sat in the junk stock seats from day one either.
Attachment 577358
D11 likes this.
2015 XP 1000.
Dealer for :
The New Polaris Seats are in At Rosedale Motorsports FJK Rose-dale Motorsports 38 August 2nd, 2018 11:21 AM
RZR 570/800 Seat Adjuster Installation Picklez Projects and How-To 0 October 27th, 2016 10:38 AM
rzr 1000 seats charlie78 RZR 570 Specific Discussion 7 September 16th, 2016 06:11 AM
UTV Inc Seat lowering bases longtravel05 Polaris RZR Parts For Sale 3 July 26th, 2016 09:39 PM
PRP Heated Bench RZR S Seat Review.... ..stiffler.. General RZR Discussion 45 November 12th, 2014 06:51 PM
