RzrAid Tender Springs - Polaris RZR Forum - RZR Forums.net
RZR XP 1000 High Lifter Edition Discussions related to the RZR XP 1000 High Lifter Edition.
 3Likes
post #1 of 17 Old August 7th, 2019, 08:36 PM Thread Starter
Pebbleprincess's Avatar
First Name: Whit
My RZR: '19 Rzr XP4 HL, '13 570 LE
Member #42445
View Pebbleprincess's Photo Gallery(0)
So has anyone utilized the RzrAid tender springs for any length of time. After coming from a highly modified suspension on my last Rzr Im trying to keep it simple on my new HL4. Just wanting to know if they are worth trying. I mainly ride OK/TX, so trails, mud, and basic rocks. Not a dune rider.
Young Enough to Play, Old Enough to Pay
'19 XP4 HL
'13 570 LE
Pebbleprincess is online now
post #2 of 17 Old August 7th, 2019, 09:06 PM
bigvic's Avatar
Member #26552
View bigvic's Photo Gallery(0)
Re: RzrAid Tender Springs
Been running mine for a year, and i can say that was probably one of the best mods I made to date...especially for only $230.
They were a little too stiff when I first put them on, but have since worn in to a sweet spot.
slomo likes this.
bigvic is offline
post #3 of 17 Old August 8th, 2019, 01:47 PM
MAXPOWER's Avatar
Member #265648
View MAXPOWER's Photo Gallery(0)
I live and ride in Oklahoma and have a set of rzraid springs on my 2016 xpt. I cannot tell you about long term as I only have about 400 miles on them. They have been awesome with a huge improvement in ride plushness and ride height. I have been to crossbar ranch, little Sahara and mulberry in Arkansas with them..... No complaints.
MAXPOWER is online now
post #4 of 17 Old August 8th, 2019, 05:46 PM
credwine's Avatar
Member #265902
View credwine's Photo Gallery(0)
I've had mine for about 6 months. Big difference over stock. Probably no where close to a shock therapy overhaul but for $230 bucks, it is well worth it. The wife was the one who noticed it more. It also helped raise it up a bit more as well for a more aggressive looking mud machine. Get em, you won't regret it.
credwine is offline
post #5 of 17 Old August 8th, 2019, 06:27 PM Thread Starter
First Name: Whit
Member #42445
Awesome, thank you everyone for the feedback. Order placed.
'19 XP4 HL
'13 570 LE
post #6 of 17 Old August 10th, 2019, 12:51 PM
Pat H's Avatar
First Name: Pat
My RZR: 2018 1000 XP4 Ride Command Edition. 2018 RZR XP1k Ride Command 2 seat
Member #211553
View Pat H's Photo Gallery(0)
1200 miles on mine. Im just a trail rider and they work just fine for me. If I were a duner, Id maybe consider more in depth work. Notta duner so they work on both my RZRs
Im at 16.5 clearance. Spare tire and Isota box is stuffed full of tools, parts and a 2 ton bottle jack. It would take a couple pretty healthy Men to lift that box with its contents!!!
Pat H is offline
post #7 of 17 Old August 22nd, 2019, 03:38 AM
XMARGH's Avatar
Member #241850
Since this review, I put a full year worth of riding on them. One of the best modifications I did to my XP1K HLE. Great ride and a lift at the same time. I actually removed the tenders prior to trading in my HLE and they are now installed on another HLE. Well worth every dollar.
One thing I did not touch base in on the video is the fact to make sure you have the ends of the springs lined up 180 degrees apart from each other. You will see the arrows on the black spacer. I didn't do this and noticed I was binding the springs to one side of the shock assembly.
ramairs801 likes this.
Shawn
2019 Polaris RZR Turbo S Velocity(on order)
XMARGH YouTube Channel
XMARGH is offline
post #8 of 17 Old August 22nd, 2019, 04:34 AM
Jollish3076's Avatar
First Name: Jason
My RZR: 2019 RZR XP4 1000 High Lifter
Member #266130
View Jollish3076's Photo Gallery(0)
Originally Posted by XMARGH View Post
https://youtu.be/ls289qXIQ_A
@XMARGH Your video was the little push it took to convince me to purchase these tender springs. Have not had the machine out on a real trail ride yet, but I can tell from just running up and down our lane and around the property the ride is better for sure.
2019 XP4 1000 HLE
Jollish3076 is offline
post #9 of 17 Old August 22nd, 2019, 05:58 AM
XMARGH's Avatar
Member #241850
I found my '18 HLE to be far too rough for my liking while trail riding, I think once you really get on it through some bumps you'll see a big difference.
Shawn
XMARGH is offline
post #10 of 17 Old August 22nd, 2019, 06:29 AM Thread Starter
First Name: Whit
Member #42445
I have a set ordered and will make sure to take some measurements before and after install. Looking forward to completing my build and actually getting some riding done.
'19 XP4 HL
'13 570 LE
post #11 of 17 Old August 22nd, 2019, 07:38 AM
vtprairie's Avatar
Member #70416
View vtprairie's Photo Gallery(0)
Love mine have had them on my 1000s for about 1300 miles with my 30's and springs my GC and handling is great. For the money best thing I added to my machine for sure.
2016 RZR 900 Trail EPS
2017 RZR 1000S
vtprairie is offline
post #12 of 17 Old August 22nd, 2019, 01:00 PM
Ohv wildcat's Avatar
My RZR: 15 XP1000 Fox
Member #80199
View Ohv wildcat's Photo Gallery(4)
So, what happens when you hit a big bump? I guess you wouldn't start using your main suspension spring until the tenders are coil bound, right? So the first 4" of travel or so is very soft--any worries about sway/rolling in the corners? My machine needs help on the ride--my Fox's are completely coil-bound.
Ohv wildcat is offline
post #13 of 17 Old August 22nd, 2019, 01:38 PM
XMARGH's Avatar
Member #241850
If your goal is to retain a low center of gravity and a plush ride then be gentle on the amount of preload you set. You can't have Ground Clearance and a Low Center of gravity, something has to give. I did not find that my suspension was negatively impacted when I kept a modest spring pre-load. Also you are correct the spring tender helped really cushion the bumps and smooth things out.
Shawn
XMARGH is offline
post #14 of 17 Old Yesterday, 08:03 PM Thread Starter
First Name: Whit
Member #42445
Finished the upgrade. The ride is awesome for what little if done.
Factory clearance: 16 1/4
Tender Upgraded: 18 1/2 less 1 of preload on all 4 corners.
ID:	582894Click image for larger version
'19 XP4 HL
'13 570 LE
post #15 of 17 Old Yesterday, 09:21 PM
E.T.X.Rzr's Avatar
First Name: Justin
My RZR: 2019 HLE4
Member #81149
That must be a 2 gallon bucket if thats 18.5 of ground clearance?
graniteguy16 likes this.
2019 HLE4
E.T.X.Rzr is online now
