Broken axle help - Polaris RZR Forum - RZR Forums.net
RZR XP 1000 High Lifter Edition Discussions related to the RZR XP 1000 High Lifter Edition.
post #1 of 18 Old September 28th, 2016, 11:00 AM Thread Starter
Houk
houk88's Avatar
My RZR: 2015 rzr4 900
Member #61793
View houk88's Photo Gallery(0)
Broken axle help
Send ride out on this machine and the broke the driver front axle flush with the front chunk housing in going to take this to the dealer and pray the replace it however I want to know the best way to repair this and also repair it on the trail because I cut my trip extremely short I will post pictures shortly
houk88 is offline
post #2 of 18 Old September 28th, 2016, 11:39 AM
I Like It Dirty!
filthyredneck's Avatar
First Name: Justin
My RZR: 2015 RZR 1K HLE
Member #46044
View filthyredneck's Photo Gallery(0)
Re: Broken axle help
Easiest way to get it out is drill a hole in the broken off shaft, thread it, and screw a slide hammer in and it'll snatch right out. That particular style break is not one that's easily repaired on the trail. In that case, I'd cut the band's off the outer cv boot, pull the boot out of the way, and pull the axle out of the outer cv and ride 3 wheel drive for the rest of my day.
11' Renegade 800 XXC
15' RZR 1000 HLE
Get Filthy OR Go Home!
filthyredneck is offline
post #3 of 18 Old September 28th, 2016, 11:51 AM Thread Starter
Houk
houk88's Avatar
Member #61793
houk88 is offline
post #4 of 18 Old September 28th, 2016, 11:52 AM Thread Starter
Houk
houk88's Avatar
Member #61793
Thank you for the info
houk88 is offline
post #5 of 18 Old September 28th, 2016, 11:55 AM
jerrzr
Guest
jerrzr's Avatar
Member #
Posts: n/a
View jerrzr's Photo Gallery()
^^^yep.
The last one I had like that, it was quicker for me to weld a piece of 1/2" square flatbar to it so I could grab it with a slide hammer.
post #6 of 18 Old September 28th, 2016, 11:56 AM Thread Starter
Houk
houk88's Avatar
Member #61793
My other opinion question is to upgrade the axles or not I'm afraid if I upgrade the axles the next weakest link is the front chunk?
houk88 is offline
post #7 of 18 Old September 28th, 2016, 12:01 PM
jerrzr
Guest
jerrzr's Avatar
Member #
Posts: n/a
My last rzr I upgraded to rhinos. It's a pretty good bang for the buck. They were more durable than stock but the cvs would still break before the diff would. They will be my next axle on the HLE
post #8 of 18 Old September 28th, 2016, 12:14 PM
kezell17's Avatar
My RZR: 2014 RZR 800 XC
Member #62297
View kezell17's Photo Gallery(0)
How strong are the factory axle in general? If the bike is left in stock form do they hold up?
2017 HL Blue 1000XP
2014 RZR 800 XC w/S-conversion - gone
www.youtube.com/kevinezell
kezell17 is offline
post #9 of 18 Old September 28th, 2016, 12:16 PM
Community Smart***
ReiKo's Avatar
First Name: ReiKo
My RZR: High Lifter
Member #78942
View ReiKo's Photo Gallery(0)
Factory axles are strong enough...
ReiKo is offline
post #10 of 18 Old September 28th, 2016, 12:30 PM
jerrzr
Guest
jerrzr's Avatar
Member #
Posts: n/a
Todd at Hunterworks explains axles very well when it comes to breaking them. Check out his write up:
Polaris RZR XP 1000 900, Polaris Ranger 800 - ATV Axle Info
post #11 of 18 Old September 28th, 2016, 04:08 PM Thread Starter
Houk
houk88's Avatar
Member #61793
I have no idea I know I am running 32 rocktanes and the axle broke on a small dirt hill so I'm gonna go with not that strong
houk88 is offline
post #12 of 18 Old September 28th, 2016, 05:15 PM
I Like It Dirty!
First Name: Justin
Member #46044
With a 32 I'd go with the rhinos. They're quite a bit stronger than stock, but will still break in a bind. Hard to beat them for the money with the warranty they come with
15' RZR 1000 HLE
post #13 of 18 Old September 28th, 2016, 06:02 PM
nwokhunter's Avatar
First Name: Butch
My RZR: 2011 RZR S LE, 2014 XP1000, 2016 xp1000
Member #25902
View nwokhunter's Photo Gallery(0)
I will go to rhinos if I break mine. However I have 1700 miles on my stock axles. Half those miles with 31" tires and the other half with 33's. Ride rocks and mountain trails.
nwokhunter is offline
post #14 of 18 Old September 28th, 2016, 06:29 PM Thread Starter
Houk
houk88's Avatar
Member #61793
Not sure how I shattered mine after 150 miles then
houk88 is offline
post #15 of 18 Old September 28th, 2016, 06:47 PM
jerrzr
Guest
jerrzr's Avatar
Member #
Posts: n/a
There's always that possibility of just a bad axle with a weak spot.
Broken Axle Need Help maddogwfo General RZR Discussion 5 August 18th, 2016 05:17 AM
broken Axle then flipped? Losiento72205 RZR XP Turbo 13 June 8th, 2016 09:27 PM
Broken rear axle wicked_dean RZR XP Turbo 7 June 1st, 2016 08:47 AM
Broken axle? MattVL RZR XP 4 Turbo 18 April 8th, 2016 11:35 PM
