Wire cubes to high beams - Polaris RZR Forum - RZR Forums.net
RZR and UTV Video's Post RZR Videos here
post #1 of 5 Old March 2nd, 2017, 08:06 PM Thread Starter
Buckeye Fan's Avatar
First Name: Brad
My RZR: 18 TURBO S
Member #74302
View Buckeye Fan's Photo Gallery(0)
I'm wanting to wire my cube lights into the high beams. Can anyone tell me the easiest way to do that?
Buckeye Fan is offline
post #2 of 5 Old March 2nd, 2017, 09:00 PM
Xp41thousand's Avatar
First Name: Andy
My RZR: 2015 xp4 1000 Rzr 170
Member #75804
View Xp41thousand's Photo Gallery(0)
Re: Wire cubes to high beams
https://www.rzrforums.net/rzr-xp-4-10...tch-video.html
That will get you on the right track.
Xp41thousand is offline
post #3 of 5 Old March 2nd, 2017, 09:01 PM Thread Starter
First Name: Brad
My RZR: 18 TURBO S
Member #74302
Thanks brother!
post #4 of 5 Old March 2nd, 2017, 09:03 PM
rzr(s)hroom's Avatar
First Name: kevin
My RZR: 2010 rzr s
Member #14447
View rzr(s)hroom's Photo Gallery(0)
find the wire on the back of the headlight switch that is hot with the high beams on. run from that pin to a relay (pin 86 on a 4 post relay iirc). this will act as the trigger and will not draw any extra voltage (which could overload the wire). run power from the battery to the relay (pin 87). run your load (cubes to the relay (pin 30). finally, run pin 85 to ground.
now the relay will sense power on pin 86 when you tun on the high beams. when it senses power it will close the connection between pin 87 to 30, supplying power to the cubes. turn off high beans and the switch opens
not sure of the power draw of your cubes, but a 12v, 30/40amp relay should work fine. you can also get a 5 pin relay, and just not use the center pin (pin 87a)
rzr(s)hroom is offline
post #5 of 5 Old March 2nd, 2017, 09:10 PM
shilo020's Avatar
First Name: Rick
My RZR: Wreck it Rick: 2015 XP1000 Voodoo Blue / You Know...For the Kids: 2015 XP1000 Havasu Red
Member #59828
View shilo020's Photo Gallery(0)
The headlight switch will have 4 wires. Power in. Low beam. High beam. And ground. (For the light in the switch) Tap into the wire for the high beam and attach it to the control terminal of a relay. The relay will need a ground wire. Run a wire (with a fuse) from power to the relay. Then a wire from relay to cubes and another one from cubes to ground. The relay is needed so as to not run too much current through the headlight switch.
shilo020 is online now
High Clearance Offset A-arms w.wood RZR S 900 39 May 6th, 2018 08:08 AM
High Beams don't work rzrboba General RZR Discussion 0 November 14th, 2016 03:31 PM
Polaris to release high performance electric RZR Asaszn General RZR Discussion 21 June 15th, 2016 03:30 PM
Whats this wire? 4gpchris Lighting, Stereo and Electrical 8 February 5th, 2016 11:09 AM
2015 RZR 1000XP High Lifter Edition AMC019 Polaris RZRs For Sale 25 January 23rd, 2016 08:17 PM
