AA RZR Pro XP Build - Polaris RZR Forum - RZR Forums.net
RZR Turbo Engine Discussions for the Polaris RZR XP 4-Stroke DOHC Twin Cylinder Turbocharged Engine/Drivetrain.
 23Likes
post #1 of 42 Old September 3rd, 2019, 06:49 AM Thread Starter
AftermarketAs's Avatar
Member #186569
View AftermarketAs's Photo Gallery(0)
AA RZR Pro XP Build
**Note: as we come out with more products/updates we'll edit this thread, so keep checking back***
The 2020 Pro XP is down on crank rated horsepower compared to the X3 RR, but to the wheels this RZR seems extremely efficient. In the snowmobile world Polaris has always been better at transferring power to the ground... its seems the same with this Pro XP. With the larger water cooled turbo & different cams this RZR is going to be a beast. We had time this weekend to do some initial testing and a little clutching. We were high 170's to the wheels with just a flash, clutching added another 5-7hp. Once we get our notes together and do more testing, we'll show other results.
These clutches are simply amazing to work on! We have seen a similar version on the new style Ranger XP 1000's so clutching these is not completely new. This is very important as making clutch changes easier means better power transfer to the wheels at all times for your terrain/tire. Everything comes apart as soon as you remove the primary bolt, so replacing the wearable buttons will be extremely easy. The entire Pro XP has that satisfying feeling that everything was well thought out. More videos/images to come.
Michael Hurd ([email protected]) (Phone: 715.863.2550)
Aftermarket Assassins Website
Let's admit it, we're all addicted to speed and horsepower. AA is dedicated to help cure your performance needs!
Polaris UTV Performance Specialists - Custom ECU tuning for Powervision, exhaust, clutching & More!
Dynojet tuning certified since 2008
AftermarketAs is offline
post #2 of 42 Old September 3rd, 2019, 06:57 AM
Aspiring Perfectionist
RWB713's Avatar
First Name: Richard
My RZR: 2018 XP4 Turbo
Member #70552
Re: AA RZR Pro XP Build
Only 24 hp loss to the wheels stock? That is impressive...
2018 XPT4 - Bailey
RWB713 is online now
post #3 of 42 Old September 3rd, 2019, 07:58 AM
Chevytahoe4x4's Avatar
Member #230801
View Chevytahoe4x4's Photo Gallery(0)
Sweet
Chevytahoe4x4 is offline
post #4 of 42 Old September 3rd, 2019, 09:29 AM
Dstew619's Avatar
My RZR: 2017 Turbo XP4
Member #174273
Following
Dstew619 is online now
post #5 of 42 Old September 3rd, 2019, 10:04 AM
shubb1282's Avatar
Member #268300
View shubb1282's Photo Gallery(0)
Cams or head look interchangeable with past turbo models?
shubb1282 is online now
post #6 of 42 Old September 3rd, 2019, 10:26 AM
Morris Racing #711
Stairway2Kevin's Avatar
First Name: Kevin
My RZR: 17 XPT
Member #199785
View Stairway2Kevin's Photo Gallery(0)
this, and does the turbo look interchangeable too?
17 XPT - Titanium Matte Metallic
Stairway2Kevin is online now
post #7 of 42 Old September 3rd, 2019, 10:33 AM
Dstew619's Avatar
Member #174273
I'm going to guess to do one part of the top end you have to do it all. Complete top end with turbo and cooling system changes to make it work on older models. Really looking forward to getting some for sure answers on it as well... hoping we can do certain pieces and not the entire thing, but am doubting it.
RWB713 likes this.
post #8 of 42 Old September 3rd, 2019, 12:03 PM
Morris Racing #711
First Name: Kevin
My RZR: 17 XPT
Member #199785
I'm curious because I'm already planning to pull the head this winter and build for next year so if the new head is redesigned and is an improvement I might start with it instead of the what I have.
Dstew619 likes this.
post #9 of 42 Old September 3rd, 2019, 01:03 PM
homdaddy's Avatar
Member #26239
View homdaddy's Photo Gallery(0)
So do you think we can use our old weights and spring s in the new primary.i have one on order as soon as polaris release them.im so tired of the rattling factory 18 primary
homdaddy is offline
post #10 of 42 Old September 3rd, 2019, 01:17 PM
RWB713's Avatar
First Name: Richard
Member #70552
Springs, highly doubtful....weights, no. The pro XP uses a much wider weights.
2018 XPT4 - Bailey
post #11 of 42 Old September 3rd, 2019, 01:39 PM
FRAZR's Avatar
My RZR: XPT4 Velocity
Member #82174
View FRAZR's Photo Gallery(0)
I believe I read that the Pro XP Primary will not work on the older RZRs.
FRAZR is offline
post #12 of 42 Old September 3rd, 2019, 01:57 PM
homdaddy's Avatar
Member #26239
It should it's the same belt from what I've read.so I'll get some springs and weights ordered up .sad pard is I'll get my clutching before my clutch
homdaddy is offline
post #13 of 42 Old September 3rd, 2019, 02:16 PM
Dstew619's Avatar
Member #174273
Don't go assuming because the belt is the same it will work. The entire clutch is completely different along with a completely different housing. Assuming the crankshaft hasn't changed you should be able to upgrade. However, like the top end you'll probably have to buy everything... primary, secondary, cvt housing, cvt cover, intake and exhaust tubes. That all adds up real quick in price, I'd guess over $2k. And then obviously the body has changed, so you'll have to play around with that intake tube to make work.
As far as individual parts from the primary and secondary swapping over to the old primary/secondary, I would say nothing will swap over at all. Far too different. At best will be the spring, but again I doubt it. And the spring is the least of what I want, there are plenty of springs in many different rates available in the aftermarket that works amazingly well already.
post #14 of 42 Old September 3rd, 2019, 02:19 PM
RWB713's Avatar
First Name: Richard
Member #70552
According to Hubert Rowland, the primary clutch will retrofit to the current Turbo, and yes, does use the same belt, but it uses different weights for sure, they are much wider, the spring I don't know, but may be similar in size, spring rate is unknown, plus it'll tune differently than the current primary as well.... The secondary uses a different shaft size, so it will not directly fit.
Check this video around the 13 min mark
Max H, FRAZR and Dstew619 like this.
2018 XPT4 - Bailey
post #15 of 42 Old September 3rd, 2019, 02:33 PM
Dstew619's Avatar
Member #174273
Great video, I love the way that primary comes apart. I'm really hoping Airdam comes out with a retrofit kit for it. However, I still have concerns. Video guy said it fits (assuming he's right), it still looks huge! I don't know if that truly means it'll fit with my current housing. Fit on the crankshaft, sure. So you still might have to buy the entire housing and cover still to truly make work on older models. Looking forward to seeing how it plays out and is adapted.
T-REX and RWB713 like this.
