Blown engine - Polaris RZR Forum - RZR Forums.net
RZR Turbo Engine Discussions for the Polaris RZR XP 4-Stroke DOHC Twin Cylinder Turbocharged Engine/Drivetrain.
 44Likes
post #1 of 80 Old July 29th, 2019, 06:55 PM Thread Starter
15rzrhubbard's Avatar
Member #226369
View 15rzrhubbard's Photo Gallery(0)
Blown engine
Rzr has 970 miles on it with just a stage 5 trinity exhaust and canned Pvcx trinity tune. Iíve been working with Mike at Aftermarket Assassins to make a few improvements. Ended up purchasing 2018 head gasket, new head bolts, from OEM vendor, did DIY oil cooler mod, and RZRjoesí BOV done right mod. Purchased 2017 injectors, low temp spark plugs, and tunes 3, 3.5, 4 and s3 clutch kit with performance helix from Mike. 3 being safe pump gas tune, 3.5 being possible with good pump gas but on the edge and 4 98-100 octane.
Not looking to bash anyone with this thread but looking to find answers and see what failed. I have experience building motors for turboíd tuned import street cars. I have also rebuilt my old 2014 XP1000 at 1,900 mile with no problems. I donít take shortcuts and used OEM manual for head work and everything torques to spec. Before work began everything was cleaned and bed was removed. Any pause in work and everything was covered and protected form FOD and was reinspected before it went back together. Project went smooth nothing was rushed and no leftover parts.
Replaced head gasket, bolts, injectors, spark plugs, clutch kit. Installed oil cooler and BOV, verified timing twice. Loaded stage 3 (pump gas) tune (This is the only tune I have loaded so far). Put clutch kit to recommended weights for tune and 32s. Did vacuum test on BOV mine was .375 instead of rzrJoes' .400. Bled coolant and oil systems, verified BOV/diverter was working correctly, insured clutch was performing correctly at idle.
Did a couple of pulls to insure clutching was working properly and engine temps were stable. Clutching was close Ran it 20 miles on dirt and paved roads, then checking timing again along with coolant and oil levels. Clutch was still running a little hot but that was the case before work was done, it was staying cooler than before, just not where i thought it should be yet. Car was running good, felt a little slower then previous tune and clutch off the line but then would pull strong, figure this was due to not dialing in the clutch yet. Only did one Wide open pull on a road, rest of it was pretty tame between 20-50mph making sure everything was working properly.
Took the car out for another 20 mile run on dirt and paved roads. Driving about 40mph and boom pssssss and died. Wasnít sure what was wrong at this point, and called my wife for a tow. Got it home and have broken spark plug, ruined head, damaged cylinder walls, broken piston. I have not taken it apart yet as I was waiting to see what Mike wanted me to do, damage has been verified with a cheap borescope.
No leaks through this entire process, head bolts and gaskets are still fine with no leaks. No increase in temps at any point and no crazy boost spikes, no miss fires, no hard starting, no engine stumbling, verified timing again and still in.
Open to any ideas and requests for additional pictures to help determine cause.
15rzrhubbard is offline
post #2 of 80 Old July 31st, 2019, 10:41 AM
MCB Performance's Avatar
Member #80756
View MCB Performance's Photo Gallery(0)
Re: Blown engine
Subscribing for pics. Forensics are impossible without data. You didn't possibly drop that plug before installing it did you? Did you notice any signs of detonation when scoping it?
MCB Performance is offline
post #3 of 80 Old July 31st, 2019, 11:49 AM
wrenchinator's Avatar
Member #259882
View wrenchinator's Photo Gallery(0)
Re: Blown engine
Broken plug sounds about right, real bummer in any event.
wrenchinator is offline
post #4 of 80 Old July 31st, 2019, 12:29 PM
EE
FordTruckMan's Avatar
My RZR: 2019 XP Turbo
Member #201969
Re: Blown engine
This is terrible to hear. The carnage sounds exactly like detonation to me, but someone who clearly knows what they are doing, I just can't imagine you didn't hear it pinging if it was actually detonation.
You mention the car felt a little slower than the previous tune, but at the top you said you only had one tune loaded? Am I misunderstanding? I wonder if the damage was done previously and the piston let go later. Can you see any stress cracks in the piston leading away from the hole? I had a blown ranger blow a hole in a piston on a cold start, found out after the fact that it had been run with a tune way to lean previously, even though my tune was on the money. Engine builder said he was surprised it lasted as long as it did.
Good luck man.
FordTruckMan is offline
post #5 of 80 Old July 31st, 2019, 01:01 PM Thread Starter
Member #226369
Re: Blown engine
Fordtruckman. The car was originally on trinity tune and felt good, then did head gasket injectors and the rest of the stuff. Then installed The new aa tune seemed good but clutching was not dialed in. No noise before blew just poofff and coasted to a stop. Plugs were put in with a spark plug socket to insure no closing of the gap. Iíll get more photos when I have the head off.
post #6 of 80 Old July 31st, 2019, 06:49 PM
shubb1282's Avatar
Member #268300
View shubb1282's Photo Gallery(0)
Re: Blown engine
Helping add some pictures since he's having some technical difficulties.
ID:	581238   Click image for larger version
ID:	581240   Click image for larger version
ID:	581242   Click image for larger version
shubb1282 is online now
post #7 of 80 Old July 31st, 2019, 06:50 PM
shubb1282's Avatar
Member #268300
Re: Blown engine
and more
ID:	581246   Click image for larger version
ID:	581248   Click image for larger version
ID:	581250   Click image for larger version
post #8 of 80 Old July 31st, 2019, 06:52 PM
shubb1282's Avatar
Member #268300
Re: Blown engine
and last for now
ID:	581254   Click image for larger version
ID:	581256   Click image for larger version
ID:	581258   Click image for larger version
post #9 of 80 Old July 31st, 2019, 07:01 PM
dartersracing's Avatar
First Name: DONNY
My RZR: 2014 PACE Z1 1000
Member #19554
Feedback Score: 15 reviews
Re: Blown engine
looks like you dropped a valve, what does the top of valve look like?
209-373-5336 DONNY DARTER
dartersracing is offline
post #10 of 80 Old July 31st, 2019, 07:17 PM
EE
Member #201969
Re: Blown engine
I'll second the dropped valve. Is the spring damaged? Or the retaining clip? You didn't happen to check valve clearances when you were doing the gasket, injectors, etc.?
15rzrhubbard, slomo and RZR_Scott like this.
post #11 of 80 Old July 31st, 2019, 07:29 PM Thread Starter
Member #226369
Re: Blown engine
I did check them while I was in there. They were in tolerance, well extremely close
post #12 of 80 Old July 31st, 2019, 08:09 PM
shubb1282's Avatar
Member #268300
Lean not damaged plug
post #13 of 80 Old July 31st, 2019, 08:20 PM
RZR_Scott's Avatar
My RZR: 2014 800 XC
Member #271236
Re: Blown engine
I'll third the dropped valve, curious about the spring too.
RZR_Scott is offline
post #14 of 80 Old July 31st, 2019, 08:49 PM
mrw8i's Avatar
My RZR: 2019 XP4 Turbo & 2013 800S LE
Member #48175
View mrw8i's Photo Gallery(0)
Re: Blown engine
My guess is detonation. Everything else came after.
15rzrhubbard likes this.
2019 XP4 Turbo - Isota Glass Windshield, PRP Seats
2013 800S LE - MCX Turbo, DG Offroad Cage, Racertech Front Bumper, PRP Seats, Cheap Deep Dish Steering Wheel, Exit X2 Shocks
mrw8i is online now
post #15 of 80 Old July 31st, 2019, 08:52 PM Thread Starter
Member #226369
Re: Blown engine
Would lean conditions cause valve drop ? Just curious because the plugs look brand new. No fuel on them.
