Compressor Wheel Play? - Polaris RZR Forum - RZR Forums.net
RZR Turbo Engine Discussions for the Polaris RZR XP 4-Stroke DOHC Twin Cylinder Turbocharged Engine/Drivetrain.
post #1 of 5 Old June 11th, 2019, 10:05 AM Thread Starter
APS's Avatar
Member #213025
View APS's Photo Gallery(0)
How much play should be in the compressor wheel?
Realized my air filter somehow fell off during a 260 mile ride. probably on mile 1! Was loosing boost towards the end of the ride but kept the hammer down. After clean up pulled my AA blow off valve for a cleaning. Figured that was the source of what seemed like loss of power due to loss of boost. Discovered dirt on the clean side and popped open the air box. Surprise! loose filter.
Plumbing between the turbo and intake is filthy. Compressor wheel seems to have lots of play but is not contacting the housing. Oil looks good gonna do a compression test this afternoon.
APS is offline
post #2 of 5 Old June 12th, 2019, 04:03 AM Thread Starter
APS's Avatar
Member #213025
Re: Compressor Wheel Play?
UPDATE
I spoke with a reliable source yesterday evening regarding the slack in the compressor wheel. He tells me there is a surprising amount of play in the wheel found in a healthy stock turbo. He advised me to clean up the plumbing thouroughly. Also advised me to clean or replace the map sensors in the charge tube and intake tube. I cleaned everything thouroughly with throttle body cleaner. cleaned out the turbo and buttoned everything back up. Took the rig out for a test rip and everything seems to be back to normal. Throttle response and boost are spot on. Currently tuned with an AA stage 1. No smell of burning oil or other signs of motor damage. Hopefully I caught this in time before any real damage was done. I am sure the lifespan of the turbo has been compromised but for now she is good to go. Going to order one of the Donaldson Filters from AA today that clamps on. I am not sure how the stock filter came loose. No one I talked to has heard of that being an issue. I will be more diligent in my air filter inspections from now on.
APS is offline
post #3 of 5 Old June 12th, 2019, 07:01 AM
Morris Racing #711
Stairway2Kevin's Avatar
First Name: Kevin
My RZR: 17 XPT
Member #199785
View Stairway2Kevin's Photo Gallery(0)
A little side to side play is ok as long as the blades aren't touching the housing and/or the seals aren't leaking, but if you have up and down or around (however you want to word it) play then I would suggest a rebuild.
17 XPT - Titanium Matte Metallic
Stairway2Kevin is offline
post #4 of 5 Old June 12th, 2019, 09:23 AM
psheadl's Avatar
First Name: Paul
My RZR: 2014 XP1K (sold), 2016 XPT4, 2017 XP1K
Member #31171
View psheadl's Photo Gallery(0)
Arizona Flag Re: Compressor Wheel Play?
I used to work for Air Research on turbocharging automotive engines. The bearings "float" so it appears to have a lot of play on the shaft. In some cases the compressor blades initially rub so that clearance is minimized. I doubt that you can ingest enough dust to damage the compressor before internal engine damage occurs. Biggest damage potential to the turbo is large object ingestion like fasteners or debris.
psheadl is offline
post #5 of 5 Old June 12th, 2019, 09:38 AM Thread Starter
APS's Avatar
Member #213025
Thanks for the input. I did not mention I fired the motor up with the intake tube loose and let it run up to operating speed. I shut it down and watched the compressor wheel free spool with ease for a long time. I figured that is a good sign. I also checked the play in the wheel warmed up and it was quite a bit less. I imagine the large tolerance cold is to compensate and leave room for when the turbo gets hot and expands.
APS is offline
